apostolakisl
Everything posted by apostolakisl
  1. From this screen. I have the edit enabled, I change the name (just deleted the AHU3 part). I hit "save" in the upper right corner that shows up after I start editing, it does the little swirly thing for a couple seconds and takes me back to the previous page. But nothing changed. Same name (which is apparently too long and it is cutting off the word "lobby"). And if I hit device dashboard again, it returns me to the page shown above with the name still un-edited. This ISY is running 6.0.4
  2. Right after I upgraded, I went out of town. There was a big wind storm and it blew over an outdoor potted plant that had led lights in it controlled by a lamplinc. The wire to the lights tore and it was making the lamplinc sense go bananas. 6.0.5 could not function with that going on. Via VPN, Michel downgraded me to 6.0.4 which got ISY to run, but the java programs page wouldn't open. The programs were all working, you just couldn't get to them in java. But you could in UD mobile. Michel said there was a program set to run at start that was in a loop doing this. I was skeptical, because I have had all those programs for years without issue. Anyway, I shut down all the run at startup programs from ud mobile, but the programs page was still blank (no panes or grids or anything, just a blue screen). I tried upgrading to 6.0.5 again and now all is fine. I re-activated all the run at startup programs and all is still fine. My theory is that the downgrade wasn't complete and there were some mis-matched files preventing the java programs page to load. The main thing here, as I see it, is that 6.0.5 crashes if an Insteon device is misbehaving whereas previous versions could deal with it.
  3. had some issues with .05 and went back to .04. The node is still populating correctly. ???
  4. @Javi I am still having issues with the names of thermostats I added. For Example, Venstar AHU1 Conf (this is fine, displays as expected) Venstar AHU3 Lobby (this displays as Venstar AHU3 it cut off the Lobby part) I open the full device dashboard page and the full name is there, I try to edit the name, hit save, but it doesn't save it.
  5. I'm still on 6.0.4 and did legacy sync and at first glance it seemed to have worked.
  6. I restored a backup from a few months ago, and all is normal for how it was at that time. But when I do a synchronize, it breaks again. I got no errors, but my nodes are either missing, not configured correctly, and nothing populates. This isy is running 6.0.4. I haven't made any changes to the ISY firmware since I upgraded to 6.0.4 however long ago that was (not long after it was first introduced). The changes I made that needed sync'ing was I added a new PG node and moved a PG2 node to PG3 and deleted a few devices and changed a few programs. EDIT I tried uninstalling ud mobile and clearing all data. Again, the sync results in the same non-functional ud mobile. Restoring the backup gets it back to a working ud mobile as it was at that time.
  7. I have two ISY's connected to UD mobile. I made a bunch of changes to one of them and re-synced it. I got some error about a node definitions file if I recall and now none of the nodes on that 1 ISY work. My favorites folder had bunches of stuff from that ISY disappear. Further syncs show no error but don't fix it. @Javi The other isy seems to be normal.
  8. @paulbates Seems that you are correct. I factory reset again, setup wifi, turned on api, and they are both working with nodelink and pg3x. I will let it go for a few days and then see what happens if I try connecting to skyport.
  9. Possible. I factory reset the two that aren't working, connected to wifi and turned on the local api, and I got a connection on nodelink (didn't try pg3x at that point). I thought I had it fixed, I then rejoined skyport thinking I was good. When I went back later to check on it, it was no longer working. So maybe I need to leave skyport off.
  10. There are no clients connected to the ones that won't connect. The ones that will connect have no issue being connected to nodelink and pg3 at the same time and accepting manual queries. The ones with no cleints connected won't respond to manual query commands either. I tried connecting to only 1 thing, then if it didn't work tried the other thing. I agree with chatpgt analysis that the thermostats' public api engine is crashed/frozen/whatever word you want to use. It is clearly on but not responding to anything but simple commands.
  11. I just noticed in nodelink that the two t5800 with dongles that aren't connecting are reporting the thermostat type and firmware to nodelink. Nodelink shows that info, but it does not show any data. I did a curl query to one of the thermostats that doesn't connect and the same to the one that does, and the one thermostat gives a response, the other doesn't. It seems as though the local api is off, despite being on. C:\Users\apostolakisl>curl 192.168.3.89:80/query/info {"name":"AHU3 153434240000000000bby","mode":3,"state":0,"fan":0,"fanstate":0,"tempunits":0,"schedule":1,"schedulepart":1,"away":0,"spacetemp":73.0,"heattemp":67.0,"cooltemp":76.0,"cooltempmin":35.0,"cooltempmax":99.0,"heattempmin":35.00,"heattempmax":99.0,"setpointdelta":2.0,"availablemodes":0} C:\Users\apostolakisl>curl 192.168.3.127:80/query/info C:\Users\apostolakisl> CHAT GPT said this: What’s happening internally on your Venstar T5800 is likely: HTTP connection accepted Request handed to handler thread Handler tries to process route (/foobar, /query, etc.) Handler crashes / times out internally Socket closes with no response → curl shows empty reply 👉 That delay = the thermostat is attempting to process the request and failing, not ignoring it. chat gpt basically wants me to do a hard reset. it thinks the api subsystem is locked up. if that fails, do a factory reset. This is consistent with me having issues with other thermostats that somehow stopped having issues. @Guy Lavoie The SD card just needs to be between 2 and 16GB and Fat32 formatted. I use a micro SD and an adapter. You can download a tool from venstar that puts the firmware and any custom images you want onto the card.
  12. apostolakisl replied to Techman's topic in eisy
    Things did not go well. 6.0.4 to 6.0.5. Seemed to go well at first glance. But opening java ac takes forever. None of my insteon nodes populate. programs aren't running. Can't open java ac programs page, it times out and gives error. Can't open programs page from ud mobile, gives an error. Can't open eisy ui. It gets a response from eisy as evidenced by the non-secure icon showing open in the browser, then it just spins forever. I tried a reboot from an ssh session. That didn't fix anything. I also did a java update and deleted the cache and all which did not work (as expected since problems all around, not just java).
  13. Initial testing would indicate yes. The one node populates several seconds before the other, but it does populate and previously it never populated without a query.
  14. I have a similar issue with an Elk node. I have two garages that are monitored by Elk alarm. I set them both up to display on my favorites page. But only one of them ever populates without doing a query. The other always populates. They are identical to each other except for the specific Elk sub-node referenced. It has been like this for a very long time. If I close UD mobile and open it back up, the node is again not populated. According to google play store, I am up to date on ud mobile app. If I look at all of my Elk nodes, it seems hit or miss which ones are populated. What can I do about this?
  15. No, you can't. But you don't need to set the on level to 0, just use the controller off button. Of course if you want it so that no matter what action you take at the controller, the scene turns off, then you would need to set on level to 0 for all devices. If it is a kpl, you can set it to non-toggle off instead. Isy used to let you propogate the settings for one controller to all of them, but they got rid of that many moons ago when they added non-insteon products. Apparently the logic broke when applying to node server devices.
  16. I now have 3 connected Venstar thermostats. I just added a 4th, and it won't connect. This makes no sense. Two of the others also wouldn't connect, then one day out of the blue they started connecting. The 3rd unit discovered immediately. I do not understand this. I ask the thermostat to do a firmware update and it says it is already up to date. The others supposedly were also up to date. Perhaps some update is actually happening after being online for a while even though it says not? Two of the connected thermostats are t5800 with wifi key, and one is a t7850 with built in wifi. The 4th is also a t5800 with a key. All of them are connected to the Venstar skyport server without issue.
  17. apostolakisl replied to jkraus's topic in IoX Support
    Speak for yourself. Texas time. . .
  18. apostolakisl replied to jkraus's topic in IoX Support
    Just turn off DST and and use UTC-x hours. No need to pay any attention to the name of your time zone. Like I am in UTC-6. Personally, I am a fan of DST always. I didn't notice any issues with DST except that programs that run continuously looking for failed heartbeats all reported failed heartbeats at 3am. These programs all track thermometers and look for any change in the temp or humidity which restarts the program. They all have a wait time of 10 or 20 minutes and if no re-trigger of the if clause happens in that time, they send an email. So the jump from 2am to 3am was interpreted as no update in one hour. So I guess a wait clause is not a running timer but rather sets a start time upon starting and then loops back every cycle of a code and does some subtraction. Since 2:05 never happened, and the program triggered at 3am, it must do it that way. I would think that things like waits would run on UTC time and be unaffected by the displayed time, but obviously they use the displayed time. I would expect sunrise and sunset to always run on UTC and your latitude/longitude and therefore be unaffected by chosen display time. If ISY just ran on UTC time everything would work fine through DST switch except something scheduled to happen at displayed time between 2 and 3am.
  19. The eisy-ui is stable, it is just not complete. It is not yet a replacement for the java ui. It is mostly just a place to view things, not program things. You can turn lights on and off and stuff like that.
  20. What link doesn't work? The link I posted works. I just did a java update and used that link to reinstall iox finder last week. And clicking it today downloads the file, though I didn't try installing it.
  21. I linked this page to my bookmarks and use it. It has never been changed and still works today since it was posted in 2018.
  22. Iox finder would be perfect if it weren't for Java updates. You would load it once and be done. Any isy that it finds or you direct it to find (port 8080 or an isy on a vpn or vlan) would populate and be there indefinitely regardless of isy firmware current or future. But for some stupid reason java makes you redo it with every update. I just bookmarked the page for the start.jnlp link so I can quickly redo it after each update of java. I have not tried where iox finder lets you save/load your configuration. Probably that would let me not manually add back my off-site isy and port 8080 preference.
  23. Must not have been using finder. The start.jnlp link must be used, not admin.jnlp. The finder can access multiple isy's on different firmware at the same time. For a while I had a 994i and Polisy at the same time with way different firmware. Clearing the cache is still an issue after updating java, not after updating isy. For local credentials you must manually add. Http://xxx.xxx.xxx.xxx:8080. If you let it automatically find your isy it will go through portal credentials. It really would be fine if it weren't for java updates. Seems like every windows update triggers a java update.
  24. I believe that loads a firmware specific IoX launcher. At least it used to, perhaps that has changed. I have had issues with that in the past still getting messed up by cached Java stuff when firmwares change. Again, I haven't messed with this in a long time since I just keep using IoX launcher that I downloaded a long time ago that keeps working on multiple and updated versions of ISY firmware without needing any update to the launcher. The main issue I run into is after updating the actual Java app, not updating ISY. I also manage multiple ISY's at different locations over VPN's so I manually put in the IP addresses. Though you could also go to the ISY portal and copy the portal URL for your ISY and do it over the open internet. In short, either way works. I would suggest that he completely clear Java cache and applets to be sure that everything is starting off fresh.
  25. When you load IoX launcher on your desktop, it will find ISY automatically but it will only automatically give you the portal login. If you want to add the local option, click "add" and then type in the url. ie, http://xxx.xxx.xxx.xxx:8080 or you can use the https://xxx.xxx.xxx.xxx:8443 if you want an encrypted connection (I don't see the point when inside your lan). If you have your ISY across a vpn or on a different vlan, or you have auto-discovery blocked by your router, then you will need to manually enter the ip no matter what. Whether you use the local credentials or portal credentials, it doesn't matter, both work the same. And the login prompt will tell you which to use in case you lose track of what you clicked on. EDIT: This is where you want to delete all the java saved applets and configurations. This is very important. When you relaunch the start.jnlp you will get the iox launcher that autodiscovers the firmware and works across multiple firmwares of ISY. Generally, I have found that it will also not need to be cleared again upon further updates to ISY. But if it starts giving you issues, then just repeat this process.
