Everything posted by rick.curl
Adding new door contact fails
Update: The sensor I am trying to add is a Sercomm SZ-DWS08(N), and apparently it makes my Eisy go nuts every time I try to pair it. Time to abandon this sensor and try something else. BTW- I did try factory resetting the sensor, but it didn't help. I am looking for a Zigbee door/window contact that has a reed switch (instead of a hall effect sensor) inside. The reason I need one with a reed switch is that I will be hacking it to attach wires so I can connect it to a relay contact on my Generac generator so I will get notification when the generator is running. Can anyone recommend a Zigbee contact that will work? Thanks. -Rick
....But this is Zigbee, not Zwave. I don't have the menu option to exclude a device.
Thanks, but since the new device does not show up, how can I do that?
I Have an Eisy with the Zigbee dongle. I had modified a Zigbee door contact to notify me when my generator is running. The door contact failed after working for a year, and I attempted to replace it with a similar one. When I tried to pair the new contact, my Eisy seemed to lose its mind. It kept interviewing non-existent Zigbee devices and I couldn't make it stop. After 20 minutes or so I rebooted the Eisy. It shows a couple new Zigbee devices (that don't actually exist), but my new device is not in the list. What happened? How can I fix this? Thanks for any advice. -Rick
Tried these Matter bulbs. No love.
Aidot does offer matter sharing, but only to other users of the Aidot app. Google Home and Smarthome will both require that I install a matter hub. I thought Eisy would serve as a Matter hub. Will Eisy eventually support adding Matter devices without having to add another hub or gateway? I'm confused.
Good catch! I had missed that IPV6 was required. Got it turned on now, but I'm still getting "Could not add Matter Device. Bluetooth Unsubscribed. 500" I don't have Google Home. I can successfully add these smart plugs to the Aidot app (from their manufacturer). I did reset the plugs to factory default before trying to add them to the Eisy.
Android. It's a Google Pixel 7. I did upgrade to 5.9.1.18, but no joy. Looking forward to getting this working. I really need to be able to control a few devices via Wifi instead of PLC or Insteon's mesh RF system. We've got a big piece of property and our Wifi network has outdoor repeaters.
Last week I tried to pair a Linkind Smartplug LC09003-PLUG-US-4 and I got this error message:. Could not get Matter QR Code rendezvous Type for MT:4Q0002:E15S60F76G00. 500 At the time I was on 5.9.1.7. I upgraded to 5.9.1.17 and tried again. I thought for a minute that it was going to work, but UD mobile finally gave me the error message: "could not add Matter Device. Bluetooth Unsubscribed. 500". Any idea what it is telling me?
how could I have ISY send a text that has a button..
I wonder if Pushover might be the solution. Look here: https://pushover.net I am using it to send me text messages from Eisy when my generator is running. -Rick
Similar problems here. I got a pack of four Linkind Smartplugs LC09003-PLUG-US-4. When I try to add them by scanning the QR code with UD mobile, I get: Could not get Matter QR Code rendezvous Type for MT:4Q0002:E15S60F76G00. 500 Hopefully somebody will straighten it out soon....... -Rick
Zigbee device turns off unexpectedly
That makes a lot of sense I didn't know that. I just replaced the Zigbee smart switch with a different brand and all is good now. Thanks for the help!
it looks like this is an issue with Wooley smart plugs. Not the fault of Eisy. Now that I know this- is there a way I can write a program so if a scene is switched on, to send the "on" commend every 5 minutes or so? I thought it would have been easy, but under the "if" section of code I can check a number of things, but I don't see a way to check to see if a scene is turned on or not. Am I missing something obvious? -Rick
I got the bookcase moved so I can see the Zigbee device. It's a Woolley SA-035-10A-ZB: https://www.aliexpress.us/item/3256805874315420.html It also has the number BSD17 on it. There's nothing in the instruction sheet that indicates a default timing function. Any thoughts? Thanks.
Unfortunately the switch is in a wall box behind a big heavy bookcase. I'll try to get access to it in the next couple days. I really should have made a note of the type of switch. Lesson learned. -Rick
Thanks. Previous logs: Four logs giving the time: [ Time] 19:52:30 60(0) preceeded by: Create Rest U7 [/rest/profiles/ns/3/connection] Create Rest U7 [/rest/profiles/ns/4/connection] Create Rest U7 [/rest/profiles/ns/0/connection] Before that there were a bunch more entries giving the time. Does this help? I would have uploaded the log, but I only printed a screen.
I recently added a Zigbee wall switch to control fans in my living room and it is generally working, but the fabs unexpectedly turn off after about half an hour. If I turn on the event viewer at level 3 I see this when the fans turn off: [D2D Event ] Event [ZB55785_001_1] [ST] [0] uom-78 prec = 0 [ZB55785_001_1] ST 0 (uom=78 prec=0) What is this telling me? Thanks! -Rick
Constant X10 Chatter in Event Viewer
UPDATE: I unplugged and re-plugged the PLM and the extra traffic is GONE! Hope it stays that way.
Can't add new Z-wave devices
I tried it with and without the extra tap. No joy. In case it was the DZPA1 at fault, I tried to add a Minoston MP20Z and it failed too.
I have exactly the same issue, and, like you, I am seeing the traffic from 02 52 FF 80 a couple times a second. I don't have a spare PLM. Should I try to get one? I wonder if anyone else is seeing the same thing.
Thanks for the response. I did as you suggested, and here's what I saw: Fri 11/10/2023 06:39:50 AM : ---- Start Adding Devices - S2 Standard --- Fri 11/10/2023 06:39:50 AM : [ZWAVE-INCL-S2STD] Start Include with S0/S2 or non-secure Fri 11/10/2023 06:39:50 AM : [ZWAVE-INCL-S2STD] Added 'CommandAdded' callback 0x842032ca8 Fri 11/10/2023 06:39:50 AM : Z-Wave Listening for Z-Wave devices to add to the network Fri 11/10/2023 06:39:50 AM : [X10-RX ] 02 52 FF 80 Fri 11/10/2023 06:39:50 AM : [ X10] J/Status Request (10) Fri 11/10/2023 06:39:50 AM : [X10-RX ] 02 52 FF 80 Fri 11/10/2023 06:39:50 AM : [ X10] J/Status Request (10) Fri 11/10/2023 06:39:51 AM : [X10-RX ] 02 52 FF 80 Fri 11/10/2023 06:39:52 AM : [ X10] J/Status Request (10) Fri 11/10/2023 06:39:52 AM : [X10-RX ] 02 52 FF 80 There are many more "status request" lines, but no response from a Z-wave device. The DZPA1 was blinking amber, indicating that it was ready to be included. Thoughts?
I just attempted to add a Leviton DZPA-1 ON/OFF receptacle to my system and the system gets stuck adding a device to the Z-wave network. I tried another device and I got the same thing. I have other DZPA-1's in my network and I was able to add them with no trouble at all, so I know they are compatible. At this point it looks like I have lost the ability to add Z-wave devices. I can control Z-wave devices so that would imply that the dongle is working. I tried unplugging and re-plugging the Z-wave/Zigbee dongle and then restarting IoX, but it did not help. I'm running IoX 5.7.0. Any suggestions? Thanks. -Rick
Sonoff S31 ZB on Eisy?
I attempted to link a Sonoff S31 Lite ZB Zigbee smart plug with my Eisy and something jumped the track. It was recognized as "ZB440505.1 Main", and the interview process seemed to complete normally, but the first time I tried to control it I got "Platform_errors--7058" and "platform_errors--7123". I take it that this means it is not supported yet? Thanks for any insight on this. -Rick
IoX finder "Not Found" error message
Thanks, Techman. Actually, the solution was in that thread. See Geddy's post near the bottom. Sorry I didn't find that before starting a new thread. -Rick
Originally when I ran the IoX finder it would show me one IP address. A few weeks ago this changed and now I am seeing the IP address followed by port 8443, then "eisy.local.8443", but then an error message "not found" pops up. I can acknowledge the error message and log in with no trouble, but I am wondering what the message is about. Any ideas? Thanks! -Rick
Many "not available" entries after Zigbee synchronization
I opened a ticket last week, but still no response. I am especially concerned that for the last couple of days when I try to check my tickets their website says "There has been a critical error on this website". I hope the folks at Universal Devices are OK. -Rick
