Everything posted by garybixler
TIVO not being added
I have upgraded from Pg3 to eisy-ui and that is when the inputed data doesn't get saved. The last log sent was from the eisy-ui plugin.
@firstone Hi, Was wondering if the problem with adding TiVo was seen in the latest logs. It just seems to be the problem of saving the entered data. Nothing I added gets saved. The save button basically does nothing. Thanks Gary
Solid State Relay
Thanks @apostolakisl , Found them.
Solid State Relay
Thanks @EricBarish and @TJF1960 , I couldn't fine them from the picture. I was wondering if you could provide a part number and where to buy. Thanks Gary
Solid State Relay
Hi, I am looking for any suggestion on what relay would be compatible with the webcontrol8 controller. I have found some optically isolated Solid State Relays (SSRs) but would like a recomadation on ones that have been used with the webcontrol8. Thanks Gary
No data being received
I set the log to debug and did a couple of restarts and re authenticated. I can send commands but receive no data. Test connection is successful. Log included. Thanks. Gary TeslaEVstream-log-2026-11-03T14-02-13.187Z.zip
@Panda88 Hi, The problem I dad previously with being able to send commands to my Tesla but not receive any data has returned. What ever UDI did initially to fix the problem seems to have been undone. I did migrate the plugin over to eisy-ui but it may not have been receiving before that. Thanks Gary
Virtual showing percent
@sjenkins Hi, I have discovered that the virtual dimmer will not accept the status being set to 0. It requires 1 and above otherwise it will default to 5. Maybe that could be addressed in the Virtual plugin. Thanks. Gary
@sjenkins Hi, I tried setting different things at the node but every time it gets an update from the variable that is 0 it defaults to 5. Maybe I missed something that you were saying. I did see the range in the virtual dimmer definition showing a range of 1-100. Is there something need in the definition? Thanks Gary
I have been trying the virtual dimmer but have a couple of questions. First my conf is {"type": "dimmer", "name": "Light Level"}. I noticed that you can't add special characters like % to the name. I am updating the status from a variable and can't seem to get the status to show 0. The lowest it will go is 5, Thanks for any assistance. Gary
Hi, Just wondering if a virtual device could be added showing a percent value for humidity etc. Thanks. Please disregard. Ill try using a dimmer switch. Gary
Variables displayed
Thanks, I'll give that a try.
Variables displayed
Hi, I was wondering if variable may be displayed in tiles. Would also be nice if they could be tagged as degrees in Fahrenheit and percentages. Thanks Gary
Humidity sensor problem
Eric I have checked the voltage and all is good there. If you install the sensor face up as in the diagram in the manual you would be putting + voltage on pin 1 and ground on pin 3. The datasheet for the HIH-4021-002 shows pin1 as ground and pin 3 as + voltage. So with my next one I will follow the stats for the HIH-4021-002. The second sensor I tried did overheat as I connected it as shown but quickly disconnect it from the board. I reversed polarity and it then did work without overheating but the readings are not accurate, I think the over heating caused internal damage. I have one more sensor coming so hopefully the third time will be the charm Gary
I think I am finding that the pinout for the HIH-4021-003 is different than shown in the manual. I am seeing pin 1 as ground, pin 2 as out and pin 3 V.
Hi, I first got the HIH-4021-003 from Digi key and accidently installed it backwards and it absolutely burnt up. Next I correctly installed an HIH-4000-002 from eBay and it to burnt up. Waiting for the second HIH-4021-003 from Digi Key to try but I can see the problem with the first sensor but the second one should have worked. Am I using the wrong sensors? I doubled checked the voltages from the Webcontrol8 and they look fine. Thanks for any thoughts. Gary
Light sensor inverted voltage.
Thanks Guy, I added this to the webcontrol8 PLC programing. START SUB 500 AIP2 VAR1 SKIP_OFF: END It does work but I don't think the light sensor is very linear. I can get 0 in full darkness and 498 in bright light as a value in the variable. Gary
Hi, I found some ambient light sensors that work very well giving a reading of 0 to 400+ giving them a very good range. However the problem is that the analog output is reversed from what is expected. 0 is light and 400+ is dark. Just wondering if there might be a way of inverting that through the webcontrl8 itself. Still looking for a light sensor that outputs the expected range of 0 for dark and 400+ for light. I do have some passive light sensors but they don't have the amp to increase their range of sensitivity. Thanks for any advice. Gary It looks like it can be done with PLC programming but I would not know how to do that.
Davis_V2
Thanks Bob, Working perfectly. Gary
Davis_V2
I tried the migration but got a 404 error so I just deleted it from Pg3 and tried to install directly in eisy but I then get this error 'Plugin archive not found' Thanks Gary
Pg3 migration causing problems.
I am on the latest software and AVRemote still will not find any Tivos. I enter the url of the Tivos and do a save but it doesn't really save. No saving bar appears on the bottom right of the screen. When I restart the info I entered disappears. I have done reinstalls and restarts but there is no change. Gary
Davis_V2
I have been using the Davis_V2 node server for quit awhile now and was wondering if it will be moving to the production store. My last NS to migrate. Thanks Gary
More problems with migration
I just updated to the latest software and still can't get my two Rokus to load properly One or the other will show an internal server error on the node.
I just did the latest software update and still can't get AVRemote to save and fine Tivos.
Awoken at 3 AM in the last 2 days
I have been able to recreate the event. If the eisy-ui is rebooted and then run the QueryAll program the event will happen. Since I needed to reboot the eisy-ui daily because of the migration that is why it has been happing lately. Thanks Gary
