Everything posted by Javi
ZMatter USB Firmware Update 7.32 to 7.46
That is not were Long Range ability is defined, try to add a long range device in eisy and the option will be shown, or will show the reason Long Range is disabled. The update site is only used to update firmware, nothing else, all other options are set from eisyui
Admin Console
Are you sure this is the same Web Server? Admin Console > Configuration > Networking > Web Server
Admin Console
NR is already implemented, although requires fixes, in the next release. Web Server is legacy, and using default conflicts with eisy-ui. We had not planned on migrating this feature, files can still be added via ssh. What is the use case?
Creating Favorites Page For Others
I recommend using eisy-ui going forward. If it is the same 'user' any changes made to favorites will propagate to all users. Until we have an eisy-ui mobile app just open directly with link. We are in the process of verifying mobile compatibility, most of the newer pages are mobile compatible, some of the older pages may require horizontal scroll/zoom/etc. Release notes for 1.3.8 - eisy can now be accessed remotely at https://{uuid-no-colon}.isy.io
2843-222 Open/Close Sensor to display Open-Close
UD Mobile allows custom formatted values. See https://wiki.universal-devices.com/UD_Mobile#Individual_Status_Mappings
EISY column ajdustment
The program and node data grids are scheduled to be replaced for mobile compatibility and virtualization (to fix refresh issues). Feature requests are deferred on these 2 screens until changed.
eisy-ui line spacing
Light/Dark/System implemented in current beta Menu > Settings > Display The program and node data grids are scheduled to be replaced for mobile compatibility and virtualization (to fix refresh issues), so feature requests are deferred on these 2 screens until changed.
How do I add a device to a scene?
eisy UI 1.3.11_1 should be correct. try reboot and clearing browser cache (F5), if not showing the folder/scene selection dialog when selecting "move to folder" or "add to group".
US LR is compatible with both Mesh and Long range. Select when including a new device. I'm not sure what you ordered, this is a hardware distributer's upgrade, similar to using zooz site to update your zooz dongle. The region is set in eisy-ui > Menu > Zwave. US LR required for Long Range.
No, was not needed from 7.32 to 7.42, which is the min requirement for Long Range.
There is no drag and drop in latest beta, right click context menu > add to group
Only tested to 7.42, Also as a reference to others the direct link to instructions is https://wiki.universal-devices.com/Eisy:User_Guide#ZMatter_USB_Dongle_Firmware_Upgrade
Suggested UD Mobile Feature - Autobackup of ISY
Or /api/system/backup/create which will respond with the endpoint of the zip file /api/system/backup/download
Right click, drag and drop no longer exists on the node page, might need to refresh and/or reboot.
Yes we locked out z-wave long range unless at a min version (7.42) as other version had too many issues. eisy-ui is currently the only interface which gives you the option to choose mesh or long-range. Tip: take a picture of the QR code and upload to pc, then select the image instead of trying to scan with a PC camera.... or use eisy-ui on mobile
The instruction was from my own Z-Wave upgrade, on mac so glad to hear it works on windows. Nothing was lost in my case, needed to fix long range bug.
Beta is stable, https://forum.universal-devices.com/topic/47042-eisy-ui-is-getting-there-heres-where-we-stand/
Geofencing for Multiple Users with UD Mobile
See https://wiki.universal-devices.com/UD_Mobile#Occupancy_v2.0_Node_Server
- Slow Response
Admin Console
See https://wiki.universal-devices.com/Main_Page#On_Big_Sur,_Admin_Console_is_no_longer_a_separate_Window
This is changed in beta, to show a selection dialog instead.
Slow Response
If using beta repo for upgrades I would first verify the issue, is the status slow to update or is the program scene slow to execute. Open the event viewer on you phone before you walk into a room if the status change immediately and there is a delay then investigate that path. If status does not update immediately then investigate that path. For the latter, try removing the devices and specify long range (only available in beta) during inclusion. An alternative, if both devices support local linking add both as mesh in a scene (although this may cause other issues depending on your setup).
V1.3.11_1 Refresh in Programs makes search unusable
Programs are re-evaluating very frequency. Not an issue but is the cause. The programs list is scheduled for virtualization which will correct, but not sure on the time frame. All improvements to original grids/lists are deferred until virtualization is complete. This is also needed for mobile implementation so is high on the list.
Program To be Triggered by Its Own Folder Condition
It will not trigger inside the folder. What I reference is in a program an if condition can be the status if another program (e.g. the folder), in this case it's not the folder's conditions triggering the program it is the folders's status triggering the program.
#1 No. A folder status must be true for automatic condition (IF) evaluation of children. It does not trigger evaluation, this still requires and event/status-change/etc. You could have a sibling program (to the folder) run a programs (IF) condition when the folder becomes true. This may even work in the program itself. Be aware that if the programs condition condition is an event, it will fail (IF), as the event is not true (is not happening). If the condition is a status and is true it will run.
