Javi
Employees
Joined
Last visited
Currently
Viewing Topic: Plugin has been Migrated
Everything posted by Javi
How to copy the program txt from web ui ?
Implemented see: https://wiki.universal-devices.com/Eisy-ui#Programs
Eisy-ui control of Insteon Configurations
Fixes will be in production before then.
EISY-UI Network Resources - UDP Commands
Thanks, JSON body is being converted to JSON object. I don't think it will make it in the next release, but should be in subsequent. Fix ID: /eisy-ui/pull/177
Thanks, there were some recent fixes, so please try the staging version of first. If that does not work please provide the exact string used in the body. I could not replicate, so my guess is the body may be causing issues with the parser.
Feature Request: Tabbed Page Navigation
This is on the todo list.
Hue XY setting in Scenes NOT WORKING
Thanks. Fixed saving scene links with prec values. Did not make it into the next release, so likely subsequent. Until then please use Admin Console for this situation. fix ID: /eisy-ui/pull/175
Insteon Configuration options were improved/fixed in eisy-ui 1.4.13 https://wiki.universal-devices.com/Eisy-ui#Insteon
Firefox and Web Edits in eisy-ui
Time increments in Programs were recently fixed, as some browsers did not work. ID: /eisy-ui/pull/160 Should be in the latest staging
Plug in Dimmer Options?
Added issue. ID: /udi/issues/34 We are likely a few months out on Insteon feat implementations that did not previously exist in Admin Console.
what is the eisy-ui version?
Geolocation map issues
Yes, this is very possible as location changes may reset time/sunrise/sunset/etc
Changing multiple Hue bulbs' Colors in a Scene
FYI for others, this is now a know issue for Hue Branded bulbs, not for other Color bulbs. It is benign and can be ignored. Investigation ID: /udi/issues/33
Please open a ticket with your UUID for remote diagnotic.
EISY-UI time display discrepency
Likely time (count) drift in the browser only not on eisy itself, refresh should correct. Will test a fix for drift.
Nodes interface
Favorites is still a work in progress, variables and programs are still on our TODO list.
Try interview on the Main Node. If that does not work try recreating profiles. "http://<controller-ip>/rest/profiles/move/zmatter/zigbee?recreate=true"
Notifications wont start, nor reinstall
What was the permission issue? What Restore?
How to add old X10 devices to EISY-UI?
The underlying firmware has not changed, so not sure if it needs to be added first. I have never used x10, but did find one in inventory to test. Try adding from Admin Console then use from eisy-ui. https://forum.universal-devices.com/topic/47536-how-to-add-old-x10-devices-to-eisy-ui/#findComment-410377
No “paste” option when moving a device into a folder
I'm not sure, looks like the plugin in failing to create NodeDefs or they are not being uploaded. Check the plugin's log. I noticed that an invalid config paramters on another users's controller caused the plugin to behave the same way, if I remember it was the Pushover node name being too long. I would not post here if you have keys as they may be in the log. @Jimbo.Automates may have a better idea.
Two fixes for Hue support. #1) Fixed Hue Node Def, so setting variables in Programs will now work. IoX 6.1.2_17, may require Update with interview from Node > Right Click > Configuration Verify the Hue Node has NodeDef > Properties > editor ZB_HUE. From Node > Right Click > Node Info "properties": [ { "id": "ST", "editor": "ZB_HUE", "name": "Hue" }, e.g. #2 Fixed Scene Commands for Commands with only named parameters:IoX 6.1.2_17 Issuing Hue Commands from Scenes to all Hue Nodes will now work.
Critical Java Vulnerability Requires Immediate Patch
No Java in Portal. Android Applications use "Java"ish, they are built not run with Java which is different.
No Scenes in eisy-ui!
Sort from header. The KPL must have been added with a retain existing scenes, this is not recommend. It should be added by clearing all. Only users who have them connected to 2 controllers use this, and it will fail in some cases.
It is too late now as the last run is when it evaluated false. But you can see today's next scheduled for 5:27:15 Also, there is no need from from, an exact time of sunset is fine as there are no other conditions.
Scenes losing Hue bulbs
Early versions of plugin migration PG3x to eisy-ui-plugins deleted nodes so this would have been the cause of the first instance. This is now fixed.
