Posts
294 -
Joined
Last visited
Everything posted by randyth
HA integration broken after upgrade to IoX 5.9.1
randyth replied to MMAltair's topic in Home Assistant
That is very good to hear. -
I think it's likely that the OS update did do something to confuse/break HA's ISY integration. In Home Assistant, go to Settings->System->Logs and see if you can find any error messages related to the Universal Devices ISY/IoX integration. If you do find something, you can go here and start a New Issue to see if the author can fix it. -Randy -
Virtual Buttons aren't really switches or "toggles" -- they are push buttons. Technically, Alexa sees them as Doorbell Buttons which trigger Alexa Routines when pushed. Currently, Amazon does not let you trigger Alexa Routines with switches. If they ever do allow such things, we would be happy to offer Virtual Switches that trigger Alexa Routines based on their on/off state. Personally, I'm hoping they simply add a "Toggle Action" to Routines. This way, for example, you could toggle a light on/off with one Virtual Button. Unfortunately, this is not a feature we can add for them.
Nice!
This is a very interesting thread, and kudos to UDI for embracing those of us crazy enough to run multiple home automation systems. @Michel Kohanim Does this initial script install Home Assistant Supervised or Home Assistant Core?
To add detail to Javi's comment, here is an example of a program that turns on lights at 6am and then off at 8am: If From 6:00:00AM To 8:00:00AM (same day) Then Set 'Ambient Lights' On Else Set 'Ambient Lights' Off
For those of you using an Alexa with your home automation... Did you know that Amazon is tracking all the activity of the home automation devices you've exposed to Alexa whether or not it was Alexa that triggered that activity. This includes things like manually turning a light on or off, or having your ISY activate something on a schedule. To see your Alexa Smart Home History, try this link: https://www.amazon.com/alexa-privacy/apd/dsh?ref=activityHistory&locale=en-US If you click on Manage my smart home device history->Email history from that webpage, you can get a CSV file with the status and usage information Alexa has about smart home devices associated with your account. You will also receive access to a report with "helpful insights" about your use of smart home devices connected to Alexa. That's not creepy at all.
Support thread for: PG3x v3.1.33 (June 30, 2023)
randyth replied to bmercier's topic in Polyglot v3 (PG3x)
Initially, I had the same results as @TUhl01 and @glarsen. Then on a whim I logged out of PG3x and am now having the same issue as @Techman. -
New - Ring node server is now available in the PG3x store
randyth replied to Bumbershoot's topic in Ring
Ditto. Caught this pest on my back deck recently: -
Assuming you moved from an ISY994, I suspect your portal account is still trying to talk to this old hardware. If that is the issue, you should log into the portal, select the Add ISY button to add your Polisy, and then add all the devices you want exposed to Alexa to it (Polisy->Select tool->Connectivity->Amazon Echo). Better/more complete instructions can be found here: https://wiki.universal-devices.com/index.php?title=ISY_Portal_Migrate_configurations_to_a_new_ISY
Support thread for: PG3x 3.1.21 (January 23, 2023)
randyth replied to bpwwer's topic in Polyglot v3 (PG3x)
Just a guess, but I think this update is only available (or useful) for people with the new eisy device. -
@shbatm, thanks so much for starting work on this so quickly after I reported the issue.
- 5 replies
- zmatter
- home assistant
(and 1 more)
Tagged with:
I suspect that program always sets the RainDelay variable to 0 because every time the Then statement decrements the value it re-triggers the program (it starts back at the If). I think you are going to have to change RainDelay to a regular (Integer) variable to prevent the If block from re-triggering.
I'm a fan of the slightly spendy but very flexible Flic buttons. I have some that link directly with Alexa, some that call the ISY's REST API, and some that call my Shelly devices' REST API. They recognize press, double-press, triple-press, and long-press actions for four different operations per button. Again, very flexible. Here's a list of all the services they support out of the box: https://flic.io/all-functions Unlike Insteon's mini remote or Lutron's Pico, Flic buttons are just one single button.
Ditto. I did the same -- definitely easier for me this way.
PG3 Not Responding After Update Please Help!!!
randyth replied to btreinders's topic in Polyglot v3 (PG3x)
The updated version of PG3 does not like to talk to ISY on any port other than 8080, so it fails to launch. You should probably open a ticket with UDI to get instructions on how to reset your ISY port settings. Or, if you are adventurous, you can try this... sudo rm /var/isy/FILES/CONF/0.UCF Be warned, however, that this will clear your ISY's credentials, time zone, and SMTP settings along with resetting the port. -
Is this on Polisy and, if yes, did you change the port number of ISY on Polisy to be something other than 8080? -
Ordered!
I have a Smoke Bridge and successfully use the Status is On method. Smoke Alarm - [ID 0058][Parent 004A] If 'Alarms and Locks / Smoke Bridge-Smoke' Status is On Then Send Notification to 'myself' content 'Alarm Alert' Else - No Actions - (To add one, press 'Action') As you can see, I do not force a query because the alarm appears to clear itself after awhile (likely when the smoke alarm stops). @CPrince, have you verified that your Send Notification action is working by right clicking on the program in the AC and choosing Run Then?
Ah, good to know. It has been so long since I did this I couldn't remember the exact details. Glad you figured it out!
There is a way to "fix" this in the Administration Console: Right click on the node created by the Virtual NS and select Delete. Go to the menu Node Server->Virtual->Add Node and add the node back in. You should now be able to use ISY Portal->Connectivity->Amazon Echo to add this node to Alexa. NOTE: Step #2 can be tricky because you have to know the node's address and primary node address. To find this information, open PG3 and go to Dashboard->Virtual->Details->Nodes. There might be an easier way to do this, but not one I am aware of.
In a way, yes. While the ISY can't look through to HA's devices directly, you can make HA tell the ISY when something of interest happens. For example, I setup HA to trigger an ISY scene when my Ring doorbell senses motion. HA can also turn on/off any devices that your Insteon controls.
Ditto what MrBill said. In my case, I use HA to add Ring and Brilliant Dimmers (via HomeKit) to my setup. ISY still handles the majority of my automation logic, and has proven the more reliable. But, HA allows me to include a more diverse selection of home automation technologies. (Hopefully UDI will be able to support Ring via Polyglot again soon.)
After a tad bit of research, I found this old post from the HA forums regarding Hub (2245) vs. PLM (serial modem): The 2245 is not as reliable as the serial modem. In short, the 2245 only provides a Web interface to communicate with it so it has to be polled. The polling uses a “circular buffer” inside the 2245 that can overload, and even worse the 2245 itself can sometimes clear out before being read, so information can get lost.
For people who are fortunate enough to have a spare PLM and Insteon Hub, any opinions on whether one would be better than the other? For example, does the Hub have a stronger dual-band RF transceiver than the 2413S or 2413U?
