Everything posted by larryllix
Ecobee on PG3x - vacation status
It appears that vacation mode shows up in Climate Type as Smart1 and it's changes will not trigger through HomeKitHub. Changing the mode from Heat to Off or back triggers an update in the Vacation status though. Was this an intended style of operation or is this a bug to be fixed yet? (PG3x)
I have ecobee stat via HomeKitHub working now. How do I get Vacation status from the ecobee stat? I have monitored the Smart7 climate status and it doesn't change. However I did find the Smart1 Climate status changing and modified the configuration of smart2 to say "Vacation". It does report through in IoX and eisy-ui with that nomenclature. However, it will not trigger a program and does not come through without Querying the stat status. Smart7 node is labeled "Vacation" by default installation but would never function. Is there something I am missing here, or is getting Vacation status possible and coded for yet?
Latest eisy update crashes all plugins
Mine were all working fine and the offer came to delete the ones from the OLD system PG3x. It also deleted the nodes from IoX as well and they ceased to exist completely in programs and node lists.
All sounds familiar. I have restored my PG3x plug-ins and have hesitated to try again with eisy-ui. Nice I/F but caused too many problems. Now I am trying to install the HomeHubKit along with ecobee but it seems PG3x plug-ins are none existent will not even respond with a negative message. I am just about to just give up. IoX spews a lot of garbage messages to be cleared, on the screen now, every boot-up. Nonsense messages about new Insteon devices and old events, repeated several times. Very frustrating.
Others, including myself, and @oberkc have had some problems with eisy-ui plug-ins deleting PG3x plug-ins from IoX completely. Still some migration bugs there.
Plugin Migration
My three plug-ins were working fine with them installed in both places. The trouble only started when I agreed to delete them from PG3x.
Plugin Migration
Same thing happened here. I have since deleted the eisy-ui plug-ins and re-installed them back in PG3x. Of course all programs involved with these devices had to be updated (with fake edits) and re-saved to make them function again.
Daylight Savings Time
West of Thunder Bay was always Central Time along with Manitoba but still switched back to standard. An example of being past the logical time zone boundary..... Neighbours, previously from Thunder Bay, complained about putting the kids to bed at 10:00 PM while the sun was still shining on their beds.
This will be coming to Ontario some year soon. Applied and approved in 2020 but some board is waiting for Quebec and NY to co-operate also.
Feedback on new web based UI
I like colour for On and Off devices and possible Lighter green for partially ON (1-99%) but don't want to see 15 different colours for temperatures, and other analogue things. Too much becomes a garden of visual nonsense. Alarms needs their own colours and that demands a plain background, again, so they don't disappear in a sea of colours. Of course there are blinking colours for alarm levels too.
End of IoX?
Looks like it came back. My polisy is a mess now and needs PG3 nodes re-installs along with refreshing programs to use the rebuilt labels. I've had worse but this is annoying to have to recheck every node parameter. Thanks to whomever fixed it.
Ryse Shade Migration Issues
Eisy-ui told me all nodes were migrated and asked m if I wanted to remove my PG3 nodes. When I replied YES, all nodes ceased to function and ALL NODES WERE REMOVED from my polisy. None would function from eisy-ui. When I reinstalled RYSE, and others, nodes were generically installed again but no programs function. I have been busy renaming nodes and update jerking programs to use them again. Basically starting from scratch except dead programs still exist but do not activate any restored node. BTW: after saving each program (after a useless edit) eisy-ui complained about not saving the update each time I attempted to exit (it was). I had to click "Discard" each time to proceed.
End of IoX?
End of IoX?
Ecobee setup
I tried power cycling the ecobee stat and the got the same...no response
Ecobee setup
Thanks. 1,2 done, 3 skipped. 4 results in no feedback whatsoever. Am I missing something? Does the system jumping back and forth from PG3x to PG3 matter? I get a page wanting me to migrate to PG3 or back. Also, how would I tell if my ecobee is already paired to something? I have no Apple devices. Log always shows this file missing despite many UPGRADE PACKAGES completed. 2026-10-18 18:11:32.906 MainThread udi_interface ERROR udi_interface:write: import aiomqtt 2026-10-18 18:11:32.907 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError
Ecobee setup
Thanks but that takes me around in circles again. I cannot Discover anything. Reading the github webpages referes me to other github pages that refer me to more github xxx.MD pages. I am lost. HomeKitHub node always shows "NOT CONNECTED" I have tried about 5 different ecobee PINS now but I am not finding any title for the PIN. I have been using "hap_pin"
Ecobee setup
Does this Plug-in install into PG3x or PG3? Every time I see the Home screen it shows me random versions, so I am not sure if this is a problem or why there are two versions showing up. I have been reading github files for hours but nothing seems to work or apply. I have been trying to re-install, and restart the HomeKitHub many times and no ecobee stat shows up in a list. I have never seen a list, empty or otherwise. My ecobee shows a small QR code with an 8 digit number but no connection has ever been made, to my knowledge. HomeKitHub only ever shows CURRENT STATUS: "Disconnectd" in red. I is not clear where it is not connected, ISY or the Stat.
Bye bye admin console polisy implications?
That is the 64 GB, fully captured by the polisy system.
I'm obviously not understanding this sector usage chart on my polisy but some things just don't seem to add up to 32GB being full. ---------------------------------------------------------------------------------------- [admin@polisy ~]$ df Filesystem 1K-blocks Used Avail Capacity Mounted on zudi/ROOT/default 60295013 4666919 55628093 8% / devfs 1 0 1 0% /dev procfs 8 0 8 0% /proc zudi/tmp 55628128 35 55628093 0% /tmp zudi/usr/home 55628183 90 55628093 0% /usr/home zudi/var/polyglot 10485760 55429 10430330 1% /var/polyglot zudi/var/isy 10485760 56322 10429437 1% /var/isy zudi/var/log 55628710 616 55628093 0% /var/log zudi 55628117 24 55628093 0% /zudi zudi/var/tmp 55628117 24 55628093 0% /var/tmp zudi/var/empty 55628117 24 55628093 0% /var/empty zudi/var/db 55629372 1279 55628093 0% /var/db zudi/var/run 55628142 48 55628093 0% /var/run zudi/var/crash 55628117 24 55628093 0% /var/crash zudi/var/db/pkg 55663864 35770 55628093 0% /var/db/pkg
Thanks but ll seems to be working now with the method I used. It doesn't seem to make sense I am using 32GB of SSD with this system though. Others didn't need the extra room, apparently.
I found info on expanding your freeBSD SSD drive partitions and so far...it seems totally successful. It took some nerves and some guessing at system naming but I got through it. https://kb.royalehosting.net/en/article/how-to-resize-a-freebsd-partition-eu4wlu/#2-3-resize-the-partition The last line needs to use "zudi" instead of the "zpool" as listed. The line number 5 referred to was line 3 in my system. I think I had to reboot my polisy when done as eisy-ui seemed a bit of a mess. Took a while to come back without insanity. Things are much better. Lines are still little too fat vertically but much, much better. From what I can remember now, those boxes can never be filled out to the edges in HTML code. Nice going @Javi (pat on the back)
I just realised that imagers require an image, not a file backup. Can the imagers produce an image from and existing HDD? I gave up on Rufus last time. It didn't appear to be able to handle and image larger than 2 or 16 GB. I d/l another program (diskimager) and it worked just fine. There still must be something wrong with 32 GB used up on this system. There has to be tonnes of spare space left, somewhere. Even the df counts don't add up to the totals. Three main folders show about 55MB each and a few others show 1-2MB each. I can't account for more than about 250 MB (0.25 GB). ????? Did you get your eisy-ui into your 32GB partition?
Geeesh. I am totally about 250K x 1K blocked used but my df total shows about 5,500K x 1K blocks on the drive. Somebody has been stealing my sectors!!!! There must be a sector compaction command on freeBSD..maybe somewhat dangerous for a running system though. I suspect the hardware in polisy may not handle more sectors than 32 GB of space.....eeeew, dread the thought. Maybe I ordered too many pizzas on my polisy?
Thanks so much Guy. I found the amazon order for 64GB. Seems I bought two? I have a spare polisy though, The df command shows about 25 MByte x 1K sectors SSD and it is about 98% full. I hope this is easily re-allocated to one drive....ewww, Is there an easy way? Perhaps there is some clean-up on isle two that can be done? ie: is there multiple images of old polyglots or ISYs just taking up unemployed space?
