Everything posted by jtara92101
Has a Date Been Set?
We don’t know when the picture was taken, and of course I was curious and I noticed there is a lot of office space for lease in the area - at least when photos were taken. I infer from addresses that UDI’s suite is in the back of the building somewhere. Was there any update on the impact of fires on company operations? The major ones are just now 100% contained. Still looking for that miracle turning water into wine. However: turns out the Army Corps of Engineers uselessly and wastefully diverted water from N. California to the inland “bread basket” area on the east side of the mountains, and there are concerns about available water for crops this summer. Maybe employees are all going out snapping up the last available chest freezers? I put one in my Michigan basement a month ago, snappy new WiFi model from Home Depot that was on sale end of the year. Made in China, of course. Boy am I glad I did. From power measurements the thing might even have an unadvertised inverter, or at least somehow variable compressor. Gonna go grab the last of that Canadian beef before it stops coming over the bridge. All in jest and satire - sort of - but also pointing out that the LA area is particularly affected by recent natural and unnatural phenomena, so cut them some slack.
Midnight drop? Or Midnight pity party? No wine before its time? Or no wine? We need divine intervention. Encino surely has water by now. The big guy turned on the tap!
Hue Hub Connected But No Hue Bulbs Added to System
I'm facing a similar issue, and having trouble following this. What's different is that from a few days ago, I'm suddenly unable to affect the state of bulbs from the AC. (Or from linked Insteon buttons, which is how I discovered this...) I got notices in the log about groups and bulbs not existing. And also a Python error with traceback. (wish I'd saved that...) I decided to re-install the Hue plugin, and I installed on a different slot, because of tips here. Now I'm in the condition where PG sees the bridge, and the bridge is connected. I can't get it to populate the bulbs. Hub button, restart, still only shows 1 node, the bridge. As with OP, I got no request to push the button (when I tried it without pushing the button first). I did add the hub IP address, though it works (such as it is) either way. A really detailed how-to would be useful, vs. the very terse comments in the README.
I assume there will be an announcement in the slow-moving “announcements” section. The app has had graphing for a while - you have to enable it on eISY with a secret incantation I don’t remember off-hand. I don’t have much I can graph, though I have an Ecobee and sensors and it indeed makes graphs. And oh ah say, ah say Paul - I just realized we’re neighbors. Hello from Lathrup Village!
Ecobee PIN issue
Same thing here. Documentation is vague. On first start, I will "receive a PIN". Where/how?
IoX Finder on MacOS, click on URL is hinkey
When I start IoX Finder on MacOS (Sonoma 14.1.2), I have great difficulty clicking on the URL to open the console or Polyglot. I have to try several times, sometimes it highlights the URL, sometimes it brings up the menu, sometimes it brings up the menu and then the menu disappears. I usually have to close IoX Finder and re-open several times before it randomly works. What's the secret handshake?
WIZ Integration
I'm gonna take a stab at it, as a long-delayed introduction to developing Polyglot plugins. I have mostly Hue bulbs, but I could not bring myself to pay the price ($54 each!) for 5 1.5W Hue "candle" bulbs in a dining room chandelier. (PLUS I'd have to use socket adapters, as my chandelier has standard E26 bases, and the available white+color candle-shape Hue bulbs have E12 base.) Naw dawg, not $270 to light a chandelier! So, I got a bunch of Hue and 5 Wiz bulbs. When I got them, I did a bit of digging, and demonstrated I was able to control them easily using Curl from a command-line window in MacOS. Shouldn't be very difficult.
Documentation link needs to be updated - and a note on elevation
The documentation/"more info" link in the Polyglot 3x store page doesn't work. "Not found". https://github.com/UniversalDevicesInc-PG3/udi-sun-poly/master/blob/README.md If I push that button (MacOS/FirefoxPolyglot V3 via I0X Finder) it takes me to the above link and I get "not found". I found the following in a topic on this forum: https://github.com/UniversalDevicesInc-PG3/udi-sun-poly/blob/master/README.md This link works. Took me a minute to spot the difference: the correct link reads blob/master while the incorrect link reads master/blob. I had some trouble figuring out the format of the parameters. I fiddled around and finally got the format for latitude and longitude, and now I get values. Still unsure about height. Feet or meters? That's not in the documentation. But at least now I can find the Github repo and read the code to figure it out. Edit: answer - the poly uses astral.geocoder. https://astral.readthedocs.io/en/latest/ There's a note in the documentation: And then I found this about Astral.Observer: A float that is the elevation in metres above a location, if the nearest obscuring feature is the horizon
WIZ Integration
Wiz has completely replaced Hue in some and much diminished in others big box stores. E.g. Target sells Wiz but not Hue. Home Depot has reduced Hue to the bottom shelf of an end cap, the rest of the end cap being Wiz products. And you can buy Wiz in supermarkets.
eISY OpenADR production certificate
Thanks, Michael. Good to know it's just a software entitlement/download. I found this: https://www.dteenergy.com/us/en/insight/insight-features.html Energy Bridge is a ZigBee dongle that provides real-time data directly from the meter. I'll check with DTE to see if I'm eligible. Can eISY talk to the bridge? OpenADR is for this, or for talking to an Internet API? Looks like they are using this (Powerley) bridge currently. And I came across threads talking about connecting to it with Home Assistant. So, assume I'll be able to talk to it once I get one. https://csa-iot.org/csa_product/energy-bridge-2/ There's a reasonable $1.99/mo subscription fee. Thinking this has nothing to do with OpenADR - which is a separate concern, right?
I'd like to better understand the add-on OpenADR Production Certificate. I've moved to a new (old) home, and want to order an eISY as a replacement for my existing ISY994i and Polisy. (As well, I've a developer, and interested in what I can do in the super-niche area of steam heat... perhaps some AI to model house heat gain/loss, see if there's some way to optimize use of a steam heating system in conjunction with a heat pump (currently, no A/C, heat pump might be more economical just to "take the chill out" in spring/fall), remote-adjustable air valves, etc. My electric utility just started TOU billing so interested in high-level management of loads). Anyway, I've got a meter that I'm unsure if I can read with eISY, will get to that in a sec. My main concern is, I want to get the eISY ordered, and uncertain exactly what to order. Is eisy | OpenADR just eisy with a production certificate? Is OpenADR capability able to be added later by adding a production certificate? Is any add-on hardware needed to communicate with a meter? I notice there's a (small) discount ordering eisy | OpenADR vs adding certificate later, though that's not a big concern. Maybe somebody can comment on my meter, while we're at it: OpenWay by Itron, Centron. CL200 240V 3W TYPE C2S0D 30TA 1 OKh, dated 9/11 FCC ID 5K9AMI5JC-AMI6, MODULE: AMI6 Utility is DTE (Michigan). Does the utility have to do something, or do I have to get some code or certificate or something from them? Anything needed to add to this? Advisable to wait for ZMater USB to be out of beta? I've got a ton of Insteon, some of which I will use, some Hue bulbs and strips, a little bit of Wiz, want to explore WLED. a few Sonoff S31 that I haven't flashed yet that I've been using to measure critical and constant loads (generator or battery still a necessity in the offing, welcome to Michigan!)
Insteon leak sensor for pure water?
Haha, so you want to know if your R/O system leaks. Must be RO/DI. I get about 15ppm out of the RO (with permeate pump) and 1ppm after two stages of DI. Then re-mineralization cartridge to the little faucet and fridge. I have a valve and tube I can use to draw DI water for mixing up household cleaning solution, plants, etc. It's suitable for a reef tank (which I don't have, no fishies in my high-rise condo, no thank you) and in fact I purchased from a company that specializes in that use. (Reef tanks and saltwater aquariums best practice is go as close to 0 as possible, then add suitable minerals. I actually know somebody who has a business maintaining reef tanks. He was on an episode of Tanked!)
querry
Also, check for loose/missing connections! I had until recently persistent problems communicating between the PLM and one particular room, and in particular the SwitchLinc at the entrance to that room. (master bedroom) I was focused on my electrical system (unconventional for residential 3-phase system, where every other apartment is on two alternating legs of a 3-phase system, providing anomalies including the two legs not being 180 degrees out of phase with each other, and 208-volt appliance outlets...) as well as noise from my computers and "honking" UPS. (PLM is near the computers/UPS). I've tried all sorts of things, the most promising was running a long extension cord to the master bedroom to plug-in the PLM. Well, I recently move an OutletLinc from the master bedroom to entrance hallway, because I no longer needed it after updating to 5.x and Polyglot (on Polisy) and was able to install Hue bulbs in bedside lamps and integrate with the SwitchLinc and so no longer needed the OutletLinc. So, I wanted to move the OutletLinc to the hallway for a neater installation than the 2-pin dimmer that was there. (Outlet vs plug-in dongle). When I removed the OutletLinc, I noticed that one of the wires was loose or perhaps not connected at all. I *think* it was the neutral. But not sure how that OutletLinc even worked if there was no neutral connected. In any case, it was AT LEAST loose, and then perhaps was creating noise. After swapping the BR OutletLinc with the conventional outlet in the hall, no more communication problems! PLM no longer has any trouble communicating with the MBR devices, and it's plugged in right next to the computer (no long extension cord). I had checked and re-check the SwitchLinc wiring, thinking if there was a wiring problem, it MUST be there. Check ALL the outlet/switch wiring to make sure it is snug!
Not quite there with UDI Moble
I gather UDI Mobile was never released for iOS, just some beta testing that didn't go so great? For iOS, geofencing can/should be centrally managed by the OS. Applications register for notifications, and get notified based on their chosen criteria. e.g. notify me every n seconds, every n feet or miles, or upon crossing a boundry. Apps wake up momentarily when they are notified, they are expected to handle the notification and then return. If the app was sleeping, it goes back to sleep. iOS is careful to use the fewest resources needed to satisfy the aggregate needs of apps that register for geolocation notifications. Android I am less familiar with, I can't imagine it is different! But if most/all of the Android geofencing apps have a power management problem, perhaps Android has done dealt with this as well as iOS. I write apps using a cross-platform framework. (Rhodes/Rhomobile). The framework exposes almost all device capabilities using common interfaces. So, I write once, only very occasionally writing "native extensions". (This doesn't need one.) UI is in a WebView using HTML/CSS/JS so quick to throw together a UI. MVC is in Ruby, it is very similar environment to Ruby on Rails server with browser. (The "server" is in the app.) Contrary to popular belief, there are no performance issues vs "native" code. I've incorporated geolocation in a couple of apps for clients, but haven't had a need for geofencing. And I did a native iOS taximeter, but would never go native today. Too much low-level work and too much to learn for two platforms! So, will be interesting to see if it turns out the Android battery performance sucks...
Yea, we cross-posted. I just discovered that, would never have found it without actually setting up a geofence and device. Oh, no IFTTT needed can do it just in Locative? I guess I needed IFTTT previously (haven't had any kind of occupancy set up for a while) in order to set a variable on the ISY so had to have ISY/IFTTT integration set up and then could use IFTTT to set the variable. There are some bells/whistles obviously with the short code generation and communication of the uuid I will look into. I've got a better way yet. Would have to convince UDI to display a QR code in the portal. Already have the app for that. cut/paste exercise.
Oh, geez, OK, I just now got the bright idea to click on the "Help" button! (In my defense, I would have never seen the Help button had I not just been curious enough to set up a geofence and device... I see there is a URL to hit when in, and when out. So, sure easy enough to set up with Locative and IFTTT. But for the unwashed public, would be better if it "just works" without having to involve IFTTT and typing of URLs. I'm just going to go ahead and write the app. Piece of pie. For starters, will need to type in uuid, which is painful but proof of concept. Assume there is a bit more to the API than the in/out. Is the API public? If not, I will check with Michael.
Unclear from those links how I would integrate specifically with Occupancy 2.0. I must be missing something here... I already set a home/away variable locally using Locative and IFTTT. But that's not the same as Occupancy 2.0. Guessing here... if I install Occupancy 2.0, then I will get some inputs/outputs that I can use in a Program? So, the I can use Locative (or whatever) to set home/away and/or some more specific value(s) like distance? I did set up Occupancy 2.0 once. I will do so again and poke around a bit more.
Support Thread: 5.0.16C (ISY994)
Thanks. It's an odd UI. The 4.x sliders were more intuitive. "On" is odd wording for "level"! But I know it is difficult to come up with a term that will fit all contexts. Naming is the hardest problem in software development!
OutletLinc - Disable Load Sense?
Yes, the lights are dimmable. The fixtures are so old they have REAL transformers! I solved it by replacing one of the framing projector lamps with a 35W halogen. It's the largest poster, it needed more brightness anyway. Yea, that one wall washer is WAY too close to the fire sprinkler! It has a small LED "cornrow" in it though. Not the 100W halogen it was made for! Looking for higher wattage bayonet base cornrows. Mostly they lie about the wattage...
Probably 30W at full brightness, plus transformer losses. Ancient Lightolier track with 3 framing projectors with big chunky transformer bases, probably have 5W LEDs, and two 110V wall washers with bayonet base bulbs, I think not more than 8W LEDs in the wall washers. I'm constantly on the lookout for higher wattage bayonet base LEDs they are hard to find. Probably should get conversion adapters to candelabra screw base - the fixtures have plenty of room. I actually want to light two more pictures with framing projectors. Will have to check storage locker to see if I have any more, don't think so. I may have one or two spots though that are convertable by adding the FP accessory. The wall washers are too close to a fire sprinkler, otherwise I could put halogens in them and get the brightness I want and solve the minimum wattage requirement. Maybe one halogen in a framing projector. I've probably over-done being green. Think I'll try that - I have one large movie poster that could use more brightness anyway. I think I have some Yushios somewhere. Bet I can get a couple of those Lightolier FPs on eBay cheap... XXXXX nope. Lightolier FPs are like hens teeth! I'll put a halogen in the FP for my big movie poster.
Dredging this up, because I have this problem with a track with just 4 low-wattage LEDs at my entrance plugged into a 2476D. The lights cycle. Actually, I had been using a 2457D2 and had this problem only if I raised brightness to 100%. I thought perhaps the 2472D might have less trouble, as it is newer. And, also, it's a neater installation of course. I didn't want to run in-wall wiring to the track, and is easily hidden by I really wasn't thinking about LoadSense... So, maybe for now I will go back to the 2457D2 (Edit: nope, it seems to have permanent load sense, the manual doesn't even mention it. I think they started to call it "Load Sense" when they started letting dimmer outlets act as as a controller?) The OutletLinc Dimmer manual says that Load Sense can be disabled using "software such as Houselinc" So, could ISY please do whatever HouseLinc does? Pretty please? Maybe if we figure out what HouseLinc does? --- I tried the tippy-tappy procedure above, the LED acted the same, but did not disable Load Sense. I guess the one above is a Euro model?
Is there a manual for 5.0.16c admin console? Alternately, can somebody explain the new device settings for dimmers? There now is: - On 0-100% - Beep 0-255 - On Level - Off - 100% - Ramp Rate 0.1 seconds - 9.0 minutes - Backlight - 0-100% I don't understand what "On" is. I might GUESS it is minimum level. But if I set it, then Write Changes, the turn ON and OFF, it goes back to 0%. On and Beep have a "disclosure arrow" and if you click it, it removes the widget for the value and says "click to specify". I don't understand by it always sways has Backlight. An OutletLinc (for example) has a backlight? So, this begs the question: is there a manual? I don't find this in the Wiki.
Is there currently anything else that works with Occupancy 2.0? I gather that UDI Mobile has the single purpose of implementing the geofencing on your phone in order to provide one of the inputs to Occupancy 2.0? Was it ever released for iOS? I can't find it, but I see the Android product. Are there other geofencing apps that work with Occupancy 2.0? I'm thinking like some 3rd party app of more general purpose, such as a full remote for ISY? So, basically, this is similar to Locative but talks directly to Occupancy 2.0? From discussion I have seen, there are issues with high background usage, and perhaps no iOS app at all? Sorry for all the clueless questions. I might be able to throw this together quickly if there is interest. I might want to charge a few bucks for the app for my trouble. I'd imagine it's a small market, but willing to give it a shot. There is no reason that geofencing needs to have an app run in background on either iOS or Android. The app gets notifications from the system, and briefly "wakes up" when criteria are met. "listening" for the fence boundaries is managed centrally by each of iOS and Android's central geolocation code. Exactly. That's how it is SUPPOSED to work. I've done this before. I wrote a little taximeter app a few years ago that I never released. Now... no taxis! And a couple other apps that deal with geo, one for home inspection for energy assessments and one for facilities maintenance technicians. So, pretty familiar with how this is SUPPOSED to work, and you are right on track.
Hmmm, don't have any yellow icons, and don't think I did before. I have some with green "frame", one with a red "frame", and most with no "frame". I have one that has the Then in blue. Is that a comment? I can't edit the Then. If $Away is not 0 Then Allow the programs in this folder to run. I only have a few programs. I can just replace all of them. I decided the blinky-blinky has nothing to do with programs. Its poor bridging, despite a good number of dual-band devices. Something to do to my 3-phase star/Wye wiring, I think. (You had another name for it). For reliable setup, I have to run an extension cord to the bedroom and put the PLM on the extension cord to get it on the other leg. Oh. Edit... LOL I don't need to run the extension cord to the other room or other leg. I just need the extension cord! OK, sure, I can just drop a long orange extension cord behind the server cabinet where it won't be seen... Is there some filter that will demonstrably help? It seems the long extension cord is a good enough filter. I rebuilt the PLM a couple years ago. I think I have more caps if need be. And another old PLM I could rebuild. But with quality caps I installed, shouldn't be necessary. (Going off topic here, but I know Larry knows a lot about this stuff.) The blinky-blinky I think is "I can't talk to the PLM".
Transitioned to 5.0.16C, my first 5.x. Went smoothly, and didn't lose anything, but... Some programs now apparently do not run and as well cannot be disabled. In Summary page, they all say: - Not Saved - ... under Activity. Might it help to delete and recreate the programs? Only thing I see in the log is a line like: Mon 05/18/2020 07:13:08 AM : [ Time] 07:13:15 2(0) Which is what I get on a disable that works. Also, I have a SwitchLinc that is set to run one of these programs on fast on, and one on fast off. Of course, the programs don't run. The ON and OFF button lights cycle on/off 8 times on a NORMAL on or off. (NOT fast on/off). Dunno if this is related. I think this may actually have been an issue before the transition. ---- Edit: I deleted/recreated two of the programs. (Bedroom All On, Bedroom All Off). Now they can be disabled/enabled and they run. Strangely, now NONE of the programs show - Not Saved - under Activity. It appears now that all can be enabled/disabled. I'd guess they all run now, will check later. Is this some bug with the upgrade from 4.x? Programs left if a modified but unsaved state?
