dbuss
  • Posts
    942
Everything posted by dbuss
  1. dbuss
    remove old Zwave
    Yes, you can.
  2. I had the same issues. A reboot resolved my issues. This is the first time I've experienced any issues with the time changes.
  3. Right-click on your desktop and click on "Display settings". Then, choose a resolution that allows you to view all the information in the admin console.
  4. I've changed the display resolution, so all the information is viewable.
  5. Right click on the device and select delete. This will delete the device from your eisy. The device would need to be factory reset before trying to include in a system. Sent from my SM-G998U using Tapatalk
  6. I'm sorry. I never checked for that.
  7. You may want to check the connection where the antenna cable connects to the board. I had similar problems and discovered that connection was the problem. The connector on the antenna cable was not making a good connection to the connector on the board.
  8. The best way to get programming help here is to post the program. You can right-click on the program in the admin console, click on copy to clipboard, and then paste it into a post here. Explain what you want the program to do. I'm sure you will get the help you need by doing this.
  9. The recommended way to remove/exclude a Z-wave device is the use the remove/exclude option on the admin console. Here's a link to the document that explains removing a Z-wave device. https://docs.universal-devices.com/production/zw.pdf If you use the removed failed device option as you have been doing, you should factory reset the device. Even though you removed the device from your eisy, it still has your eisy as its controller. Using the recommended method will remove the device from your eisy and remove your eisy from the device.
  10. Thank you!
  11. These will work for me. Thank you!
  12. I tried your suggestions with no change. I reinstalled the plug-in thn clicked on load profile before starting the admin console with no changes. I deleted the plugin and installed it in a different slot, then clicked on load profile before starting the admin console with no changes.
  13. I've just installed the Schlage plug-in, and it works very nicely. Thank you. The issue I'm having is setting the deadbolt's status in a program. I am given a list of my variables or a numerical choice. Is this correct? When setting the status of the battery in a program, it works as expected. I've attached screenshots below. Thank you!
  14. Mine do the same thing. Only one local will connect at a time.
  15. Yes, you add it manually. I have mine set at -1056.
  16. Once I corrected the operator error, it worked perfectly. Thank you, @bpwwer!
  17. I corrected it and will keep you posted. Thank you!
  18. 2024-02-04 13:13:12,179 Thread-54 udi_interface DEBUG noaa:query_alerts: request = https://alerts.weather.gov/cap/wwaatmget.php?x=WIZ048/WIC139&y=1 2024-02-04 13:13:12,179 Thread-54 udi_interface DEBUG noaa:query_alerts: request = https://alerts.weather.gov/cap/wwaatmget.php?x=WIZ048/WIC139&y=1
  19. We aren't under any weather alert at this time. The first line below indicates an invalid zone. I have been using WIZ048/WIC139, and I have been getting other alerts just fine. 2024-02-04 12:43:48,700 Command udi_interface DEBUG noaa:query_alerts: ? invalid zone 2024-02-04 12:43:48,700 Command udi_interface DEBUG noaa:query_alerts: Parse XML and set drivers 2024-02-04 12:43:48,701 Command udi_interface ERROR noaa:query_alerts: Weather alert update failure 2024-02-04 12:43:48,701 Command udi_interface ERROR noaa:query_alerts: not well-formed (invalid token): line 1, column 0
  20. @bpwwerHere's the debug log while we have a Dense Fog Advisory. 2024-02-04 06:03:18,153 Thread-4 udi_interface ERROR noaa:query_alerts: Weather alert update failure 2024-02-04 06:03:18,153 Thread-4 udi_interface ERROR noaa:query_alerts: not well-formed (invalid token): line 1, column 0
  21. The plugin shows nothing other than "None" in the admin console. I will definitely look at the log next time. Thank you!
  22. @bpwwerCan Dense Fog Advisory alerts be added to your plug-in? We've had several in the last few days and they aren't being presented in the plug-in. Thank you!
  23. Here's a screenshot of the information presented in the TimeData node.
  24. Was the 10 minute delay in geofence detecting you entering the geofence or was the 10 minute delay in the program triggering the lights after the geofence detected you entering the geofence? Sent from my SM-G998U using Tapatalk
  25. I've used this to do something similar to what you want to do. Program 1 Set a variable to 3 when you enter your geofence. If Chris has entered the geofence Then $Chris is home = 3 Else $Chris is home = 0 Program 2 Turns the lights on and sets $Chris is home = 1 should you want to use the $Chris is home = 1 for something else when you are home. If From Sunset To 11:00:00PM (same day and $Chris is home= 3 Then Set 'Front Entry / Front Porch Light / ZY 012 Front Porch Light' On Set 'Front Entry / Entryway light / Entry way overhead light 011' On Set 'Side Deck Lights / Side Deck Lights' On Set $Chris is home = 1 Else $Chris is home = 0
  • Create New...
