Everything posted by Mitch Mitchell
Cannot log into ISY Portal -- error 429
down here too - two portal accounts.
ZMatter antenna assembly?
I noticed this too -- there need to be some printed instructions about the antenna colors included. If its just silk screened on the board, folks who purchase the assembled version will never see those.
Homeseer and Eisay. Is there a future?
Something happened to mine, I reentered the credentials and it started working, no idea why that worked.
I'm seeing the same issue within the last few days, the last eisy device update date in HS is 6/10/2023 10:21:44 PM an the log is full of the following message:
core files worth reporting?
I found several network related issues that essentially gave the eisy no chance to work right so I doubt this was specifically an eisy problem. That reminds me, I need to close my support ticket.
Error in log which looks like mac address?
Bob I sent you a PM with a link to the log files -- too large to attach. Please let me know if you can access them or need any other information to diagnose. Thanks! Mitch
Here is a more up to date list from the homeassistant sources: https://github.com/home-assistant/core/blob/dev/homeassistant/components/ambient_station/sensor.py TYPE_24HOURRAININ = "24hourrainin" TYPE_AQI_PM25 = "aqi_pm25" TYPE_AQI_PM25_24H = "aqi_pm25_24h" TYPE_AQI_PM25_IN = "aqi_pm25_in" TYPE_AQI_PM25_IN_24H = "aqi_pm25_in_24h" TYPE_BAROMABSIN = "baromabsin" TYPE_BAROMRELIN = "baromrelin" TYPE_CO2 = "co2" TYPE_DAILYRAININ = "dailyrainin" TYPE_DEWPOINT = "dewPoint" TYPE_EVENTRAININ = "eventrainin" TYPE_FEELSLIKE = "feelsLike" TYPE_HOURLYRAININ = "hourlyrainin" TYPE_HUMIDITY = "humidity" TYPE_HUMIDITY1 = "humidity1" TYPE_HUMIDITY10 = "humidity10" TYPE_HUMIDITY2 = "humidity2" TYPE_HUMIDITY3 = "humidity3" TYPE_HUMIDITY4 = "humidity4" TYPE_HUMIDITY5 = "humidity5" TYPE_HUMIDITY6 = "humidity6" TYPE_HUMIDITY7 = "humidity7" TYPE_HUMIDITY8 = "humidity8" TYPE_HUMIDITY9 = "humidity9" TYPE_HUMIDITYIN = "humidityin" TYPE_LASTRAIN = "lastRain" TYPE_LIGHTNING_PER_DAY = "lightning_day" TYPE_LIGHTNING_PER_HOUR = "lightning_hour" TYPE_MAXDAILYGUST = "maxdailygust" TYPE_MONTHLYRAININ = "monthlyrainin" TYPE_PM25 = "pm25" TYPE_PM25_24H = "pm25_24h" TYPE_PM25_IN = "pm25_in" TYPE_PM25_IN_24H = "pm25_in_24h" TYPE_SOILHUM1 = "soilhum1" TYPE_SOILHUM10 = "soilhum10" TYPE_SOILHUM2 = "soilhum2" TYPE_SOILHUM3 = "soilhum3" TYPE_SOILHUM4 = "soilhum4" TYPE_SOILHUM5 = "soilhum5" TYPE_SOILHUM6 = "soilhum6" TYPE_SOILHUM7 = "soilhum7" TYPE_SOILHUM8 = "soilhum8" TYPE_SOILHUM9 = "soilhum9" TYPE_SOILTEMP1F = "soiltemp1f" TYPE_SOILTEMP10F = "soiltemp10f" TYPE_SOILTEMP2F = "soiltemp2f" TYPE_SOILTEMP3F = "soiltemp3f" TYPE_SOILTEMP4F = "soiltemp4f" TYPE_SOILTEMP5F = "soiltemp5f" TYPE_SOILTEMP6F = "soiltemp6f" TYPE_SOILTEMP7F = "soiltemp7f" TYPE_SOILTEMP8F = "soiltemp8f" TYPE_SOILTEMP9F = "soiltemp9f" TYPE_TEMP10F = "temp10f" TYPE_TEMP1F = "temp1f" TYPE_TEMP2F = "temp2f" TYPE_TEMP3F = "temp3f" TYPE_TEMP4F = "temp4f" TYPE_TEMP5F = "temp5f" TYPE_TEMP6F = "temp6f" TYPE_TEMP7F = "temp7f" TYPE_TEMP8F = "temp8f" TYPE_TEMP9F = "temp9f" TYPE_TEMPF = "tempf" TYPE_TEMPINF = "tempinf" TYPE_TOTALRAININ = "totalrainin" TYPE_UV = "uv" TYPE_WEEKLYRAININ = "weeklyrainin" TYPE_WINDDIR = "winddir" TYPE_WINDDIR_AVG10M = "winddir_avg10m" TYPE_WINDDIR_AVG2M = "winddir_avg2m" TYPE_WINDGUSTDIR = "windgustdir" TYPE_WINDGUSTMPH = "windgustmph" TYPE_WINDSPDMPH_AVG10M = "windspdmph_avg10m" TYPE_WINDSPDMPH_AVG2M = "windspdmph_avg2m" TYPE_WINDSPEEDMPH = "windspeedmph" TYPE_YEARLYRAININ = "yearlyrainin"
I think the limit of 4 soil moisture sensors is out dated as they can support 8 I believe.
Here are all the field names possible in the data: https://github.com/ambient-weather/api-docs/wiki/Device-Data-Specs This lists all the parameters that a device might send. Note: Not all devices send all the parameters. winddir - instantaneous wind direction, 0-360º windspeedmph - instantaneous wind speed, mph windgustmph - max wind speed in the last 10 minutes, mph maxdailygust - Maximum wind speed in last day, mph windgustdir - Wind direction at which the wind gust occurred, 0-360º windspdmph_avg2m - Average wind speed, 2 minute average, mph winddir_avg2m - Average wind direction, 2 minute average, mph windspdmph_avg10m - Average wind speed, 10 minute average, mph winddir_avg10m - Average wind direction, 10 minute average, 0-360º humidity - Outdoor Humidity, 0-100% humidity1...humidity10 - humidity 1...10, 0-100% humidityin - Indoor Humidity, 0-100% tempf - Outdoor Temperature, ºF temp1f...temp10f - Temperature 1...10, ºF soiltemp1f...soiltemp10f - Temperature 1...10, ºF soilhum1...soilhum10 - Temperature 1...10, % leafwetness1...leafwetness8 - Leaf Wetness 1...8, Int, % soiltens1...soiltens4 - Soil Tension 1...4, Float, cb gdd - Growing Degree Days, Int, days etos - Evapotranspiration short, Float, in/day etrs - Evapotranspiration, tall, Float, in/day tempinf - Indoor Temperature, ºF leak1...leak4 - Leak Detection 1...4, 0=OK, 1=LEAK, 2=OFFLINEle battout - Outdoor Battery - OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) battin - Indoor Battery - OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) batt1...batt10 - OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) batt_25 - PM2.5 Air Quality Sensor Battery indication, OK/Low indication, Int, 1=OK, 0=Low (Meteobridge Users 1=Low, 0=OK) batt_lightning - Lightning Detector Battery - 1=Low 0=OK batleak1...batleak4 - Leak Detector Battery - 1=Low 0=OK battsm1...battsm4 - Soil Moisture Battery - 1=OK, 0=Low batt_co2 - CO2 battery - 1=OK, 0=Low batt_cellgateway - Cellular Gateway - 1=OK, 0=Low hourlyrainin - Hourly Rain Rate, in/hr dailyrainin - Daily Rain, in 24hourrainin - 24 Hour Rain, in weeklyrainin - Weekly Rain, in monthlyrainin - Monthly Rain, in yearlyrainin - Yearly Rain, in eventrainin - Event Rain, in totalrainin - Total Rain, in (since last factory reset) baromrelin - Relative Pressure, inHg baromabsin - Absolute Pressure, inHg uv - Ultra-Violet Radiation Index, integer on all devices EXCEPT WS-8478. solarradiation - Solar Radiation, W/m^2 co2 - CO2 Meter, ppm relay1...relay10 - Relay 1...10, 0 or 1 pm25 - PM2.5 Air Quality, Float, µg/m^3 pm25_24h - PM2.5 Air Quality 24 hour average, Float, µg/m^3 pm25_in - PM2.5 Air Quality, Indoor, Float, µg/m^3 pm25_in_24h - PM2.5 Air Quality 24 hour average, Indoor, Float, µg/m^3 pm25_in_aqin - PM2.5 Air Quality Sensor indoor, AQIN sensor, Float, µg/m^3 pm25_in_24h_aqin - PM2.5 Air Quality Sensor indoor, 24 hour running average, AQIN sensor, Float, µg/m^3 pm10_in_aqin - PM10 Air Quality Sensor, Float, µg/m^3 pm10_in_24h_aqin - PM10 Air Quality Sensor, 24 hour running average, Float, µg/m^3 co2_in_aqin - Indoor CO2 from AQIN, Int, ppm co2_in_24h_aqin - Indoor CO2 from AQIN, 24 hour running average, Int, ppm pm_in_temp_aqin - Indoor PM sensor temperature, Float, ºF pm_in_humidity_aqin - Indoor PM sensor humidity, Int, % aqi_pm25_aqin - AQI derived from PM25, AQIN sensor, Int aqi_pm25_24h_aqin - AQI derived from PM25 Indoor, 24 hour running average, AQIN sensor, Int aqi_pm10_aqin - AQI derived from PM10 Indoor, AQIN sensor, Int aqi_pm10_24h_aqin - AQI derived from PM10 Indoor, 24 hour running average, AQIN sensor, Int aqi_pm25 - AQI derived from PM25, Int aqi_pm25_24h - AQI derived from PM25, 24 hour running average, Int aqi_pm25_in - AQI derived from PM25 IN, Int aqi_pm25_in_24h - AQI derived from PM25 IN, 24 hour running average, Int lightning_day - Lightning strikes per day, int lightning_hour - Lightning strikes per hour, int lightning_time - Last strike time, Datetime lightning_distance - Distance of last lightning strike, Float, miles tz - IANA Time Zone, String dateutc - Datetime, int (milliseconds from 01-01-1970, rounded down to nearest minute on server) Server calculated fields: lastRain - Last time hourlyrainin > 0, date (calculated on server) dewPoint - Dew Point, ºF (calculated on server) feelsLike - if < 50ºF => Wind Chill, if > 68ºF => Heat Index (calculated on server) date - Human Readable Date, string (converted on server from dateutc) feelsLike1...feelsLike10 - feelsLike for sensors dewPoint1...dewPoint10 - dewPoint for sensors feelsLikein - Indoor Feels Like dewPointin = Indoor dew Point
we have the main kits plus 5 soil sensors, a few extra temp/hum sensors, and a ground temp sensor. I’ll get the list and see if I can tie it to the data as well.
Bob if you look at the JSON returned from the API I think the sensors will be clearer -- fyi there is an indoor and outdoor PM25 sensor so there are two (with different names) but I don't see the multiple battery issues in the data returned from ambientweather.net. [ { "macAddress": "E8:DB:84:E3:CA:4A", "lastData": { "dateutc": 1685851680000, "tempinf": 76.8, "battin": 1, "humidityin": 54, "baromrelin": 29.888, "baromabsin": 29.235, "tempf": 71.8, "battout": 1, "humidity": 77, "winddir": 180, "winddir_avg10m": 99, "windspeedmph": 0, "windspdmph_avg10m": 0, "windgustmph": 1.1, "maxdailygust": 12.5, "hourlyrainin": 0, "eventrainin": 0, "dailyrainin": 0.024, "weeklyrainin": 0.067, "monthlyrainin": 0.024, "yearlyrainin": 8.858, "lightning_day": 0, "lightning_time": 1675866562000, "lightning_distance": 24.85, "batt_lightning": 0, "solarradiation": 0, "uv": 0, "soilhum1": 13, "soilhum2": 4, "soilhum3": 11, "soilhum4": 3, "soilhum5": 11, "battsm1": 1, "battsm2": 1, "battsm3": 1, "battsm4": 1, "battsm5": "1", "temp1f": 84.9, "humidity1": 48, "temp2f": 77.7, "humidity2": 40, "temp4f": 84.4, "batt1": 1, "batt2": 1, "batt3": 1, "batt4": 1, "pm25": 6, "pm25_24h": 9.8, "aqi_pm25": 25, "aqi_pm25_24h": 41, "batt_25": 0, "pm25_in": 2, "pm25_in_24h": 2.5, "aqi_pm25_in": 8, "aqi_pm25_in_24h": 10, "batt_25in": 1, "batt_co2": 1, "feelsLike": 72.3, "dewPoint": 64.19, "feelsLike1": 85.8, "dewPoint1": 63, "feelsLike2": 77, "dewPoint2": 51.4, "feelsLikein": 76.7, "dewPointin": 58.9, "lastRain": "2023-06-03T23:43:00.000Z", "lightning_hour": 0, "tz": "America/Chicago", "date": "2023-06-04T04:08:00.000Z" }, "info": { "name": "Magnolia Manor Weather Station", "coords": { "coords": { "lon": -97.052743, "lat": 33.0110917 }, "address": "1616 Shadywood Ln, Flower Mound, TX 75028, USA", "location": "Flower Mound", "elevation": 177.010009765625, "geo": { "type": "Point", "coordinates": [ -97.052743, 33.0110917 ] }
Yep, I see a addnodedefs invalid entry: addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_1" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="WINDDIR" EDITOR="I_DEGREES"/> <st ID="GV6" EDITOR="I_DEGREES"/> <st ID="SPEED" EDITOR="I_SPEED"/> <st ID="GV7" EDITOR="I_SPEED"/> <st ID="GUST" EDITOR="I_SPEED"/> <st ID="GV5" EDITOR="I_SPEED"/> <st ID="RAINRT" EDITOR="I_RATE"/> <st ID="GV1" EDITOR="I_RAIN"/> <st ID="GV2" EDITOR="I_RAIN"/> <st ID="GV3" EDITOR="I_RAIN"/> <st ID="GV4" EDITOR="I_RAIN"/> <st ID="DISTANC" EDITOR="I_DISTANCE"/> <st ID="GV11" EDITOR="I_BATTERY"/> <st ID="SOLRAD" EDITOR="I_RADIATION"/> <st ID="UV" EDITOR="I_UV"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="GV9" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> that sure looks like the weather info Here is the whole log: Java Web Start 11.371.2.11 Using JRE version 1.8.0_371-b11 Java HotSpot(TM) Client VM JRE expiration date: 8/18/23 12:00 AM console.user.home = C:\Users\mitch ---------------------------------------------------- 😄 clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- Trace level set to 5: all ... completed.network: Cache entry not found [url: https://eisy.local:8443/admin.jnlp, version: null] network: Connecting https://eisy.local:8443/admin.jnlp with proxy=DIRECT network: Connecting socket://eisy.local:8443 with proxy=DIRECT https://eisy.local:8443/WEB/iox.jar https://eisy.local:8443/WEB/ce.jar https://eisy.local:8443/WEB/chart.jar network: Cache entry found [url: https://eisy.local:8443/WEB/iox.jar, version: null] cache: Adding MemoryCache entry: https://eisy.local:8443/WEB/iox.jar cache: Resource https://eisy.local:8443/WEB/iox.jar has future expires: Sat Jun 03 13:10:06 CDT 2023 update check skipped. cache: registerReference: com.sun.deploy.cache.MemoryCache$CachedResourceReference@26b5cd34: 1 addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_1" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="WINDDIR" EDITOR="I_DEGREES"/> <st ID="GV6" EDITOR="I_DEGREES"/> <st ID="SPEED" EDITOR="I_SPEED"/> <st ID="GV7" EDITOR="I_SPEED"/> <st ID="GUST" EDITOR="I_SPEED"/> <st ID="GV5" EDITOR="I_SPEED"/> <st ID="RAINRT" EDITOR="I_RATE"/> <st ID="GV1" EDITOR="I_RAIN"/> <st ID="GV2" EDITOR="I_RAIN"/> <st ID="GV3" EDITOR="I_RAIN"/> <st ID="GV4" EDITOR="I_RAIN"/> <st ID="DISTANC" EDITOR="I_DISTANCE"/> <st ID="GV11" EDITOR="I_BATTERY"/> <st ID="SOLRAD" EDITOR="I_RADIATION"/> <st ID="UV" EDITOR="I_UV"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="GV9" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [PM25] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_2" NLS="sensor"> <sts> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="BARPRES" EDITOR="I_PRESSURE"/> <st ID="ATMPRES" EDITOR="I_PRESSURE"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="PM25" EDITOR="I_PM25"/> <st ID="GV10" EDITOR="I_PM25"/> <st ID="GV8" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [PM25] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_3" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_4" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="CLIHUM" EDITOR="I_HUMIDITY"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="CLITEMP" EDITOR="I_TEMP"/> <st ID="DEWPT" EDITOR="I_TEMP"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_5" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) addNodeDefs invalid entry ----<nodeDef NODETYPE="139" ID="e8db84e3ca4a_6" NLS="sensor"> <sts> <st ID="BATLVL" EDITOR="I_BATTERY"/> <st ID="TEMPOUT" EDITOR="I_TEMP"/> <st ID="BATLVL" EDITOR="I_BATTERY"/> </sts> <cmds> <sends/> <accepts/> </cmds> </nodeDef> ---- java.lang.IllegalArgumentException: U7DriverControl dup param [BATLVL] at com.universaldevices.u7.U7DriverControl.fail(Unknown Source) at com.universaldevices.u7.U7DriverControl.<init>(Unknown Source) at com.universaldevices.u7.U7DriverControl.newStatus(Unknown Source) at com.universaldevices.u7.U7NodeDef.<init>(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.u7.U7NodeDefs.addNodeDefs(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.registerProfile(Unknown Source) at com.universaldevices.uxt.UXTProfileDownloader.loadAllProfiles(Unknown Source) at com.universaldevices.uxt.UXTNodeServerMgr.loadProfiles(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.prepareAuthenticatedSession(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.authenticate(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.onDeviceOnLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.onLine(Unknown Source) at com.universaldevices.upnp.UDControlPoint.updateDeviceInfo(Unknown Source) at com.universaldevices.upnp.UDControlPoint.addDevices(Unknown Source) at com.universaldevices.ui.UPnPClientApplet.start(Unknown Source) at com.universaldevices.ui.UDIDefaultLauncher$2.run(Unknown Source) Z-Wave event: control=[_25] action=[1.3] -- Extended Info -- <eventInfo> <zwave CBP="false" CONNECTED="false" RELAXDELAY="0" INTERVIEWTIMEOUT="0" SECUREINC="2" HOMEID="0" NODEID="0" RELAXDELAYDEFAULT="15"/> </eventInfo> -- Z-Wave event: control=[_25] action=[7.1] -- Extended Info -- <eventInfo> <options> <files ZMATTER="true"/> <dongle ZMATTER="false" ZWAVEOTHER="false"/> </options> </eventInfo> -- Z-Wave Backup Options: - zmatterFile= true - 500SeriesFile=false - zmatter connected=false - other connected=false network: Cache entry found [url: https://www.universal-devices.com/auto_update/updates_config, version: null] cache: Adding MemoryCache entry: https://www.universal-devices.com/auto_update/updates_config cache: Resource https://www.universal-devices.com/auto_update/updates_config has expired. network: Connecting https://www.universal-devices.com/auto_update/updates_config with proxy=DIRECT network: Connecting socket://www.universal-devices.com:443 with proxy=DIRECT network: ResponseCode for https://www.universal-devices.com/auto_update/updates_config : 304 network: Encoding for https://www.universal-devices.com/auto_update/updates_config : null network: Disconnect connection to https://www.universal-devices.com/auto_update/updates_config cache: registerReference: com.sun.deploy.cache.MemoryCache$CachedResourceReference@562a3ad4: 1 network: Cache entry found [url: https://www.universal-devices.com/auto_update/prod-updates.xml, version: null] cache: Adding MemoryCache entry: https://www.universal-devices.com/auto_update/prod-updates.xml cache: Resource https://www.universal-devices.com/auto_update/prod-updates.xml has expired. network: Connecting https://www.universal-devices.com/auto_update/prod-updates.xml with proxy=DIRECT network: ResponseCode for https://www.universal-devices.com/auto_update/prod-updates.xml : 304 network: Encoding for https://www.universal-devices.com/auto_update/prod-updates.xml : null network: Disconnect connection to https://www.universal-devices.com/auto_update/prod-updates.xml cache: registerReference: com.sun.deploy.cache.MemoryCache$CachedResourceReference@9ef316ba: 1 network: Cache entry not found [url: https://www.universal-devices.com/sales/modules/status?uuid=uuid:00:21:b9:02:64:1c, version: null] network: Connecting https://www.universal-devices.com/sales/modules/status?uuid=uuid:00:21:b9:02:64:1c with proxy=DIRECT cache: https://www.universal-devices.com/sales/modules/status?uuid=uuid:00:21:b9:02:64:1c is not cacheable. cache: MemoryCache: removed entry https://isy.universal-devices.com/launcher/udlogo.png cache: MemoryCache: removed entry https://isy.universal-devices.com/launcher/isy.jnlp
I agree the display issue is not the node server. The parsing error seems to have gone away (that was reported in the node server logs so it was not console related). Would deleting the isy devices created by the node server and having it recreate them be worth trying?
Well this is interesting, I see values showing up on UD Mobile but not the admin console, even using the cloud console.
It looks like the main and indoor sensors have updated now. Let me check again when I get home.
Yes, I have. Did you see anything in the PM I sent that might point to where to investigate next? I can pull logs from the FreeBSD file system if you know which ones I should grab.
I have a brand new eisy that I am configuring, and I have used ssh to access the FreeBSD system. I see several .core files that appear to have been created today. Are these worth reporting? I'm assuming this isn't normal.
I get the following (coordinates and address overwritten) [{"macAddress":"XX:XX:XX:XX:XX:XX","lastData":{"dateutc":1685666220000,"tempinf":76.8,"battin":1,"humidityin":55,"baromrelin":29.87,"baromabsin":29.218,"tempf":85.8,"battout":1,"humidity":52,"winddir":270,"winddir_avg10m":263,"windspeedmph":0,"windspdmph_avg10m":0,"windgustmph":0,"maxdailygust":7.6,"hourlyrainin":0,"eventrainin":0,"dailyrainin":0,"weeklyrainin":0.043,"monthlyrainin":0,"yearlyrainin":8.835,"lightning_day":0,"lightning_time":1675866562000,"lightning_distance":24.85,"batt_lightning":0,"solarradiation":12.23,"uv":0,"soilhum1":18,"soilhum2":8,"soilhum3":21,"soilhum4":6,"soilhum5":24,"battsm1":1,"battsm2":1,"battsm3":1,"battsm4":1,"battsm5":"1","temp1f":86,"humidity1":50,"temp2f":93.7,"humidity2":33,"temp4f":82.9,"batt1":1,"batt2":1,"batt3":1,"batt4":1,"pm25":16,"pm25_24h":11.1,"aqi_pm25":59,"aqi_pm25_24h":46,"batt_25":0,"pm25_in":7,"pm25_in_24h":3.4,"aqi_pm25_in":29,"aqi_pm25_in_24h":14,"batt_25in":1,"batt_co2":1,"feelsLike":88.16,"dewPoint":66.11,"feelsLike1":87.9,"dewPoint1":65.2,"feelsLike2":93.6,"dewPoint2":60.2,"feelsLikein":76.8,"dewPointin":59.4,"lastRain":"2023-05-28T22:10:00.000Z","lightning_hour":0,"tz":"America/Chicago","date":"2023-06-02T00:37:00.000Z"},"info":{"name":"Magnolia Manor Weather Station","coords":{"coords":{"lon":-NN.NNNNNNN,"lat":NN.NNNNNNN},"address":"NNNN Street Ln, Flower Mound, TX 75028, USA","location":"Flower Mound","elevation":177.010009765625,"geo":{"type":"Point","coordinates":[-NN.NNNNNN,NN.NNNNNNN]}}}}] Now I get populated information for about 8 nodes on Polyglot but the devices in Isy show only "low" for one field:
I have a new Eisy/PG3X installation and when I added the AmbientWeather node server, configured it with the API Key, I get the following parse error in the log and no devices populated in the IoX:
Scheduled programs failed to run
I had a program set to run at sunset that hasn't run at least since the time change -- this on an ISY994. The clock on the ISY is correct.
Controlling a Honeywell Damper with an IOLinc
You can easily control the unit by attaching a switch or relay to the remote connections and setting the units switch to "off" - e.g. vent only when the remote switch is closed. No need to worry about power or anything else. I have my Alexa controlling mine via the ISY.
New house, more choices.
Z-Wave motion sensor to Insteon lighting is slow because a round trip to the Z-Wave controller (ISY) is needed to send out a scene command -- Insteon goes directly.
I think the question of Z-Wave vs. Insteon becomes moot with the dual band Insteon devices -- that's all we have now, powerline only is gone. The Insteon wireless network does not come with the management headaches of a Z-Wave network. We have Z-Wave locks and some other small devices but I would go with Insteon dual band over again if we ever moved.
MS II behavior
With my programs, the light doesn't go out if there is motion - but if you've got it working with simpler code, please post your programs as I am always looking for better algorithms! Sent from my SM-N950U using Tapatalk
MS II behavior
I think I captured all the programs here. Note that the condition on the Actions folder keeps the light from switching off if under manual control. I don't have anything special set up to restart the timer. Sorry, I originally grabbed the options tab from the old sensor.
