cap60552 Posted February 22, 2013 Posted February 22, 2013 When I attempt to generate a self signed key I receive an exception: java.security.ProviderException: java.security.NoSuchAlgorithmException: SunTlsKeyMaterial KeyGenerator not available Attempts to create a Cert request succeed up until the point I click OK after receiving the signing request. Then I receive a dialog box with an exclamation point, followed by: "/CONF/ISYKS.SRV" I am running Version 3.3.10 on an ISY 994i Pro. Any help would be greatly appreciated
Michel Kohanim Posted February 22, 2013 Posted February 22, 2013 Hello Mr. Wohler, Three questions: 1. Are you using Java 1.7.13? 2. Are you using the dashboard? 3. Did you accept the security warning when downloading the dashboard? With kind regards, Michel
cap60552 Posted February 22, 2013 Author Posted February 22, 2013 Quote Three questions:1. Are you using Java 1.7.13? 2. Are you using the dashboard? 3. Did you accept the security warning when downloading the dashboard? 1. Java (Version 7 Update 15). 2. Yup, I followed the steps in the PDF 3. I did.
cap60552 Posted February 22, 2013 Author Posted February 22, 2013 I managed to get the CA certificates and the Server certificate uploaded into the ISY using dashboard and a different local computer. They display in the dashboard via the correct buttons however when I connect to the SSL port of the ISY I am still showing the old certificate in the browser and not my new one. This persists even after a reboot. Any suggestions?
Michel Kohanim Posted February 23, 2013 Posted February 23, 2013 Hello Mr. John Wohlers, I know you had a ticket with us. Is this resolved? With kind regards, Michel
cap60552 Posted February 25, 2013 Author Posted February 25, 2013 No, I have not been able to resolve this. I also do not have a ticket open, I thought that I would try the forums first since I assumed it was just something I was probably doing wrong and I might get answers from the community rather than bother official support.
Michel Kohanim Posted February 25, 2013 Posted February 25, 2013 Mr. Wohlers, Thank you. I think it would be more expeditious if you submitted a ticket. With kind regards, Michel
