One button, two scenes?
Hi Guys;
I'm hoping to be able to have one button on my remotelinc trigger two scenes.
I want it to go something like this.
(for the sake of argument, i'll use the B button, and the B button triggers the SCENES A and B)
If SCENE A is true, and button B is SWITCHED ON
then SCENE B
I would like to be able to toggle between them. so
if SCENE B is true, and button B on SWITCHED ON
then SCENE A
and so forth.
Is this possible?
Drew
What if both are False?
By your logic, If A OR B, then turn on Both.
Could it then start with;
If SCENE A OR B are OFF then Button B turns SCENE A ON
There is no such thing as a scene status.
If you could identify a representative device from each scene, you may be able to try something like:
Status of representative device from scene A is off
And status of representative device from scene B is off
And control button B is switched on
Turn on scene A
Else...nothing
You will not be able to use any wait statements, nore anything in the else path.
I am a little like garyfunk in being unclear what you are trying to do.
The way I understood the request is:
If Neither Scene is on, Turn Scene A on.
If Scene A is On, Turn Scene A Off, Turn Scene B On
If Scene B is On, Turn Scene B Off, Turn Scene A On
Continued presses of RL-B toggle between the two scenes.
I would do this with a variable for tracking assumed scene status. I am assuming from the OP that the RL buttons are in NonToggle ON mode. RL-B SHOULD NOT BE a controler of either scene.
  Control RL-B is switched On
  and
  i.scenestat < 2
then
  Set Scene B Off
  Set Scene A On
  i.scenestat=2
else
  Set Scene A Off
  Set Scene B On
  i.scenestat=1
Assuming that there would be another button used to turn off the scenes.
  Control RL-A is Switched On
then
  Set Scene A Off
  Set Scene B Off
If RL-B is in normal Toggle mode, then the second program should be replaced with the following:
  Control RL-B is switched Off
  Set Scene A Off
  Set Scene B Off
The combination of the first and third programs would loop through: Scene A On - A & B Off - Scene B On - A & B Off
Thank you Xathros.
RL-B is in Toggle mode so
"If
Set Scene A Off
Set Scene B Off"
is what I have. Works fine
Also,
"If Neither Scene is on, Turn Scene A on.
Continued presses of RL-B toggle between the two scenes."
is correct as well.
I'm unclear on what "
i.scenestat < 2
" and
i.scenestat=1
means.
But I think this is exactly what I'm looking for.
Drew
andrew77-
i.scenestat is an Integer variable and will need to be defined on the integer variables tab. Since there is no such thing as a scene status, we need a variable to track what we believe the status of the scenes to be. In this case if i.scenestat < 2 then we think either Scene B is on (i.scenestat=1) or no scene is on (i.scenestat=0 - uninitialized after startup) so we then Turn Off B, Turn On A and set i.scenestat=2. B may have already been Off - doesn't matter. If i.scenestat=2 it means Scene A is on so we turn A off and B on and set i.scenestat=1.
Also note that the programs turn one scene off then the other on. This allows there to be some overlap in the scene definitions (Same light(s) in both scenes) Otherwise the overlapping lights would always be off.
So, the variable is simply tracking your toggle status.
Okay, so my head is spinning with the integer thing.
(I just saw the tab now for the first time if that lets you in on my apparent ignorance with this)
I'm wondering what to do as far as this goes.
You are 100% correct in that
1. When I press RL-B off Scene A and Scene B shut off
2. When I press RL-B on, it triggers Scene A
3. When I press RL-B again, it knows Scene A is on and triggers Scene B
4. This would toggle back and forth
Do impart knowledge. If this integer thing-a-ma-bob is what I think it is, it's going to be the new cat's *** around these parts.
Drew
(note: No cat's will be harmed in these proceedings)
Just beware that there is likely a reason why "scene" status has no meaning with insteon. Possibly, it is because no two people can agree on what it means for a scene to be on.
If you have a scene that includes two devices, who's "on" level is 30% and 70% (more complicated still, a scene with different "on" levels for each controller), is the scene ON or OFF if the levels are 31% and 71%? What about 29% and 69%?
I bring this up only to point out that scene status can be a more complicated concept than first imagined. One needs to think through their own definition of scene status to make sure any variable used accurately reflects that definition.
Drew
Drew-
Sorry, I can't determine what your questions is here. Also, I've been working this problem with my RL2 in mind which is an 8 button unit. I'm now remembering the old Remotelincs were 4 scene with on/off rockers so there is a RL-B Off button that I was not considering Doesn't change the toggle routine any but I think the second program should be:
  Control RL-B is Switched Off
  Set Scene A Off
  Set Scene B off
  i.scenestat=0
A bit about variables in the ISY: There are two kinds, Integer and State. Both can only contain positive integer values or 0. The only difference is that a State variable can trigger a program when it's value changes much like triggering a program with the change in status of a Switchlinc. An integer variable will not act as a trigger. Variable naming is unimportant beyond your level of OCD'ness. I use i.mvarname for Integer and s.mvarname for State variables in my code to to make reading/debugging a bit easier. Variable names cannot contain Spaces or certain punctuation symbols. .-_ are fine. I also tend to catagorize my mvars for the same reason. s.SEC.HomeAway, s.UTIL.WasherRunning etc. This way I can sort the mvars by name grouping like items.
Im sorry if I was unclear.
I know nothing of the integer and variable of which you speak.
The numbered list in my last post is what I'm trying to accomplish.
Where can I learn about integers?
Your paragraph that starts off "A bit about variables in the ISY" leaves my head spinning.
The universal devices wiki is a good place to start for most things. Try:
http://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Variable_Details
In addition, there is a complete section on variable in this forum under "common ISY topics".
Make sure you have a relatively new version of the ISY software. Variable have only been around a couple of years. If your ISY is older than that, and you have not updated your software, you may not have variable capability.
Thanks LeeG and oberkc-
I was about to go looking for those very links.
Drew-
This is what should be accomplished by the first program I posted and the last I posted.
Go to the integer variables tab, Add a variable. Change the name to i.scenestat. Set the Init to 0 and the value to 0. Save it.
go to the programs tab and build the two programs which I will repeat here:
Program RL-B_Scenes_AB_Toggle
  and
  i.scenestat < 2
then
  Set Scene B Off
  Set Scene A On
  i.scenestat=2
else
  Set Scene A Off
  Set Scene B On
  i.scenestat=1
Program RL-B_ScenesOff
  Set Scene A Off
  Set Scene B off
  i.scenestat=0
You will probably want to read the Wiki and Variabls sections posted by LeeG and oberkc. That will give you a much better understanding of the usage of the variable here. Variables add much greater functionality to the ISY and are well worth learning how to use. We are expecting even greater functionality with variables in the (near-ish) future as UDI extends the capabilities of variables.
This stuff is beyond awesome.
I cannot wait to get the hang of this.
I'm going to drive the wife crazy.
(That is why we buy this stuff, is it not?)
Thank you again. If I have any problems understanding the nomenclature I'll post back.
Drew
Actually, variables can also contain negative integer values. I use -1 all the time because my formal computer training always represented TRUE with a -1.
Unfortunately the ISY does not accept negative variables. As Xathros stated earlier:
~Mike
There may be some confusion due to the syntax of the following operation:
Mvar = Mvar - 1 in ISY syntax is: Mvar =-1 which to the unsuspecting looks like the variable is being assigned a value of -1 when in reality we are decrementing an existing positive value by 1
Hi Xathros,
Sorry to be hard headed but can you explain that a little more...I am having trouble understanding this comment about variables only being positive numbers.
Tim
Variables can have negative numbers. From the initial post on Variable function
Integer Variable
o A signed integer (32 bit)
Program statements can assign negative values
$IAway = -10
Sorry to have been misleading on this. ISY Mvars DO in fact support negative values. I have been operating under the belief that we were limited to positive values for quite some time now.
Lee,
Was this changed since release 3.2.6? (When I purchased my ISY in Dec 2012)
I was also under the impression that variables could only be positive. Just ran a test program and to my surprise they do run negative. My apologies to kclenden for the misinformation.
~Mike
