Insteon Micro On/Off 2443-222 Not linking with isy99
I have an exiting Insteon system, with about 7 devices being controlled by an isy99. I havent had any issues for the last 2 years. I recently wired in a Micro On/Off module that works at the point of installation but will not link up with the ISY. I have tried manually linking and auto linking with no luck.
Any ideas?
Are you using the last avilable firmware update 3.3.10 for your ISY99i?
There is a good chance the 2443-222 support was added to a later revision firmware that is for the ISY994i only. Due to limitations to the firmware storage space in the ISY99i.
Yeah the firmware is indeed 3.3.10. I backed up and re-installed the firmware again. Still no luck. My access points wont even link up and say they are now unsupporeted devices. I have two 2443 Acces Points.
Sun 2013/07/21 03:30:55 PM System -170001 [uDSockets] HTTP:28 error:6
Sun 2013/07/21 03:31:55 PM System -170001 [uDSockets] HTTP:28 error:6
Sun 2013/07/21 09:30:42 PM System -5 Start
Sun 2013/07/21 09:30:43 PM System -110022 /CONF/INSTENG.OPT
Sun 2013/07/21 09:30:43 PM System -110012 /CONF/INSTENG.OPT
Sorre heres Level 3:
Sun 07/21/2013 09:43:10 PM : [1F DB EB ] Added to list of devices to link to ISY
Sun 07/21/2013 09:43:32 PM : [1F DB EB 0 ] Failed to add device
Sun 07/21/2013 09:44:13 PM : [1A 72 5B ] Added to list of devices to link to ISY
Sun 07/21/2013 09:44:13 PM : [1A 72 5B 0 ] May not fully support i2, reverting to i1
Sun 07/21/2013 09:44:13 PM : [1A 72 5B 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Sun 07/21/2013 09:44:14 PM : [1A 72 5B 0 ] Failed to add device
Sun 07/21/2013 09:44:43 PM : [1A 75 72 ] Added to list of devices to link to ISY
Sun 07/21/2013 09:44:44 PM : [1A 75 72 0 ] May not fully support i2, reverting to i1
Sun 07/21/2013 09:44:44 PM : [1A 75 72 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Sun 07/21/2013 09:44:44 PM : [1A 75 72 0 ] Failed to add device
Sun 07/21/2013 09:44:56 PM : Start Insteon Device Linking Mode
Sun 07/21/2013 09:45:07 PM : [1A.72.5B 00] Linked device type=00.0B fw=98
Sun 07/21/2013 09:45:07 PM : [1A 72 5B 0 ] Added to list of devices to link to ISY
Sun 07/21/2013 09:45:23 PM : Stop Insteon Device Linking Mode, Final processing to follow
Sun 07/21/2013 09:45:29 PM : [1A 72 5B 0 ] May not fully support i2, reverting to i1
Sun 07/21/2013 09:45:29 PM : [1A 72 5B 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Sun 07/21/2013 09:45:29 PM : [1A 72 5B 0 ] Failed to add device
Sun 07/21/2013 09:46:41 PM : [1A 72 5B ] Added to list of devices to link to ISY
Sun 07/21/2013 09:46:42 PM : [1A 72 5B 0 ] May not fully support i2, reverting to i1
Sun 07/21/2013 09:46:42 PM : [1A 72 5B 0 ] Using Database Link Table offset 0x0FF8 (reported 0x0000)
Sun 07/21/2013 09:46:42 PM : [1A 72 5B 0 ] Failed to add device
Access Points are not added to the ISY. They have no configuration, no links.
Thanks for the event trace. Unfortunately it is not at LEVEL 3.
Im wondering at this point if the isy99 is just not compatible with the 2443-222. Is there any way to load a firmware that would recognize this module?
Hi D Rock,
ISY is compatible with this module as long as you have 3.3.10.
I suspect the device is reporting a different cat/subcat that ISY does not know about. Do you have more of these devices? Can you go to Help | About and ensure that your firmware is 3.3.10?
Michel,
I do indeed have an isy99i/IR. I only have 7 Insteon devices linked with my isy.
Hope that answers the questions.
Hi D Rock,
Thanks so very much and, yes, you have answered my question.
At this time, I think it would be best to contact our tech support (links below) so that we can help you more efficiently.
