backup isy 26. after upgrading to 994
I also upgraded from isy 26. My backup was not resent thought it was. I tried to back but I cant log into my isy 26 anymore. My plm is 2412s .my 26 internet address was 192.168.1.12 the 994 is 192.168.1.24 or 26 not sure.how can I rebackup the 26 to get it on the 994 thanks. Tom
Hi Tom-
Is the 26 still connected to a PLM?
If you connect the ISY 26 to your LAN, Connect the ISY 26 to the PLM then plug the PLM into power, wait a few seconds for it to start up, you should be able to log into it at it's old address assuming you didn't factory reset the ISY 26 at all.
Also, you want to make sure you are accessing using the correct admin console. Before you try to access the ISY 26, make sure you clear your Java cache. I'm not sure if the 26 worked the same as the 99 and 994 but if so, you should try and access the console at:
http://192.168.1.12/admin
If that works, make your backup then repeat the process for hooking up and connecting to the new 994 but using it's ip instead.
-Xathros
Yes I reconnected plm to the 26 after I installed the 994. I will try that. Thanks for very fast reply. By the way for the 994 plm if I wanted to upgrade. Will the 2413u work. Or does it have to be the s version..Thanks again
Tom-
Anytime! Happy to help.
It has to be the 2413S. The U will not work.
-Xathros
