abuttino Posted August 4, 2014 Author Share Posted August 4, 2014 Restart the machine Link to comment
Alokptl84 Posted August 4, 2014 Share Posted August 4, 2014 I re-installed all the files in the correct locations and I was able to get everything working. I had changed some of the code in the area where it said do not change because I thought I needed to make changes to the away code but it turns out the update was already there. Thanks for all your help! Link to comment
MustangChris04 Posted August 4, 2014 Share Posted August 4, 2014 Restart the machine Same error after restarting. In fact, I had this error last week and and to reformat my computer and after a fresh install of windows and then installing Eventghost with this plugin the same exact errors appeared. Link to comment
abuttino Posted August 4, 2014 Author Share Posted August 4, 2014 Can you PM me and we'll get your stuff settled by a team viewer remote session? Something is very wrong. Link to comment
Jeff Kocur Posted December 10, 2014 Share Posted December 10, 2014 I have two nest thermostats. It appears that the values from the first thermostat are also being sent to ISY for the second thermostat. E.g, Ambient Temp for the first thermostat is 74. Ambient Temp for second thermostat is 73. but both variables in ISY are showing 74. I've set up two different state variables in ISY (15 & 16) and entered the 15 & 16 in the respective variables in the EG config. I also observed that the values for the first thermostat are sent to ISY more frequently than the second (it might be that the second thermostat values are only sent at startup). I'm just starting with this, so I may be missing something. Your assistance is appreciated! Link to comment
abuttino Posted December 10, 2014 Author Share Posted December 10, 2014 Can you please reply to me by email or PM tomorrow? I'll be more than happy to satisfy the needs for your ISY. Since I didn't have a multi-thermostat setup when I devised these scripts, I couldn't do them as accurately as I wanted.. Your help will be appreciated for all members. Link to comment
Jeff Kocur Posted December 11, 2014 Share Posted December 11, 2014 (edited) I was able to determine why I was having trouble with multiple thermostats. In order for the scripts to work properly, it is mandatory to assign a unique label to each of Nest Devices (on the nest device or in the app). I noticed that "name" field in the scripts was blank. I had not populated the label when installing the Nests because the "where" was unique enough for me (Upstairs / Downstairs), but since I added the label, I now see that "name" is populated with the corresponding label and the EG scripts/macros now work properly. Incidentally, I still have a problem that the ISY for Eventghost plugin causes EG to lock up when I enable on a Windows 7 machine. Enabling the Nest Thermostat plugin does not cause the issue. I have the same results on two separate Windows 7 machines, but no issue on a Windows 8 machine. If anyone has any ideas how to fix this, I'd appreciate it since I'd prefer to use one of the Windows 7 machines to run EG. Thanks! Edited December 11, 2014 by Jeff Kocur Link to comment
aca2b2 Posted January 10, 2015 Share Posted January 10, 2015 Quick question. I have tried downloading the files from http://www.tinozplace.com/Nestv80.zip, but it appears that the site no longer exist. Is there another way to get the isy994 to work with nest thermostats? Link to comment
OliverH Posted May 28, 2015 Share Posted May 28, 2015 Is there any possibility of adding Fan control to this? I wrote a few programs to equalize temperature in the house (thermostat upstairs, temp sensor downstairs, vent dampers in place...series of programs matches the temperature downstairs to nest set temp upstairs and then adjusts accordingly), but instead of turning on the nest/furnace, want to try equalizing with just the fan if the temperature differential is not large. Thanks! Oliver Link to comment
abuttino Posted September 11, 2015 Author Share Posted September 11, 2015 Quick question. I have tried downloading the files from http://www.tinozplace.com/Nestv80.zip, but it appears that the site no longer exist. Is there another way to get the isy994 to work with nest thermostats? My site went down recently with me out of town. I am trying to get it back up, keep trying over the next couple days. Sent from my XT1060 using Tapatalk Link to comment
abuttino Posted January 21, 2016 Author Share Posted January 21, 2016 Is there any possibility of adding Fan control to this? I wrote a few programs to equalize temperature in the house (thermostat upstairs, temp sensor downstairs, vent dampers in place...series of programs matches the temperature downstairs to nest set temp upstairs and then adjusts accordingly), but instead of turning on the nest/furnace, want to try equalizing with just the fan if the temperature differential is not large. Thanks! Oliver I could easily add fan control to this. Do you still want it? Sent from my Nexus 6 using Tapatalk Link to comment
kzboray Posted June 1, 2016 Share Posted June 1, 2016 I am new to ISY, but learning as I go. I installed EventGhost and the Nest plugin as described. I am using STATE variables and some work while others don't seem to do much. ACCoolVar never changes in value. Is this a read only variable? I know the state is TRUE when the AC is running as I can see that in EventGhost, but in ISY variables it always shows 0. Also I was wondering if you could post some instructions on how to configure Tasker with AutoLocation to use the at home concept for setting up a geofence. Thank you so much. Link to comment
larryllix Posted June 1, 2016 Share Posted June 1, 2016 I am new to ISY, but learning as I go. I installed EventGhost and the Nest plugin as described. I am using STATE variables and some work while others don't seem to do much. ACCoolVar never changes in value. Is this a read only variable? I know the state is TRUE when the AC is running as I can see that in EventGhost, but in ISY variables it always shows 0. Also I was wondering if you could post some instructions on how to configure Tasker with AutoLocation to use the at home concept for setting up a geofence. Thank you so much. Since this is an old thread you may try quoting the person your questions are directed at to get their attention like I just did to you. Some get notifications on the mobile devices from this action, also. Other's that watch the forum closely may answer anyway. Link to comment
Michel Kohanim Posted June 1, 2016 Share Posted June 1, 2016 Hi kzboray, If you are running a computer (or RPi), you can use Polyglot: http://forum.universal-devices.com/forum/111-polyglot/ http://forum.universal-devices.com/topic/18655-polyglot-nest-nodeserver/ With kind regards, Michel Link to comment
kzboray Posted June 1, 2016 Share Posted June 1, 2016 I'd like to say thank you to both Larryllix and Michel. Michel I'll take a look at Polyglot. Kaz 1 Link to comment
albrandwood Posted August 22, 2016 Share Posted August 22, 2016 (edited) Not sure why, but (on a fresh install) every time I try to open the NestISYwAwayFS.xml, EventGhost crashes ... Windows 7 x86 EventGhost 0.4.1.r1722 Nestv80 otherdlls Microsoft VCredist It crashes out every time I try to open the XML ... Any suggestions? Edited August 28, 2016 by albrandwood Link to comment
abuttino Posted November 20, 2016 Author Share Posted November 20, 2016 I am about ready to release a new version of this. What would you like to see? I have already added running the fan for any amount of time. I can't tell you why EG hangs up on you. I would suggest going to the registry and deleting the keys for Eventghost Sent from my Nexus 6 using Tapatalk Link to comment
ccclapp Posted November 20, 2016 Share Posted November 20, 2016 I am about ready to release a new version of this. What would you like to see? Likely asking for the (currently) impossible, but i would love to see this as ISY-only i.e. without the need for external server, eventghost etc...just wishing. Thanks Link to comment
abuttino Posted November 20, 2016 Author Share Posted November 20, 2016 I could give you the code for the PHP class but, that's only for temperature adjustments, can't discover the thermostat through that, as far as I know. Sent from my Nexus 6 using Tapatalk Link to comment
ccclapp Posted November 20, 2016 Share Posted November 20, 2016 I could give you the code for the PHP class but, that's only for temperature adjustments, can't discover the thermostat through that, as far as I know. ...i dont know enough to know what that means. Are you saying one can currently do tempeture adjustments "Isy-only". Thanks Link to comment
abuttino Posted November 20, 2016 Author Share Posted November 20, 2016 Yup. Sent from my Nexus 6 using Tapatalk Link to comment
ccclapp Posted November 20, 2016 Share Posted November 20, 2016 Yup. Oh, cool. Is the "how-to" in this thread or on the forum? If so do you mind pointing me towards it? Am i correct that home/away is not Isy-only? Thanks Link to comment
abuttino Posted November 20, 2016 Author Share Posted November 20, 2016 (edited) Deleted Edited November 20, 2016 by abuttino Link to comment
abuttino Posted November 20, 2016 Author Share Posted November 20, 2016 Search "Nest PHP class" on Google. That's where I found it. You may be able to do a home and away. If it were me and I had the Network Module, I would just use IFTTT and the Nest channel as well as the Maker channel to build an applet for the ISY to change temperature. These macros are much much more robust than anything IFTTT could give you. Sent from my Nexus 6 using Tapatalk Link to comment
ccclapp Posted November 20, 2016 Share Posted November 20, 2016 THanks Search "Nest PHP class" on Google. That's where I found it.You may be able to do a home and away.If it were me and I had the Network Module, I would just use IFTTT and the Nest channel as well as the Maker channel to build an applet for the ISY to change temperature.These macros are much much more robust than anything IFTTT could give you.Sent from my Nexus 6 using Tapatalk Thanks Link to comment
