Schedule Hold Trigger
Following up on my Party Time thread, I would like to be able to put my Schedules (or a group of schedules) on hold with a button press. I know you can manually hold a schedule, but that defeats the purpose of automation.
HAS,
You will have this functionality in release 2.5. In short, you can have a button (INSTEON button) act as a trigger to activate/deactive your schedules (such as vacation/party/etc.).
Apologies for beating a dead horse, but I am still very interested to know whether or not remote access/email notifications work for you.
Greetings,
The remote access was resolved before v2.4 came out. Once we figured out the Port Forwarding, it was all downhill from there.
I still cannot get my email notifications to work. The error messages are:
EI = No Internet Gateway Found
TM = Failed to send message to: (my email address)
Hello HAS,
I am so very sorry. We've been trying to resolve the issue with ActionTech routers where if a device is not given a DHCP address, then it will not allow domain name resolutions to go through.
May I ask whether or not you're using your ISP's DNS addresses to configure ISY or are you using the routers IP address?
I appreciate your patience,
Greetings,
UD - Device Finder Utility
Application Name: INSTEON
DHCP IP - 192.168.1.7
DHCP Sub - 255.255.255.0
DHCP Gateway - 192.168.1.1
DHCP DNS - 192.168.1.1
Interface - Ethernet
MAC Address - (yes)
Static IP - 0.0.0.0
Static Sub - 0.0.0.0
Static Gateway - 0.0.0.0
Static DNS - 0.0.0.0
Hello HAS,
Greetings,
HAS,
Thank you. We have started a discussion with ActionTech technical team to see what we can do with this issue. I shall keep you posted.
MAC Address - (yes)
Static IP - 0.0.0.0
Hello HAS,
Greetings,
