Need Help With A Program
I want to press a kpl button (g), wait 5 minutes and if a door sensor is on send a notification. It appears I need a second "if statement" and I can find no way to do that.
g is on
wait 5 minutes
I have the notification process set up and can activate it w/o the wait step so I know that part of the process works.
Thanks for your help.
control g is on
wait 5 minutes
run program 2
diasabled program 2 (runs only if called from another program)
sense door sensor is on
Why not
Control g is on
And door sensor is on
Wait 5 minutes
Send notification
Now if you want the program to trigger if the door sensor is turned on after G then my program will not work. you would need to use status is on for G.
Why not
Control g is on
Wait 5 minutes
Send notification
Because this, in my mind, does not do what you are asking.
You said you wanted a program that, for a period of five minutes after G is on, watch for a door sensor and, if triggered, send a notification (without mentioning the need for a delayed notification).  Your program will trigger a notification (but the notification will not be sent until 5 minutes after the fact) anytime the door is triggered while G is ON (regardless of whether G has been on for less than five minutes.
This may be what you want in your mind, but I believe Stusviews more accurately reflects what you asked for in your original post.
Oberkc, I'm not the OP, just was throwing in my two cents.   What he wrote was:
"I want to press a kpl button (g), wait 5 minutes and if a door sensor is on send a notification"
That is what the program I wrote does.  He did not write "watch for a door sensor, and, if triggered."
Another instance of the need for the OP to specify exactly what he wants.
Eric
EricK, "I want to press a kpl button (g), wait 5 minutes and if a door sensor is on send a notification"
Thus, if 5 minutes have elapsed after pressing the button and the sensor is on, then send the notification. That's not the same as "if both devices are on send a notification after 5 minutes has elapsed."
“ I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant”
Edited by stusviews
Sorry.  I was in too much of a hurry.
Perhaps when smokegrub returns, he can clarify which of us is confused.
Stusviews:
Your suggestion worked perfectly. Also, I learned a couple of things that will prove valiable in the future. !) Using a program within a program and 2) A program that is disabled will run when used in another program. My thanks to those of you who provide such tremendous help.
