Writes to Error Log With No Other Information
msplain
After booting the memory LED on the font panel of my new ISY994i constantly blinks. I had a few "platform error" message popups so I looked in the error log. What I see is an endless stream of "Check Log" messages with no other information.
Tue 2015/01/13 07:06:44 PM System -10108 Check log
Tue 2015/01/13 07:06:45 PM System -10108 Check log
The only information in the normal log is the initial query command after reboot. I have tried factory reset, re-install firmware and numerous other things but no matter what I do I can't stop what appear to be endless empty writes to the error log.  I am starting to think this device has some kind of fault and needs to be returned.
The firmware version is 4.2.18. The configuration is the factory default with a 2413S PLM connected to the ISY.
Any advice would be greatly appreciated.
I then disconnected the WAN connection from my router. This had no effect.
My final test was to disconnect the ISY from the network. The memory light continues to flash quickly and in addition the red error light now flashes slowly.
      378.8k
