March 2, 201511 yr I could swear I had my mobilinc setup to show my ZWave locks green when locked (on). However all my devices show as red now. I'm wondering if there was a recent change I missed? Jeff
March 2, 201511 yr No. But it is possible that you customized the Mobilinc color scheme in the ML settings. Check that out and see what it shows as colors for Device On (Default Red) and Device Off (Default Green) -Xathros
March 3, 201511 yr Author My device on its red and green for off. But the lock status locked = off. So it's red. I would like it to be green when locked (on).
March 3, 201511 yr Hi Jeff, No changes here. If the device is reporting ON (Locked) then MobiLinc uses the color you have set for devices that are ON. Default is Red. Wes
March 3, 201511 yr My device on its red and green for off. But the lock status locked = off. So it's red. I would like it to be green when locked (on). Mine is the same. Never noticed since I have my locks on the dashboard using the lock icon and it shows gray when locked and red when unlocked. -Xathros
