False ON
flsenior
I have a 2476D Dimmer switch that has been installed for some time.  It is not linked to any programs.
Recently I noticed that the switch will display a 3% "ON" position in the morning.  The led indicators on the dimmer are in the total "OFF" position and I see no illumination from the lights (halogen 2 x 35W spots).
I have checked the switch in the evening to make certain that the switch is in the OFF position and will notice the change to 3% ON in the morning.
I am confirming the relative ON/OFF readings via MobiLinc Connect.
Any ideas what may be causing the 3% On indication overnight?
Need to see an Event Trace at LEVEL 3 to be certain.  Sounds like duplicate message response, perhaps during 3AM Query, that is interpreted as an On at very low level.  Turn On Event Viewer at LEVEL 3 at bedtime, and post trace when SwitchLinc shows 3% under Admin Console.
EDIT:  will need Insteon address of SwitchLinc when trace posted
I set the Level 3 as directed above.  When I close my browser and then restart the browser, the level has reset to 1.  Must I leave my desktop running and the admin console open all night?
