Log question
clark21236
Yesterday I had an issue where my Xmas light program did not run. I looked in the log file to see if I could figure out what happened. Here is what showed up in the log file. I am running 2.6.8 in my ISY.
What you will see is that on the 19th the system shut down my XMas light scene. Then at 12:09 it ran into a time server issue, then who knows what happened.
Scene:XMas Lights Off 0 Fri 12/19/2008 10:00:01 PM Program Log
0 null Sat 12/20/2008 12:09:24 AM System Start
0 pool.nt Sat 12/20/2008 12:09:29 AM System -60001
05.CA.F1.1 (John Side) Status 0% Sat 12/20/2008 12:09:29 AM System Log
05.CA.F1.1 (John Side) On Level 100% Sat 12/20/2008 12:09:30 AM System Log
05.CA.F1.1 (John Side) Ramp Rate 2.0 Sec Sat 12/20/2008 12:09:31 AM System Log
0A.87.98.1 (Mary Side) Status 0% Sat 12/20/2008 12:09:32 AM System Log
0A.87.98.1 (Mary Side) On Level 100% Sat 12/20/2008 12:09:33 AM System Log
0A.87.98.1 (Mary Side) Ramp Rate 2.0 Sec Sat 12/20/2008 12:09:34 AM System Log
FR KPL Off/On Status 0% Sat 12/20/2008 12:09:34 AM System Log
FR KPL Off/On On Level 100% Sat 12/20/2008 12:09:35 AM System Log
FR KPL Off/On Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:36 AM System Log
MBR KPL Off/On Status 100% Sat 12/20/2008 12:09:37 AM System Log
MBR KPL Off/On On Level 100% Sat 12/20/2008 12:09:38 AM System Log
MBR KPL Off/On Ramp Rate 2.0 Sec Sat 12/20/2008 12:09:39 AM System Log
Pool Pump Inlinelinc Status 0% Sat 12/20/2008 12:09:39 AM System Log
Pool Pump Inlinelinc On Level 100% Sat 12/20/2008 12:09:40 AM System Log
Pool Pump Inlinelinc Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:41 AM System Log
Front Porch Light Status 0% Sat 12/20/2008 12:09:42 AM System Log
Front Porch Light On Level 100% Sat 12/20/2008 12:09:43 AM System Log
Front Porch Light Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:44 AM System Log
Loft Fan Light Status 0% Sat 12/20/2008 12:09:44 AM System Log
Loft Fan Light On Level 100% Sat 12/20/2008 12:09:45 AM System Log
Loft Fan Light Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:46 AM System Log
Laundry Rm Slave Status 0% Sat 12/20/2008 12:09:47 AM System Log
Laundry Rm Slave On Level 100% Sat 12/20/2008 12:09:48 AM System Log
Laundry Rm Slave Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:49 AM System Log
Kitchen High Hat Slave Status 0% Sat 12/20/2008 12:09:49 AM System Log
Kitchen High Hat Slave On Level 100% Sat 12/20/2008 12:09:50 AM System Log
Kitchen High Hat Slave Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:51 AM System Log
Laundry Rm Master Status 0% Sat 12/20/2008 12:09:52 AM System Log
Laundry Rm Master On Level 100% Sat 12/20/2008 12:09:53 AM System Log
Laundry Rm Master Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:54 AM System Log
Kitchen High Hat Master Status 0% Sat 12/20/2008 12:09:54 AM System Log
Kitchen High Hat Master On Level 100% Sat 12/20/2008 12:09:55 AM System Log
Kitchen High Hat Master Ramp Rate 0.1 Sec Sat 12/20/2008 12:09:56 AM System Log
0E.18.07.1 (Xmas Tree) Status 0% Sat 12/20/2008 12:09:57 AM System Log
0E.18.07.1 (Xmas Tree) On Level 100% Sat 12/20/2008 12:09:58 AM System Log
0E.18.07.1 (Xmas Tree) Ramp Rate 2.0 Sec Sat 12/20/2008 12:09:59 AM System Log
0E.1A.CC.1 (Xmas Bannister) Status 0% Sat 12/20/2008 12:09:59 AM System Log
0E.1A.CC.1 (Xmas Bannister) On Level 100% Sat 12/20/2008 12:10:00 AM System Log
0E.1A.CC.1 (Xmas Bannister) Ramp Rate 2.0 Sec Sat 12/20/2008 12:10:01 AM System Log
MBR SLD Right Status 0% Sat 12/20/2008 12:10:02 AM System Log
MBR SLD Right On Level 100% Sat 12/20/2008 12:10:03 AM System Log
MBR SLD Right Ramp Rate 0.1 Sec Sat 12/20/2008 12:10:04 AM System Log
Scene:My Lighting Status 0% Sat 12/20/2008 03:00:00 AM Program Log
I looked at some earlier entries, before the ones I have posted here, and it looks like there could be some weird stuff going on. If I read it correctly, it looks like the system is turning some lights on and off all by itself at just after 12:00 am.
Hello clark21236,
The time server issue is not what bothers me. The problem was that your system was rebooted at 12:09 on 12/20:
So, when ISY restarts and if you have not set ISY to run your program at startup, then your program will not run till the next time (perhaps next day) that it's scheduled.
Now, my questions:
1. Did you have a power outage
2. Is that program enabled to be run at start up?
Hello clark21236,
Now, my questions:
Michel, I won't rule out a power outage, but I have no other signs in my house that it did occur.
I guess the part that is hard to understand is this.
       From    Sunset
       To      10:00:00PM (same day)
       Set Scene 'XMas Lights' On
       Set Scene 'XMas Lights' Off
If the ISY reboots at 9 minutes after midnight, shouldn't the code above run that same day? I don't understand why it would need to wait until the next day to run.
As for run at start up, I don't have any of my programs set to do that. Maybe I need to be pointed to the right location to understand what that feature will do for me.
Thanks for the help.
Steve
Catch up at Restart (Configuration) has a few glitches this way. They were gone for a while but I think some are back. For now I have unchecked that option. After a power outage the lights should return to their previous levels, so if no schedules were missed nothing is wrong.
Rand
Hello Steve,
Then answer is NO. The problem is that time sensitive programs have to be re-evaluated at start-up explicitly. All this is due to the fact that most people did not want their schedules to run after each restart nor did they want ISY to catch up to schedules that were not run. So, what you have to do is:
1. For programs that are TIME only (like yours), please decide if you want to run them at start up ... you can do this in program summary
2. Please decide if you want ISY to catchup (run programs that may have been missed) ... you can do this in Configuration Tab under System
3. And, finally, what grace period ... you can do this in Configuration Tab under System
       From    Sunset
Steve
      38.2k
      381.2k
