EZFlora Model #5010A ISY UnSupported
Just got from Smarthome and wanted to replace an EZflora that gave up after 5 years of service and when i try to link it say unsupported....
22333-233
V 1.C
1057
PS. I am on 4.3.26
Did you try New Insteon Device and manually selecting the ezflora? If you scroll down the list of devices, the ezflora is 4.00
Paul
Link to comment
Wierd. No reason I can think of. Ideas at this point:
  1. Close, then re-run the admin console ..or..
  2. Unplug and replug in the ezflora .. if that doesn't work...
  3. repeat step 2, delete the ezflora and add it back in again
Guessing a bit at this point
Paul
Link to comment
Paul
Thanks again Paul. Gave those steps a try and same result. Have a wonderful weekend.
Try right click on EZFlora node and select Group Devices.  You may have all,eight nodes but they are not listed together without being 'grouped' together.
Thanks Lee, but that didn't make a difference.
Link to comment
Thanks for the pointer Paul! Manually selecting EZFlora did add it into the system as such but for some reason only added 5 of the 8 zones. Any idea why that would be?
Curious... what does Help > About show for Firmware and UI?
Jon...
Link to comment
After uninstalling and factory reset you might open Event Viewer to level 3 and copy linking events then post back trace.  I've developed a habit with new devices to link from the same outlet as my PLM.  I have extension cord I've parted the outlet end from and use that for wired devices and a short adapter I use for wall warts.
Jon...
Link to comment
Jon...
Finally had a chance to look at the issue again. Removed the EZFlora, rebooted and then added with a level 3 trace;
Tue 02/09/2016 04:09:24 PM : Start Insteon Device Linking Mode
Tue 02/09/2016 04:09:24 PM : [LNK-BGN     ] 02 64 01 00 06
Tue 02/09/2016 04:09:32 PM : [LNK-STAT    ] 02 53 M(01) gid=00 38.7C.3B 0400 28
Tue 02/09/2016 04:09:32 PM : [38.7C.3B 00] Linked device type=04.00 fw=28
Tue 02/09/2016 04:09:32 PM : [38 7C 3B 0  ] Added to list of devices to link to ISY
Tue 02/09/2016 04:09:32 PM : [LNK-BGN     ] 02 64 01 00 06
Tue 02/09/2016 04:09:33 PM : CLI-HAMW: Connecting to api.aerisapi.com
Tue 02/09/2016 04:09:34 PM : CLI-HAMW: Successfully Processed HAMW Response
Tue 02/09/2016 04:09:34 PM : CLI-HAMW: Connecting to api.aerisapi.com
Tue 02/09/2016 04:09:48 PM : Stop Insteon Device Linking Mode, Final processing to follow
Tue 02/09/2016 04:09:48 PM : [LNK-END     ] 02 65 06 : : Unexpected, ignored (65)
Tue 02/09/2016 04:09:48 PM : [iNST-TX-I1  ] 02 62 38 7C 3B 0F 0D 00
Tue 02/09/2016 04:09:48 PM : [iNST-ACK    ] 02 62 38.7C.3B 0F 0D 00 06                 (00)
Tue 02/09/2016 04:09:49 PM : [iNST-SRX    ] 02 50 38.7C.3B 33.5D.61 2F 0D 02           (02)
Tue 02/09/2016 04:09:49 PM : [std-Direct Ack] 38.7C.3B-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Tue 02/09/2016 04:09:49 PM : [38 7C 3B 0  ] Calibrating engine version
Tue 02/09/2016 04:09:49 PM : [iNST-TX-I2CS] 02 62 38 7C 3B 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Tue 02/09/2016 04:09:49 PM : [iNST-ACK    ] 02 62 38.7C.3B 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06        (00)
Tue 02/09/2016 04:09:49 PM : [iNST-SRX    ] 02 50 38.7C.3B 33.5D.61 2F 2F 00           (00)
Tue 02/09/2016 04:09:50 PM : [iNST-ERX    ] 02 51 38 7C 3B 33 5D 61 15 2F 00 00 01 1F FF 00 E2 00 33 5D 61 01 00 00 DE
Tue 02/09/2016 04:09:50 PM : [Ext-Direct  ] 38.7C.3B-->ISY/PLM Group=0, Max Hops=1, Hops Left=1
Tue 02/09/2016 04:09:50 PM : [38 7C 3B 0  ] Using Database Link Table offset 0x1FF8 (reported 0x1FF8)
Tue 02/09/2016 04:09:50 PM : [38 7C 3B 1  ] Start : Adding device to ISY
Tue 02/09/2016 04:09:50 PM : [38 7C 3B 1  ] Finish : Adding device to ISY was Successful
Tue 02/09/2016 04:09:50 PM : [iNST-TX-I1  ] 02 62 38 7C 3B 0F 44 09
Tue 02/09/2016 04:09:50 PM : [iNST-ACK    ] 02 62 38.7C.3B 0F 44 09 06                 (09)
Tue 02/09/2016 04:09:51 PM : [iNST-SRX    ] 02 50 38.7C.3B 33.5D.61 2B 44 00           (00)
Tue 02/09/2016 04:09:51 PM : [std-Direct Ack] 38.7C.3B-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 2  ] Start : Adding device to ISY
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 2  ] Finish : Adding device to ISY was Successful
Tue 02/09/2016 04:09:51 PM : [iNST-SRX    ] 02 50 38.7C.3B 33.5D.61 23 44 00           (00)
Tue 02/09/2016 04:09:51 PM : [std-Direct Ack] 38.7C.3B-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 3  ] Start : Adding device to ISY
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 3  ] Finish : Adding device to ISY was Successful
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 4  ] Start : Adding device to ISY
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 4  ] Finish : Adding device to ISY was Successful
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 5  ] Start : Adding device to ISY
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 5  ] Finish : Adding device to ISY was Successful
Tue 02/09/2016 04:09:51 PM : [iNST-TX-I1  ] 02 62 38 7C 3B 0F 44 02
Tue 02/09/2016 04:09:51 PM : [iNST-ACK    ] 02 62 38.7C.3B 0F 44 02 06                 (02)
Tue 02/09/2016 04:09:51 PM : [iNST-SRX    ] 02 50 38.7C.3B 33.5D.61 2F 44 00           (00)
Tue 02/09/2016 04:09:51 PM : [std-Direct Ack] 38.7C.3B-->ISY/PLM Group=0, Max Hops=3, Hops Left=3
Tue 02/09/2016 04:09:51 PM : [38 7C 3B 0  ] Successfully added device
Tue 02/09/2016 04:09:52 PM : [D2D EVENT   ] Event [38 7C 3B 1] [sT] [0] uom=0 prec=-1
Tue 02/09/2016 04:09:52 PM : [  38 7C 3B 1]       ST   0
Tue 02/09/2016 04:09:52 PM : [iNST-TX-I1  ] 02 62 1D FE E2 0F 14 00
Tue 02/09/2016 04:09:52 PM : [iNST-ACK    ] 02 62 1D.FE.E2 0F 14 00 06          LTOFF-F(00)
Tue 02/09/2016 04:09:52 PM : [D2D EVENT   ] Event [38 7C 3B 2] [sT] [0] uom=0 prec=-1
Tue 02/09/2016 04:09:52 PM : [  38 7C 3B 2]       ST   0
Tue 02/09/2016 04:09:52 PM : [D2D EVENT   ] Event [38 7C 3B 3] [sT] [0] uom=0 prec=-1
Tue 02/09/2016 04:09:52 PM : [  38 7C 3B 3]       ST   0
Tue 02/09/2016 04:09:52 PM : [D2D EVENT   ] Event [38 7C 3B 4] [sT] [0] uom=0 prec=-1
Tue 02/09/2016 04:09:52 PM : [  38 7C 3B 4]       ST   0
Tue 02/09/2016 04:09:52 PM : [D2D EVENT   ] Event [38 7C 3B 5] [sT] [0] uom=0 prec=-1
Tue 02/09/2016 04:09:52 PM : [  38 7C 3B 5]       ST   0
Tue 02/09/2016 04:09:52 PM : [All         ] Writing 0 bytes to devices
Tue 02/09/2016 04:09:52 PM : [iNST-SRX    ] 02 50 1D.FE.E2 33.5D.61 2B 14 00    LTOFF-F(00)
Tue 02/09/2016 04:09:52 PM : [std-Direct Ack] 1D.FE.E2-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Tue 02/09/2016 04:09:52 PM : [D2D EVENT   ] Event [1D FE E2 1] [sT] [0] uom=0 prec=-1
Tue 02/09/2016 04:09:52 PM : [  1D FE E2 1]       ST   0
Tue 02/09/2016 04:09:52 PM : [D2D-CMP 0040] STS [1D FE E2 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Tue 02/09/2016 04:09:53 PM : [D2D-CMP 0040] STS [1D FE E2 1] ST op=1 Event(val=0 uom=0 prec=-1) is Condition(val=0 uom=0 prec=-1) --> true
Tue 02/09/2016 04:09:53 PM : [D2D-CMP 003C] STS [1D FE E2 1] ST op=6 Event(val=0 uom=0 prec=-1) != Condition(val=0 uom=0 prec=-1) --> false
Tue 02/09/2016 04:10:33 PM : CLI-HAMW: Connecting to api.aerisapi.com
Tue 02/09/2016 04:10:34 PM : CLI-HAMW: Successfully Processed HAMW Response
Tue 02/09/2016 04:10:34 PM : CLI-HAMW: Connecting to api.aerisapi.com
Tue 02/09/2016 04:10:35 PM : CLI-HAMW: Successfully Processed HAMW Response
Still only getting 5 stations....
Link to comment
Hello Automate The World,
Unfortunately no count anywhere. This said, you can definitely use Tools | Generate Topology for a high level view of where you are.
Hi Michel,
Thanks for the tip. Instead I had a few devices that I don't use anymore so I deleted them from the system and then re-added the EZFlora and everything is all good!
It would have been nice if as I was linking and there were not enough nodes available that a message would tell me so.
On a side note I remember thinking about 4 years ago when I bought this ISY that there is no way I would ever need more than 256 devices/nodes and here we are. :-)
Thanks for all the help everyone!
Link to comment
      36.9k
      370.6k
