Z-Wave Plus
Brandon
What is the current status of Z-Wave Plus support on the ISY-994iZw controllers?
Is Z-Wave Plus supported?
Is it fully supported and if not, what is and is not supported?
If it is not supported, what is the road map for adding this support?
Let's wait until regular Z-Wave is well supported before we start asking for Z-Wave Plus. Also I believe at least the Z-Wave module would have to be replaced.
What is the current status of Z-Wave Plus support on the ISY-994iZw controllers? <-Doesn't exist
Is Z-Wave Plus supported? <- No
Is it fully supported and if not, what is and is not supported? Gen 5 specifications will outline what you will miss.
If it is not supported, what is the road map for adding this support? <- No ETA
In line . . .
What is not well supported about the existing Z-Wave module?
There are several threads already discussing this.
Short and to the point.
Best regards,
Gary Funk
I assumed there would be but i was not able to quickly find them. Can you direct me to them?
Not without spending time searching. I don't keep track, I just read every post that comes up each day. But i can tell you it was after August 6th.
Best regards,
Gary Funk
Hi,
We are working towards Z-Wave Plus and it will likely be part of the next official Z-Wave release (5.0.X), but of course we have to get out of Alpha & Beta first.
Do you know when will 5.0.5 be released?
  • 4 months later...
Best regards,
Gary Funk
Do you know off hand if these issues are going to be solved by the update? Or if they are even being taken into account?
And at the risk of sounding like I don't know anything, is the Z-Wave plus not the same as the next official Z-Wave release?
My understanding is that Z-Wave plus is the same as Z-Wave Gen 5.
Hello all,
Z-Wave Gen 5 is a hardware chip. Z-Wave Plus is a certification thing with icons and some features that only Gen 5 can provide but it's not a necessity. In short, we can get Z-Wave Plus certification even without having Gen 5 hardware. We are going to do both.
  • 8 months later...
  • 1 year later...
Any chance there's a Z-Wave Plus module coming?  Can I replace the module in my existing Z-Wave if it was ordered with Z-Wave installed?  Including and Excluding is the absolute worst right now.  Dealing with door locks having to come all the way to the hub makes me want to not use any of it.
It's been out and as long as you run firmware 5.0.13 and above you can swap.
Due to the nature of locks, you'll still need to bring them close to the isy to add anyway. Adding your lock prior to installation would make that process much easier.
If done properly, this should be a one time process. What problems are you having that makes you have to do it on a regular basis?
