Can't get Mobilinc to work
bob123
Just changed to isy portal today from mobilinc connect.  The portal is working in that I can use the console and connect from my.isy.io.  But I cannot get mobilinc to connect.  I followed the wiki explicitly.
Host Type: ISY
User Name - my isy portal user name
Password - my isy portal Pwd
Local http://   blanked out
Local Port 80 - this was the setting so left it
Secure http://my.isy.io
Secure Port 443
Connect Method Auto (https) - I also tried http
UUID of ISY - this says Remote ISY and does not let my type
I do Tap to Sync with ISY and get
Syncin with ISY
Parsing Program Status
It hangs for a few minutes then says
Connection Error  Retry, Stop, Settings.
I added a 3rd profile to try from scratch - no difference
Some additional info - before it hangs on Parsing program status I see quickly flashing by
Parsing Devices and Scenes - I think that is succeeding, but the program parsing is failing.
My ISY is at 4.5.4
Fustrated.
Edited by bob123
Hi bob123,
Are you certain you have Preferred ISY set in My Profile in ISY Portal?
Also, have you tried uninstalling MobiLinc and installing it again. In some cases, the cache does not get cleared.
That was it - it did not have the Preferred ISY set in the My Profile.
Works.
Much thanks
  • 3 weeks later...
I have 2 ISY's in different houses and would like to connect both using MobiLinc. Is it possible using the same username? If not could I set up 2 accounts using different email addresses?
Michael,
Thanks, that worked to get my Mobilinc to work with both ISY's, There was one more step. When I tried to link the new email address to Amazon, I got an error "This Amazon user profile has already been used ...".  I had to un-link my first user's 2nd ISY  from my Amazon account, then re-link it using the second ISY portal user.
  • 2 months later...
I am having the same problem as bob123. I always ran mobilinc connect through mobilinc HD on an iPhone 7 and I just converted to the ISY portal and I cannot connect through moblilinc any longer.
My perferred ISY is set and I can access the device from portal plus Alexa working properly.
I have uninstalled the software and reset the device.
I am also running 4.5.4
Please help, Thank you
Sorry I should have been more clear but I was having trouble connecting through the moblilinc app on my phone. I reset the ISY again late last night (3rd time) and the app synced with the ISY. Third times a charm lol.
Thanks for you help.
  • 10 months later...
I am having a similar issue:
I have tried to connect many times to my ISY remotely and the screen keeps getting stuck on
Syncing with ISY
Parsing Address: 46 37 48 1
I have to do a hard shutdown of the app and reboot it. When I get back into it I don't have the status of any of my insteon devices. However, I can turn on and off my devices if I go individually in them but the status does not show the current status. It just stays blank.
I have already tried to reinstall the app without success. Following are my settings:
Host Type ISY
User name (my user name)
Password (my password)
Local http://no-ip(my host name).zapto.org:85
Local Port:  85
Secure https://440
Secure Port: (blank)
Connect Method Auto(Http)
UUID of ISY 00:xx:ss....
Auto Sync over wifi checked
Auto Sync over cell checked
Any help would be much appreciated. Thanks.
