Thermostat won't go to Program Mode from ISY
I am just starting to use ISY to control thermostats at my church.  These are new heat pump units 2732-242 v11
I can not get them to enter into the program modes from ISY.  Either from the admin main console or from programs, I can change them between off, cool, heat, and auto, but not program cool/heat/auto.  If I change to one of those modes, ISY shows the change in the console, but if I query it, it shows that it is still whatever it was before.  Same thing if I use a program to change the mode.
They do go into program mode just fine from the actual thermostat and display as such when queried by ISY.
and 5.0.8
Edited by apostolakisl
Hi apostolakisl,
Please try 5.0.10 or revert to 4.5.4.
Perfect, fixed it.  Also it got rid of "program cool" and "program heat" which are two modes that I don't think exist.
EDIT:  The ISY Dashboard still shows "program cool" and "program heat" even though the admin console does not.  Also, those modes show up in Agave.  I thought it was an Agave problem until I found the dashboard also has it.  If I try setting to "program cool" the dashboard responds with an error that the device didn't respond.
