Repeat On and Off Water Pump Switch
Liber93
Thanks for the help in advance.
For some odd reason I cannot get the simplest of programs to work.
I want my water pump to come on for 1 minute, then switch off for 5 minutes - and repeat this schedule 24/7.  On 1-minute, Off 5-minutes, repeat.
Any suggestions?
Hi
This is the general idea but you'll need to test it
        From    12:00:00AM
        To      12:00:00PM (same day)
        Repeat Every  6 minutes
           Set 'Pump' On
           Wait  1 minutes
           Set 'Pump' Off
Paul
Edited by paulbates
The above then section is perfect.  But I wouldn't do the If that way.  At midnight the program will reset and you won't end up with your 1/5 thing.  Probably it doesn't really matter, but in the interest of doing things the best possible way, I would do something like
IF
From 9 am 5/24/2017 (or any other time in the past)
To 9 am 5/24/2035 (or any date far off in the future, but not too far i the future since that seems to screw up ISY.)
what Paul said
Be sure to click "enable at startup" in the program summary page.
EDIT:  Also be sure to right click on it after you save the program and click "run if", this will start the loop.  Otherwise the loop won't start until the next reboot.
Edited by apostolakisl
Hi
        From    12:00:00AM
           Set 'Pump' On
           Wait  1 minutes
           Set 'Pump' Off
Paul
That would be every 7 minutes due to a syntax error in the ISY syntax. This is just to call attention to users attempting to make time critical programs.
Should have been somethig like Repeat and Wait 6 Minutes.
Also the OP wanted 24/7 so he can remove the "to 12:00 PM" line.
I like to use several OR times durig the day to restart any Repeat loop stalling, sooner, ie...when you edit the program, or the power cycles to ISY.
I suppose another option would be no If statement, and mark it as "Run on Startup"
For sure, but then when editing programs, I sometimes forget to start the program again. I've been caught a few times now. :(
Right now I rely on multiple times as I cannot depend on the "Run at startup" option.
The usual fix is to add another program that kickstarts all these programs (Then). Another easy to forget item though.
Hopefully UDI will add this option Run at startup, "If", "Then", "Else", to alleviate this problem. :)
      379.9k
