True/False Question
I have the following program;
From Sunset
To Sunrise (next day)
And Control 'Garage Lantern S' is switched Fast On
Set 'Garage Lantern S' On
Set 'Garage Lantern W' On
Wait 2 seconds
Set 'Driveway Septic' On
Wait 2 seconds
Set 'Woodshed' On
Set 'South Entry Lantern' On
I would expect it to show FALSE and it does until I use it, then turns TRUE. After I return the switches to OFF, it still shows TRUE!
Here is the normal way to turn it off;
Control 'Garage Lantern S' is switched Off
Or Control 'Garage Lantern S' is switched Fast Off
Set 'Garage Lantern S' Off
Set 'Garage Lantern W' Off
Wait 2 seconds
Set 'Driveway Septic' Off
Wait 2 seconds
Set 'Woodshed' Off
Wait 2 seconds
Set 'South Entry Lantern' Off
For you Guru's, I use this to turn on several lights on the driveway at once rather than having to go around to 4 seperate switches.
Any help, suggestions or a better way to do would be appreciated.
aLf
I may not be the "guru", but I'm pretty sure that first program will only be "evaluated" if 'Garage Lantern S' is switched Fast On. Any other action will not cause it to be evaluated.
Not sure I quite understand, but the initial program will change to true if, during the specified time periods, the 'Garage Lantern S' switch is turned FAST ON (double-tap ON).
When do you want it to go false, when you turn the 'Garage Lantern S' switch off? If so, you could try changing the IF statement to:
From Sunset
And Control 'Garage Lantern S' is not switched Off
Program 2 stays True all day long! Not sure if that is right.
aLf
Yes, it will be True all day but will not be triggered until one of the other conditions is met because of using Ands. Each change in condition will cause a reevaluation. At that time it will run the Then or Else and stay True or change False.
Rand
Is this the code you are referring to?
From Sunset
During the time that the Schedule is True:
When 'And Control 'Garage Lantern S' is switched Fast On ' the program will trigger True and run the Then Actions.
When 'And Control 'Garage Lantern S' is not switched Off' will interrupt the program when that switch is pressed off and will run the Else.
Rand
Rand:
No. The second one to turn OFF is the one that stays TRUE all day.
aLf
aLf,
Add the Sunset/Sunrise condition to program 2 if you need the program to change to False during the day.
       From    Sunset
   And (
Rand
Thanks, worked too.
