NodeLink and ISY v.5.0.11
Hi
I installed version 5.0.11 firmware in the ISy and it seems NodeLink 8.4 won't connect because of some password issue.
Tried everything I could think of.
2017-12-09 09:59:38 - ISY NodeLink Server v0.8.4 started
2017-12-09 09:59:38 - Mono version: 5.4.0.201 (tarball Fri Oct 13 22:19:03 UTC 2017)
2017-12-09 09:59:38 - ISY resolved to 192.168.20.55
2017-12-09 09:59:39 - Web config server started (http://192.168.20.72:8090)
2017-12-09 09:59:39 - ISY Node Server config detected (profile 2)
2017-12-09 09:59:42 - Location: Web server started on port 8995 [loc1]
2017-12-09 09:59:43 - Auto-Update: Checking for program update...
2017-12-09 09:59:43 - Auto-Update: No web update available
2017-12-09 09:59:44 - ISY Error: Login failure (verify ISY password on the system config page)
2017-12-09 10:00:14 - ISY Error: Login failure (verify ISY password on the system config page)
2017-12-09 10:00:45 - ISY Error: Login failure (verify ISY password on the system config page)
2017-12-09 10:01:15 - ISY Error: Login failure (verify ISY password on the system config page)
Gary
Hi
Gary
I've got the same issue.  Something similar is happening with my Polyglot node servers as well as with my portal Occupancy node server.  This suggests that this is related more broadly to changes in the 5.0.11 firmware, and not related necessarily to Nodelink.
Yes I now see the portal Occupancy issue also.
Went back to v.5.0.10 and all ok now
Edited by garybixler
Known issue, 5.0.11 appears to have broken NodeLink and Polyglot.
