Problem with docker.
Hi.
I posted this at unraid forum but don't know how often it is visited so here it goes again:
Just tried installing nodelink on unraid ver 6.3.5.
Looks like it installed OK but I can not get to webui.
How do I set it up.
P.S here is its log file
Log for_ NodeLink.html
Hi.
To Scyto: No I did not follow that. Are you familiar with unraid NAS?
               Process of creating an image and installing a docker is little different (built in, as in "automated")
              Oops forgot to include log file, it is now in first post.
               If I missing something or are mistaken then please forgive my ignorance as I'm not that familiar with linux.
Docker on anything. Unless you use --net=host you need to map the port with something like -p 8090:8090
Well I guess Nodlink docker install on unraid is not for me. It is beyond my knowledge.
I have plex and mindlna dockers running on unraid but the install was very straightforward without any knowledge of linux necessary.
Thanks anyway.
Hi.
Kind of.
I've installed the docker from template:https://github.com/jcreynolds/docker-containers
Do I run this command from command line using putty:
apt-get update && apt-get install -y wget mono-vbnc mono-complete
and then can I just type:
Net=host
Sorry for being such a pain.
Got it working.
Thanks guys.
what was the trick? missing step?
Kind of.
I've added a container variable : --net=host
