Homeseer's New 200 Series.
I like the color changing LEDs. That's one thing I wish/hope insteon does in the near future
Edited by lilyoyo1
I like the color changing LEDs. That's one thing I wish/hour insteon does in the near future
The color changing led's,  indicating the status of another device, seems very interesting, but will it work on ISY ???
Very true. If its simply changing parameters I don't see why not. Maybe via programs. I'd want it only for basic changes such as an emergency flashing the lights red.
Looks nice, but "Supports instant status when controlled locally," is problematic for programming based on the status of the dimmer.
How so?  That's basically exactly how the Insteon switches and dimmers work -- they only send a status report when locally controlled as well.
(I'm sorta bummed that they STILL don't have this in light almond color... perhaps I need to break out the plastic spray paint...)
Maybe there will finally be an alternative for the Fanlinc.... :)
Not so. If the status of an Insteon device is changed remotely, then a program can detect it.
Tell me exactly how that can happen outside of the ISY.
I see Stusviews point as I have a few programs that are based off the status of certain switches.
The problem with local only is that should your software turn it on (such as with an app) there will not be any update to any programs that are ran based off it's status
I'm confused now.  Let's try a few use-cases:
1a) User turns ON an Insteon switchlinc by pressing its paddle.
1b) User turns ON a HomeSeer Z-Wave switch by pressing its paddle.
Courtesy of "Instant Status", I think we can all agree that the effect is the same for both of the above, right?  The ISY will be instantly alerted that the paddle was depressed, and will take the appropriate action (run a program, execute a 5.x scene, etc.)  Does anyone disagree with my assessment of the behavior here?
2a) User turns ON an Insteon switchlinc by running a program on the ISY that directly turns the device ON.
2b) User turns ON a HomeSeer Z-Wave switch by running a program on the ISY that directly turns the device ON.
In this case, if a program running on the ISY causes the device to turn on, I would expect that the result would be the same -- the ISY should know that the device is now in an ON state.  Neither Insteon nor Z-Wave will send a "I just turned ON" message (i.e. "Instant Status") because by definition that is not how it works (we've discussed why this is the case frequently for new users who wonder why ISY programs won't trigger on "Control" when a scene is turned on).  Does anyone have evidence that Z-Wave and Insteon behave differently in this use-case?  Does this involve "Instant Status" at all?
3a) User turns ON an Insteon switchlinc by running a program on the ISY that turns a scene containing said switch ON.
3b) User turns ON a HomeSeer Z-Wave switch by running a program on the ISY that turns a scene containing said switch ON.
I maintain that this situation is exactly the same as 2a and 2b, above.  Perhaps the ISY does not do this with 5.0.11B -- but if so, I'd argue that it's a bug.  Does anyone have evidence that 5.0.11B doesn't work this way?  Anyone believe differently in terms of the expected outcome for this use case?
4a) User turns ON an Insteon switchlinc by sending an ON message from some other source than the ISY (a hub perhaps).
4b) User turns ON a HomeSeer Z-Wave switch by sending an ON message from some other source than the ISY (perhaps another z-wave controller).
This gets interesting.  In the case of Insteon, I know what happens -- the ISY is blissfully unaware of that change in state of the switchlinc (been there, done that, fixed it!).  In the case of Z-Wave, I do not expect that the device will proactively send an "Instant Status" message to the ISY -- but I may be wrong.  I also expect that the only way the device will respond to the other source for Z-Wave is if that other source is a secondary controller -- in which case, perhaps there's something in the protocol where the primary controller (the ISY) will "listen in" or will be notified.  So I anticipate that in the Z-Wave case (4b), the ISY will respond exactly as it does in the Insteon case (4a) -- specifically it won't respond in any way because it's completely unaware of the fact that something changed on the device. However, I admit to uncertainty regarding the Z-Wave secondary controller - perhaps the ISY actually *will* detect this one.
My conclusions -- with Instant Status, there is no situation where the ISY's idea of that device status at any point in time is different between Z-Wave and Insteon.  And if there is a difference (which is remotely possible), it would be that the ISY's idea of device status for Z-Wave would be more accurate in the case of another controller on the network.
So, perhaps Stusviews and those agreeing with him can clarify the points?  I think this is important -- and I'm concerned that I'm missing something in the argument and discussion.  What is it?
In a light switch/dimmer....
Status detects the state of the dimmer electronics no matter what changed it. Look in your ISY logs for status updates.
Switched detects the state of the paddle. ISY logs do not record this as it is not a status change. Look in the events.
It is two separate devices logically.
You haven't addressed the use cases above -- I'm aware of the status vs events thing, now what I need is for someone to explain how that's different with the HomeSeer device and how it affects the 4 use-cases I've outlined (and if there are other use cases that I'm not thinking of, that'd be useful as well).
I'm well into installing z-wave devices, and if there's something important I've overlooked, I need to to know it!
As it is famously written:
ALL CODE AND EVENTS IN THIS FIRMWARE--EVEN THOSE BASED ON REAL PROGRAMMERS--ARE ENTIRELY FICTIONAL. ALL CODERS ARE IMPERSONATED.....POORLY. THE FOLLOWING FIRMWARE CONTAINS COARSE LANGUAGE AND DUE TO ITS CONTENT IT SHOULD NOT BE VIEWED BY ANYONE.
mwester,
Your post indicates that you are using v.5+. I'm still at v4, so I can't comment on how Z-Wave devices work with v.5+.
In particular, with v.4+, which most users have installed, Z-Wave devices don't work as scene controllers nor can can Status be used as a program trigger for most Z-Wave device. Control can be a program trigger.
mwester,
Stu
Why is a such a sophisticated  user of ISY still using V4 ?  I am far from being as tech smart as you but I am very comfortable with 5.0.10 ...
Comfort is not my criterion. I have too many programs that matter a lot. And a wife the lets me know when something doesn't behave as expected or even desired (that's good, it's something I need to know).
I jump in and often have tested both Alpha and Beta computer software and hardware and, especially Insteon hardware, some of which never made it to market. Don't ask, I signed a privacy agreement.
  • 4 weeks later...
I got a notice this afternoon that this dimmer is now available.  I've got one on order, so we'll see how the ISY handles it.  This thing might actually have too many features, but we'll see how it goes.  And, no light almond...
HomeSeer HS-WD200+ Z-Wave Plus Scene Capable RGB Wall Dimmer
If only they had that in light almond...  :-)     I'm hoping my Insteon switchlincs stay working until they get a light almond version.
I'm going to put this one in my office where it won't be visible.  The almond is a kit, not a switch production run (or so it seems), so no reason there won't be a light almond one.
Specifications
    Compatible with US Z-Wave networks (908 MHz)
    120 VAC, 60Hz
    600 watt incandescent
    150 watt LED / CFL
    Supports Z-Wave Plus features
    Supports Z-Wave S2 security
    cUL, FCC, Z-Wave Plus certified
    Color: White. Almond color kit available.
Edited by Bumbershoot
I got my new HS-WD200+ in the mail yesterday, and I installed it this morning.
It reports three nodes in the AC (see screenshots).  Below is "Show All" output into the Event Viewer.  I don't see support in the ISY for the status reporting in the "Controller Indicator Color" feature.  Beyond that, it works as an on-off, but setting it to a brightness level < 100 causes significant flickering of the load on what appears to be Insteon traffic, and there's no discernable dimming of the load.  I don't understand it, but I'll fiddle with it more.
Sat 02/03/2018 07:55:24 : [UZW-CMD 51      ] [ZWCMD cmd.51]
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ] ----------------------------------------------
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ] ZW 014 Dimmer Switch
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ] ZW014_1 uid=14 type=4.17.1 mid=12 tid=17479 pid=12342
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ] Association Group ID 1
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x5E  V2   ZWAVEPLUS_INFO
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x86  V2   VERSION
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x85  V2   ASSOCIATION
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x59  V1   ASSOCIATION_GROUP_INFO
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x55  V2   TRANSPORT_SERVICE
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x72  V2   MANUFACTURER_SPECIFIC
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x5A  V1   DEVICE_RESET_LOCALLY
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x73  V1   POWERLEVEL
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x26  V4   SWITCH_MULTILEVEL
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x27  V1   SWITCH_ALL
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x70  V3   CONFIGURATION
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x5B  V3   CENTRAL_SCENE
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x2C  V1   SCENE_ACTUATOR_CONF
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x2B  V1   SCENE_ACTIVATION
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x9F  V1   SECURITY_2
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x6C  V1   SUPERVISION
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  x7A  V4   FIRMWARE_UPDATE_MD
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ]    -  xEF  V0   MARK
Sat 02/03/2018 07:55:30 : [ZW-SHOW         ] - Secure
Sat 02/03/2018 07:55:30 : [ZWAVE-TX        ] [010700800E0000E99F]                    REQ ZW_GET_ROUTING_INFO
Sat 02/03/2018 07:55:30 : [ZWAVE-TX        ] [010700800E0100EA9D]                    REQ ZW_GET_ROUTING_INFO
Sat 02/03/2018 07:55:31 : [ZWAVE-TX        ] [010700800E0001EB9C]                    REQ ZW_GET_ROUTING_INFO
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ] Node  14 - ZW 014 Dimmer Switch has the following neighbors
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ]    -          - Node   3 - ZW 003 Garbage Door Lock
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ]    - Repeater - Node   7 - ZW 007 Siren
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ]    - Repeater - Node  10 - ZW 010 Water Cop
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ]    - Repeater - Node  11 - ZW 011 West Garage Door
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ]    - Repeater - Node  12 - ZW 012 East Garage Door
Sat 02/03/2018 07:55:31 : [ZWAVE-TX ZW014_1] [85/05] Assoc Groupings Get ACK,AUTO,EXPLORE To=0x0E
Sat 02/03/2018 07:55:31 : [ZWAVE-RX ZW014_1] [85/06] Assoc Groupings Report supported=0x01 ACK,AUTO,EXPLORE From=0x0E
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ] Node  14 - ZW 014 Dimmer Switch has 1 association group
Sat 02/03/2018 07:55:31 : [ZWAVE-TX ZW014_1] [85/02] Assoc Get grp=0x01 ACK,AUTO,EXPLORE To=0x0E
Sat 02/03/2018 07:55:31 : [D2D EVENT   ] Event [n002_data1] [GV3] [47996] uom=25 prec=0
Sat 02/03/2018 07:55:31 : [  n002_data1]      GV3 47996 (uom=25 prec=0)
Sat 02/03/2018 07:55:31 : [ZWAVE-RX ZW014_1] [85/03] Assoc Report grp=0x01 max=0x05 frames=0x00 nodes=0x01 ACK,AUTO,EXPLORE From=0x0E
Sat 02/03/2018 07:55:31 : [ZW-SHOW         ]    Associations for group 001 of ZW014_1 ZW 014 Dimmer Switch
Sat 02/03/2018 07:55:32 : [ZW-SHOW         ]    Max Associations = 5
Sat 02/03/2018 07:55:32 : [ZW-SHOW         ]       - Node   1 - [This ISY]
Sat 02/03/2018 07:55:32 : [ZW-SHOW         ] ----------------------------------------------
Sat 02/03/2018 07:55:32 : [UZW-CMD 37      ] Show All Node Details : ZW014_1
Many thanks for this report.  I have ordered one but not yet received. The only reason I want(ed) this switch  is for the supposed status report from other Zwave devices.
I'd love to know id & when this is planned to work in ISY.
What firmware version are you running? When it comes to flickering, I would isolate the switch and bulb (hook it up to a pigtail and see how it dims that particular bulb to ensure its insteon traffic and not something else
Edited by lilyoyo1
I'm on 5.0.11C.  The bulbs are same Feit LEDs from Costco that I have all over the house.  I've never seen this problem with them, though this is the only Z-Wave dimmer I've installed.  I'll fiddle with it more next week, if I can get out of jury duty. :-P
