Jimbo.Automates Posted June 30, 2020 Author Share Posted June 30, 2020 netfaces should be installed on Polisy, is yours up to date?Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
Michel Kohanim Posted July 1, 2020 Share Posted July 1, 2020 @stre1026, I suspect you don't have the latest udx, otherwise you could simply click the reset button once and it would download all the necessary packages on its own. If you know how to use ssh: 1. ssh admin@<the ip address for your polisy> 2. default password is admin 3. sudo pkg update 4. sudo pkg upgrade 5. sudo reboot This should do it. With kind regards, Michel Link to comment Share on other sites More sharing options...
stre1026 Posted July 1, 2020 Share Posted July 1, 2020 @Michel Kohanim, I updated my Polisy via SSH but I'm still having the module missing error. Very odd. Says there are no updates left now. Anything else I should try? Welcome to Polisy! [admin@polisy ~]$ sudo pkg update Password: Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. [admin@polisy ~]$ sudo pkg upgrade Updating udi repository catalogue... udi repository is up to date. All repositories are up to date. Checking for upgrades (0 candidates): 100% Processing candidates (0 candidates): 100% Checking integrity... done (0 conflicting) Your packages are up to date. Link to comment Share on other sites More sharing options...
Michel Kohanim Posted July 2, 2020 Share Posted July 2, 2020 @stre1026, I will take a look. With kind regards, Michel Link to comment Share on other sites More sharing options...
Michel Kohanim Posted July 2, 2020 Share Posted July 2, 2020 @stre1026, Definitely and positively in the build. I think you may have inadvertently removed it. Please try: sudo pkg install py37-netifaces With kind regards, Michel Link to comment Share on other sites More sharing options...
stre1026 Posted July 3, 2020 Share Posted July 3, 2020 Hi Michel, Thank you. That worked. Very odd. I definitely didn’t remove it as I haven’t done anything under the hood except for set the IP address and manually try to install the module with pip. When installing the module, I got an error about a kernel mismatch and I cancelled. Then I tried again and it worked. I almost want to reset the whole thing and start over again as there seems like there may be an underlying firmware issue. Link to comment Share on other sites More sharing options...
Michel Kohanim Posted July 3, 2020 Share Posted July 3, 2020 @stre1026, Very odd. Can you please send me the output of: uname -a With kind regards, Michel Link to comment Share on other sites More sharing options...
stre1026 Posted July 3, 2020 Share Posted July 3, 2020 6 hours ago, Michel Kohanim said: @stre1026, Very odd. Can you please send me the output of: uname -a With kind regards, Michel Sure: 12.0-RELEASE-p10 Link to comment Share on other sites More sharing options...
Michel Kohanim Posted July 5, 2020 Share Posted July 5, 2020 @stre1026, Ah, way old !!!! Please backup your Polyglot and then do: curl -s https://pkg.isy.io/script/update121.sh | sudo bash This should upgrade you to the latest OS. With kind regards, Michel Link to comment Share on other sites More sharing options...
stre1026 Posted July 6, 2020 Share Posted July 6, 2020 4 hours ago, Michel Kohanim said: @stre1026, Ah, way old !!!! Please backup your Polyglot and then do: curl -s https://pkg.isy.io/script/update121.sh | sudo bash This should upgrade you to the latest OS. With kind regards, Michel Haha.. I told you I really didn't do anything to it since I received it I'm updating it now.. Link to comment Share on other sites More sharing options...
gviliunas Posted August 4, 2020 Share Posted August 4, 2020 Wireless Tag NS Crashed I was just checking my logs and noticed that the Wireless Tag Node Server crashed yesterday for no apparent reason. I restarted and everything is working normally now. Attached a log package. ISY 5.1.0 Polyglot: 2.2.9-5 Wireless Tag NS v. 2.1.17 WirelessTag_logs_2020-8-4_082045.zip Link to comment Share on other sites More sharing options...
gviliunas Posted August 4, 2020 Share Posted August 4, 2020 Smelly errors from type 107 tags When starting the Wireless Tag NS v.2.1.17 I always see this series of unknown tag parameter errors from my type 107 tags. The error message states that these are "ignored." Reporting here to verify there is no issue. Tag 107 non-VOC tag.txt Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted August 9, 2020 Author Share Posted August 9, 2020 On 8/4/2020 at 8:32 AM, gviliunas said: Smelly errors from type 107 tags When starting the Wireless Tag NS v.2.1.17 I always see this series of unknown tag parameter errors from my type 107 tags. The error message states that these are "ignored." Reporting here to verify there is no issue. Tag 107 non-VOC tag.txt 2.99 kB · 3 downloads This is normal, the node server does not support the VOC in the new tags. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted August 9, 2020 Author Share Posted August 9, 2020 On 8/4/2020 at 8:27 AM, gviliunas said: Wireless Tag NS Crashed I was just checking my logs and noticed that the Wireless Tag Node Server crashed yesterday for no apparent reason. I restarted and everything is working normally now. Attached a log package. ISY 5.1.0 Polyglot: 2.2.9-5 Wireless Tag NS v. 2.1.17 WirelessTag_logs_2020-8-4_082045.zip 62.96 kB · 1 download This was a bug in the 'Set Light' function that caused the crash. Version 2.0.20 fixes this issue, it won't be in the store for about an hour. Link to comment Share on other sites More sharing options...
tmorse305 Posted August 10, 2020 Share Posted August 10, 2020 @Jimbo, I just upgraded to 2.0.20. I noticed on one of my tags that the Out of range flag is True even though it's updating regularly. The tag type is 26, but I have other 26's that are working correctly. I can't be sure that it's related to the upgrade, it might have been that way before. How do I resolve that? Thank you. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted August 10, 2020 Author Share Posted August 10, 2020 33 minutes ago, tmorse305 said: @Jimbo, I just upgraded to 2.0.20. I noticed on one of my tags that the Out of range flag is True even though it's updating regularly. The tag type is 26, but I have other 26's that are working correctly. I can't be sure that it's related to the upgrade, it might have been that way before. How do I resolve that? Hi, enable debug mode on the controller node, then restart the nodeserver and let it run for a while, then in the Polyglot UI go to the nodeserver Log page and Generate Log Package and PM that to me. Link to comment Share on other sites More sharing options...
tmorse305 Posted August 10, 2020 Share Posted August 10, 2020 2 hours ago, Jimbo said: Hi, enable debug mode on the controller node, then restart the nodeserver and let it run for a while, then in the Polyglot UI go to the nodeserver Log page and Generate Log Package and PM that to me. I followed these instructions but pressing the 'Download Log Package' does not seem to do anything. Where is the file downloaded to? I checked the log folder within the WT NS but the newest file in there is 3 days old. Edit: I rebooted RPi running Polyglot, I had some weird logging behavior happening. After I rebooted I found a file debug.log in the log folder. It appears to be recent log info. Sent to you via PM. Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted August 11, 2020 Author Share Posted August 11, 2020 I followed these instructions but pressing the 'Download Log Package' does not seem to do anything. Where is the file downloaded to? I checked the log folder within the WT NS but the newest file in there is 3 days old. Edit: I rebooted RPi running Polyglot, I had some weird logging behavior happening. After I rebooted I found a file debug.log in the log folder. It appears to be recent log info. Sent to you via PM. Download log package should download a file in your browser to your downloads folder?Sent from my Pixel 3 XL using Tapatalk Link to comment Share on other sites More sharing options...
tmorse305 Posted August 11, 2020 Share Posted August 11, 2020 10 minutes ago, Jimbo said: Download log package should download a file in your browser to your downloads folder? Sent from my Pixel 3 XL using Tapatalk That's what I thought but no luck. I tried Chrome and Firefox but same result Link to comment Share on other sites More sharing options...
Jimbo.Automates Posted August 11, 2020 Author Share Posted August 11, 2020 7 hours ago, tmorse305 said: @Jimbo, I just upgraded to 2.0.20. I noticed on one of my tags that the Out of range flag is True even though it's updating regularly. The tag type is 26, but I have other 26's that are working correctly. I can't be sure that it's related to the upgrade, it might have been that way before. How do I resolve that? Thank you. Should be fixed in 2.0.21 which should be in the store within an hour. Looks like they changed a param name in the API, or it's always been broken. I can't fully test since my ISY is currently down for another reason, but the polyglot log looks good. Link to comment Share on other sites More sharing options...
tmorse305 Posted August 11, 2020 Share Posted August 11, 2020 Thanks @Jimbo, 2.0.21 has fixed the problem. Link to comment Share on other sites More sharing options...
rlebel Posted August 28, 2020 Share Posted August 28, 2020 Thanks for this great node server! I have my tags set up sending data to the ISY. I want to create a condition for a light sensor when its value is greater than 20,000 lux but I'm limited to 100.0. What to do? Link to comment Share on other sites More sharing options...
oskrypuch Posted August 28, 2020 Share Posted August 28, 2020 I just discovered this thread and hardware, but have some very basic questions. I would like to get outside temperature and outside ambient light into my ISY. From my reading, that would mean I need: 1) The wireless sensor tag, which appears to be battery run only. 2) Ethernet Tag Manager 3) A tag account (where I can access the data from an app) 4) This cool node server software 5) the Polisy (or equivalent) hardware -- the ISY portal does not support this? Correct? * Orest Link to comment Share on other sites More sharing options...
larryllix Posted August 28, 2020 Share Posted August 28, 2020 25 minutes ago, oskrypuch said: I just discovered this thread and hardware, but have some very basic questions. I would like to get outside temperature and outside ambient light into my ISY. From my reading, that would mean I need: 1) The wireless sensor tag, which appears to be battery run only. 2) Ethernet Tag Manager 3) A tag account (where I can access the data from an app) 4) This cool node server software 5) the Polisy (or equivalent) hardware -- the ISY portal does not support this? Correct? * Orest Correct. ISY Portal is not related. Polyglot (NS manager) can exist on the UDI cloud server, RPi, running Polyglot, or UDI polisy box, running PolyGlot. I use the kumoapp software for ISY Rest injection into variables. I don't know what Orest is. Link to comment Share on other sites More sharing options...
oskrypuch Posted August 28, 2020 Share Posted August 28, 2020 17 minutes ago, larryllix said: Correct. ISY Portal is not related. Polyglot (NS manager) can exist on the UDI cloud server, RPi, running Polyglot, or UDI polisy box, running PolyGlot. I use the kumoapp software for ISY Rest injection into variables. I don't know what Orest is. Thanks. Orest is ME. * Orest Link to comment Share on other sites More sharing options...
