Add tstat from...a distance?
What is the best practice to add a tsar that isn't seen by isy?  I have 1 tstat 10' away from isy and a lock same already in. A siren is included but 40' away and had sketchy comms. New tstat is about 15' from siren.
Any thoughts?
Thx, Jeff
If the device you are adding supports network wide inclusion then it can be added through a supported repeater following its instructions..  If not then you have to bring your device and isy within range of each other temporarily for initial inclusion.  After that it can be placed back in correct spot and will work as normal with  z wave signals through repeaters.
