NodeLink and Mono Version
Is there any issue running NodeLink under Mono version 5.16.0.179?
After doing an update to this version, I couldn't get NodeLink to run. After much difficulty, I decided to reinstall Mono, however, I can't get past the following:
Mono precompiling /usr/lib/mono/4.5/Microsoft.CodeAnalysis.CSharp.dll for arm...
Thanks for any help.
Dennis
Thank you, I wasn't able to understand what I did wrong.
Is there a way to delete current version and install the previous one?
You likely don't have a device that uses an http client.  There's a pretty bad bug in their timespan implementation.  Surprised it made it through testing.
Until mono releases a fix I did this:
- Commented out the repo in /etc/apt/sources.list.d/mono-official.list
- Ran sudo apt update
- Removed mono (sudo apt remove --purge --auto-remove mono-runtime)
- Installed raspbian version (sudo apt-get install mono-vbnc mono-complete)
This brings you back to 4.6.2.7.  Not ideal but it works.
Once it's fixed you'd just remove the mono-official comment and apt update.
Thank you! Following your instructions, I was able to revert back to Mono v4.6.2.7 and get NodeLink running again.
I did have an extra step to perform however. Apparently, the error (previous post) was preventing me from removing mono-runtime. I had to remove the files inside /var/lib/dpkg/updates first. Once I did that everything else went as you described.
Thanks again for your assistance.
Edited by DennisC
Typo
As a matter of interest what RPi version are you installing to?
4.14.71, latest build.
LOL. I wanted the RPi model, not the firmware version. I assume it is an RPi ??
Changed Q to positive
Sorry for the stupid question but can you give an example of an http client you were referring to ?
Tim
Tim
Mono can use http:// to talk to the ISY and nodelink supported devices on local APIs.
Examples of devices that nodelink supports on a local api via http: includes the rainmachine and Venstar Colortouch Thermostats.
Paul
Edited by paulbates
I reinstalled the broken 5.16.0.179 to test out using the interpreter instead of JIT (saw it work for someone on a forum).  FYI, it doesn't work.
Another forum mentioned that this is RPi specific and that it has something to do with the complete library (which didn't make a lot of sense to me, but I figured I'd try).  So I removed all of mono again and reinstalled with just "sudo apt install mono-vbnc libmono-system-net-http*" and all is running fine now.
If you've got a few minutes and some bravery it could be worth trying.  Otherwise I noticed the bug made it to mono's "bug week" so it'll be fixed in the next minor release.
I fear I'm not knowledgeable enough to recover if I get in to trouble. I think I will wait until it's proven to be fixed. I like it when things work. Lol
Thanks for keeping me informed.
If things are working, you can continue to upgrade nodelink and not mono. I'm sure not upgrading mono.
Paul
This worked great for me. Thanks io_guy!
Question, once the bug is fixed do we revert back to the original package and upgrade or stick with this package just installed?
Edit: I noticed I am getting "TCC Login Error: The socket is not connected" errors. Could it be this version of mono?
Edited by TJF1960
Paul
I'm running the affected version of Mono (version: 5.16.0.179) on an RPi, and my RainMachine is connecting to NodeLink over http -- "Use HTTPS" is NOT checked in the NodeLink configuration.  It's working...  ?
I've certainly got no clue.
I'm running the affected version of Mono (version: 5.16.0.179) on an RPi, and my RainMachine is connecting to NodeLink over http -- "Use HTTPS" is NOT checked in the NodeLink configuration.  It's working...  [emoji2957]
Yep, and I believe you. But as a traveler with a fully locked down firewall config, I can’t risk knocking out ‘prod’ for no substantive improvements. I only update my pi once a year anyway, or if there is a significant relevant security patch.
Paul
Been watching the mono bug report, looks like it's nicely broken.
If you do run 5.16.0.179 you can add a command line option "-O=-aot" to resolve the issue.  so "mono -O=-aot NodeLink.exe".
