io_guy Posted October 30, 2019 Author Share Posted October 30, 2019 No, now just try running NodeLink again. The seg fault is a missing package. My Pi has a ton of crap already installed so clearly I need to add a package to the install script for a fresh install. Just trying to figure out which one(s). Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 30, 2019 Share Posted October 30, 2019 1 hour ago, io_guy said: No, now just try running NodeLink again. The seg fault is a missing package. My Pi has a ton of crap already installed so clearly I need to add a package to the install script for a fresh install. Just trying to figure out which one(s). not sure if this is exactly the correct way, but... pi@raspberrypi:~ $ dotnet /home/pi/node/NodeLink.dll Segmentation fault Is that the correct way to run it? Quote Link to comment Share on other sites More sharing options...
io_guy Posted October 30, 2019 Author Share Posted October 30, 2019 Yep, next try sudo apt install libunwind8 Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 30, 2019 Share Posted October 30, 2019 4 minutes ago, io_guy said: Yep, next try sudo apt install libunwind8 No luck with that one, segmentation fault Quote Link to comment Share on other sites More sharing options...
io_guy Posted October 30, 2019 Author Share Posted October 30, 2019 K, gimme a couple hours. I'll do a fresh install here and figure it out. Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 30, 2019 Share Posted October 30, 2019 1 minute ago, io_guy said: K, gimme a couple hours. I'll do a fresh install here and figure it out. I appreciate your time! Quote Link to comment Share on other sites More sharing options...
io_guy Posted October 30, 2019 Author Share Posted October 30, 2019 Hmm, I have a feeling your install is old (stretch). Install the latest buster lite. Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 30, 2019 Share Posted October 30, 2019 7 minutes ago, io_guy said: Hmm, I have a feeling your install is old (stretch). Install the latest buster lite. Sorry, my previous post about a new install incorrectly said it was stretch. its actually buster (lite, I believe, as I have no GUI) pi@raspberrypi:~ $ cat /etc/os-release PRETTY_NAME="Raspbian GNU/Linux 10 (buster)" NAME="Raspbian GNU/Linux" VERSION_ID="10" VERSION="10 (buster)" VERSION_CODENAME=buster ID=raspbian ID_LIKE=debian HOME_URL="http://www.raspbian.org/" SUPPORT_URL="http://www.raspbian.org/RaspbianForums" BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs" Quote Link to comment Share on other sites More sharing options...
io_guy Posted October 30, 2019 Author Share Posted October 30, 2019 I just did a lite install and ran the script, NodeLink started right up. Try deleting NodeLink.dll and rerunning the script. Maybe it's corrupt. Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 30, 2019 Share Posted October 30, 2019 14 minutes ago, io_guy said: I just did a lite install and ran the script, NodeLink started right up. Try deleting NodeLink.dll and rerunning the script. Maybe it's corrupt. Bare with me - what am I doing wrong with the command: pi@raspberrypi:~ $ rm /home/pi/node/NodeLink.dll rm: cannot remove '/home/pi/node/NodeLink.dll': No such file or directory Quote Link to comment Share on other sites More sharing options...
io_guy Posted October 30, 2019 Author Share Posted October 30, 2019 no idea. sudo? ls /home/pi/node Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 31, 2019 Share Posted October 31, 2019 pi@raspberrypi:~ $ sudo rm /home/pi/node/NodeLink.dll rm: cannot remove '/home/pi/node/NodeLink.dll': No such file or directory I'm starting to suspect the SD card because I had the segmentation problem when I was on Rasbpian 8. I was resisting the idea because I didn't think the install would work if the card is faulty... Quote Link to comment Share on other sites More sharing options...
io_guy Posted October 31, 2019 Author Share Posted October 31, 2019 Tend to agree. Just had to replace my Pi SD card last week. Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 31, 2019 Share Posted October 31, 2019 Ok, will do tomorrow sometime. Thanks for your help with this! Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 31, 2019 Share Posted October 31, 2019 (edited) So, got a brand new SD card, mounted the buster image and started up the pi. It ran through a bunch of stuff, for the last 45 mins or so it shows this: "[ OK ] Started Daily apt upgrade and clean activities" with a blinking cursor... Edited October 31, 2019 by Maresend Quote Link to comment Share on other sites More sharing options...
Maresend Posted October 31, 2019 Share Posted October 31, 2019 So even with the brand new SD card and several attempts, still getting segmentation fault. I'm thinking the Pi itself is somehow faulty. Its quite old and had been sitting in my garage for a couple years. I'll try a new one... Quote Link to comment Share on other sites More sharing options...
Maresend Posted November 2, 2019 Share Posted November 2, 2019 Fired up a new Pi3 today, Nodelink started immediately after running your script so i'm up and running! Sorry for wasting your time with a bum pi io_guy and bumbershoot! Quote Link to comment Share on other sites More sharing options...
Whitehambone Posted November 4, 2019 Share Posted November 4, 2019 Logged into NodeLink and seen this. Is this a problem with my internet connection, a update bug in v0.10.1, or is the server down? 2019-11-04 09:10:09 - Auto-Update: Error updating file: The remote server returned an error: (404) Not Found. Quote Link to comment Share on other sites More sharing options...
io_guy Posted November 4, 2019 Author Share Posted November 4, 2019 Been seeing a few of those as well, I think the update server may be having some problems. Quote Link to comment Share on other sites More sharing options...
glarsen Posted November 5, 2019 Share Posted November 5, 2019 (edited) I just ran the install script manually and updated to 0.10.2 cleanly. Edited November 5, 2019 by glarsen Quote Link to comment Share on other sites More sharing options...
io_guy Posted November 5, 2019 Author Share Posted November 5, 2019 In 0.10.3 I'm adding a button to manually check for updates. Should be released this weekend. Quote Link to comment Share on other sites More sharing options...
brians Posted November 6, 2019 Share Posted November 6, 2019 I just moved over to a pi from a Windows 7 VM I have been using for a while...all went perfect - Raspberry Pi 3 B+ Buster Lite. I just copied over the config.xml (I also run Polyglot on it with no issues in case people want to know if can run both). Quote Link to comment Share on other sites More sharing options...
apostolakisl Posted December 14, 2019 Share Posted December 14, 2019 Anyone running nodelink on Polisy? Quote Link to comment Share on other sites More sharing options...
Bumbershoot Posted December 14, 2019 Share Posted December 14, 2019 51 minutes ago, apostolakisl said: Anyone running nodelink on Polisy? @io_guy is, though I don't think he's released an install script for the Polisy as of yet: Quote Link to comment Share on other sites More sharing options...
io_guy Posted December 15, 2019 Author Share Posted December 15, 2019 Polisy is waiting for UDI. They are creating required packages to run NodeLink. I run it successfully but I enable the regular BSD repo and install the required packages. Quote Link to comment Share on other sites More sharing options...
