Anyone know of a plug in motion sensor?
Hello,
Ive been using Insteon motion sensors for years and though they work well, I’m sick and tired of changing batteries.  Does anyone know of a decent plug in motion sensor compatible with the ISY.
Chuck
The Insteon Motion Sensor II has a USB powered option.  Otherwise, if you use Z-Wave, the Aeotec Multisensor 6 works very nicely, though it will not turn a light as quickly as an Insteon sensor, as there are no direct links.
I've been quite enjoying my z-wave occupancy sensors -- they're wired in (replacing the light switch), but actually give very good coverage of the areas I need covered in the basement.  And while I just use the occupancy mode, they DO work as motion sensors (signaling motion to the ISY when detected).
Brand?  Make/Model?
4 minutes ago, lilyoyo1 said:
Ge has one. A dimmer and a relay version
I thought that was just a motion sensor?
So this also acts as a physical switch to the wired load independent from the ISY controller ?  If so, which part acts as the switch?
Thanks...
Basically, the device functions as a normal occupancy switch -- it turns on the load if it senses motion in the field of view.  There's a paddle switch for manual on/off, if desired.  If you add it to a z-wave controller, like the ISY, it will respond to on/off (or dim, if you get the dimmer version) commands -- and it'll send events upon detecting motion (in addition to turning on the local load).
(I could do without the blasted blue LED, though - why do manufacturers insist on using those horrible eye-blinding-blue leds on everything???  I'll give Insteon credit for having avoided the temptation to "blue" everything, and instead going with a softer white led...)
Edited by mwester
  • 3 weeks later...
The other option, if you are a bit more technically inclined and not soldering challenged, is to get a 9vdc power supply and connectors.  I haven't actually done this yet, but I'm planning on it.  The Insteon motion sensor is a pigtail type of battery connector, so these should plug right in.  I guess you have to reverse the polarity to get the gender right.  But I don't see any reason that it would not work.
https://smile.amazon.com/Pangda-Connection-Battery-Connector-Buckles/dp/B072Z91Y9H/ref=sr_1_1_sspa?crid=2280GDDR283KR&keywords=9+volt+battery+connectors&qid=1560085607&s=gateway&sprefix=9+volt%2Caps%2C157&sr=8-1-spons&psc=1
Thanks for all of the great suggestions everyone.  I was hoping to find a simple motion detector I could actually plug into an outlet but apparently they don’t currently exist.
Edited by ahwman
Ahh... So this is actually what you're looking for?
https://shop.homeseer.com/collections/sensors/products/homeseer-hsm200-z-wave-multi-sensor?variant=23364824134
Ok, that's pretty cool.  Does it work with ISY?
Unfortunately, it looks like no one has stock of these.  I wonder if the they’ve been discontinued?
  • 6 months later...
I have been using the echo flex with motion sensor and an Alexa routine to update a state variable in the ISY (exposed via the portal as a dimmable light)..... my experience is a 1-2 second delay, but I haven't timed it.  But it works and it doesn't need batteries.  Cheaper than most other options (especially on black Friday).
