Aeotec Siren 6
Has anybody had luck with adding the Aeotec Siren 6 to their ISY? Mine doesn't seem to work properly.
SO I made sure I was on 5.0.15A, added the device again, and it just shows up at 9 "AV Control Point" devices with no parameters or display options in the ISY. Is that expected?
Yeah, I even went so far to install it on a PC I've never used ISY on. This time I had some buttons (On, off, dim, brighten, etc) and an "On" parameter, but that was it
  • 2 months later...
I am having the same problem. When I include an aeotec siren 6, it shows up as ZW051 AV Control Point with no status parameters. Eight more devices are present, named ZW051.1 AV Control Panel thru ZW051.8 AV Control Panel. Each of those 8 devices has no status parameters. I am running v.5.0.15A
  • 3 weeks later...
Same issue here.  Running firmware 5.0.15A and simply see 9 "AV Control Point"  devices with no parameters other than 'query' and, in one case, 'write changes'.
Has anyone figured out the issue?
  • 2 months later...
Any updates on this? I am having the same problem.
Here is my event log from when I included the siren:
Tue 12/10/2019 04:10:14 PM : Z-Wave device detected, retrieving info 2
Tue 12/10/2019 04:10:14 PM : Z-Wave device detected, retrieving info 3
Tue 12/10/2019 04:10:14 PM : Z-Wave device detected, retrieving info 5
Tue 12/10/2019 04:10:15 PM : Adding Z-Wave devices stopped
Tue 12/10/2019 04:10:15 PM : Exchanging data with secure Z-Wave device 4 of type 4.3.1
Tue 12/10/2019 04:10:15 PM : Adding secure Z-Wave device
Tue 12/10/2019 04:10:17 PM : Adding ISY node(s) for new Z-Wave device 4 type 4.3.1
Tue 12/10/2019 04:10:36 PM : Adding additional nodes for new Z-Wave device 4
Tue 12/10/2019 04:10:36 PM :   ...addNodes(uid=4,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:10:36 PM :   ...addNodes(uid=4,VERSION,cc=134,ver=0,sec=F)
Tue 12/10/2019 04:10:37 PM :   ...addNodes(uid=4,CONFIGURATION,cc=112,ver=0,sec=F)
Tue 12/10/2019 04:10:38 PM :   ...addNodes(uid=4,MANUFACTURER_SPECIFIC,cc=114,ver=0,sec=F)
Tue 12/10/2019 04:10:38 PM :   ...addNodes(uid=4,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=F)
Tue 12/10/2019 04:10:39 PM :   ...addNodes(uid=4,ASSOCIATION,cc=133,ver=0,sec=F)
Tue 12/10/2019 04:10:40 PM :   ...addNodes(uid=4,POWERLEVEL,cc=115,ver=0,sec=F)
Tue 12/10/2019 04:10:41 PM :   ...addNodes(uid=4,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=F)
Tue 12/10/2019 04:10:41 PM :   ...addNodes(uid=4,MULTI_CHANNEL,cc=96,ver=0,sec=F)
Tue 12/10/2019 04:10:42 PM :   ...addNodes(uid=4,DEVICE_RESET_LOCALLY,cc=90,ver=0,sec=F)
Tue 12/10/2019 04:10:43 PM :   ...addNodes(uid=4,TRANSPORT_SERVICE,cc=85,ver=0,sec=F)
Tue 12/10/2019 04:10:50 PM : [ZW-TX-FAILED] enc=Ok uid=4.0 cmd=0x86.13 VERSION
Tue 12/10/2019 04:10:51 PM :   ...addNodes(uid=4,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:10:52 PM :   ...addNodes(uid=4,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:10:53 PM :   ...addNodes(uid=4,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:10:53 PM :   ...addNodes(uid=4,FIRMWARE_UPDATE_MD,cc=122,ver=0,sec=F)
Tue 12/10/2019 04:10:54 PM :   ...addNodes(uid=4,NOTIFICATION,cc=113,ver=0,sec=F)
Tue 12/10/2019 04:10:57 PM :   ...addNodes(uid=4,,cc=121,ver=0,sec=F)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,CONFIGURATION,cc=112,ver=1,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,VERSION,cc=134,ver=2,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,ASSOCIATION_GROUP_INFO,cc=89,ver=1,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,ASSOCIATION,cc=133,ver=2,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,POWERLEVEL,cc=115,ver=1,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,MULTI_CHANNEL,cc=96,ver=4,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=3,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,DEVICE_RESET_LOCALLY,cc=90,ver=1,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,FIRMWARE_UPDATE_MD,cc=122,ver=4,sec=T)
Tue 12/10/2019 04:10:58 PM :   ...addNodes(uid=4,NOTIFICATION,cc=113,ver=8,sec=T)
Tue 12/10/2019 04:11:01 PM :   ...addNodes(uid=4,,cc=121,ver=1,sec=T)
Tue 12/10/2019 04:11:05 PM : Adding ISY node(s) for new Z-Wave device 4.1 type 4.3.1
Tue 12/10/2019 04:11:09 PM : Adding additional nodes for new Z-Wave device 4.1
Tue 12/10/2019 04:11:09 PM :   ...addNodes(uid=4.1,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:11:10 PM :   ...addNodes(uid=4.1,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:11:10 PM :   ...addNodes(uid=4.1,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:11:11 PM :   ...addNodes(uid=4.1,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:11:12 PM :   ...addNodes(uid=4.1,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:11:12 PM :   ...addNodes(uid=4.1,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:11:18 PM : [ZW-TX-FAILED] enc=Fail uid=4.0 cmd=0x86.13 VERSION
Tue 12/10/2019 04:11:19 PM :   ...addNodes(uid=4.1,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:11:19 PM :   ...addNodes(uid=4.1,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:11:21 PM :   ...addNodes(uid=4.1,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:11:25 PM : Adding ISY node(s) for new Z-Wave device 4.2 type 4.3.1
Tue 12/10/2019 04:11:31 PM : [ZW-TX-FAILED] enc=Ok uid=4.2 cmd=0x8E.05 MULTI_CHANNEL_ASSOCIATION
Tue 12/10/2019 04:11:36 PM : Adding additional nodes for new Z-Wave device 4.2
Tue 12/10/2019 04:11:36 PM :   ...addNodes(uid=4.2,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:11:37 PM :   ...addNodes(uid=4.2,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:11:37 PM :   ...addNodes(uid=4.2,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:11:38 PM :   ...addNodes(uid=4.2,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:11:39 PM :   ...addNodes(uid=4.2,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:11:39 PM :   ...addNodes(uid=4.2,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:11:40 PM :   ...addNodes(uid=4.2,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:11:41 PM :   ...addNodes(uid=4.2,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:11:50 PM : [ZW-TX-FAILED] enc=Ok uid=4.2 cmd=0x71.04 NOTIFICATION
Tue 12/10/2019 04:11:51 PM :   ...addNodes(uid=4.2,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:11:55 PM : Adding ISY node(s) for new Z-Wave device 4.3 type 4.3.1
Tue 12/10/2019 04:12:00 PM : Adding additional nodes for new Z-Wave device 4.3
Tue 12/10/2019 04:12:00 PM :   ...addNodes(uid=4.3,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:12:00 PM :   ...addNodes(uid=4.3,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:12:01 PM :   ...addNodes(uid=4.3,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:12:02 PM :   ...addNodes(uid=4.3,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:12:02 PM :   ...addNodes(uid=4.3,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:12:03 PM :   ...addNodes(uid=4.3,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:12:04 PM :   ...addNodes(uid=4.3,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:12:04 PM :   ...addNodes(uid=4.3,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:12:07 PM :   ...addNodes(uid=4.3,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:12:11 PM : Adding ISY node(s) for new Z-Wave device 4.4 type 4.3.1
Tue 12/10/2019 04:12:15 PM : Adding additional nodes for new Z-Wave device 4.4
Tue 12/10/2019 04:12:15 PM :   ...addNodes(uid=4.4,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:12:16 PM :   ...addNodes(uid=4.4,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:12:16 PM :   ...addNodes(uid=4.4,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:12:17 PM :   ...addNodes(uid=4.4,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:12:18 PM :   ...addNodes(uid=4.4,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:12:18 PM :   ...addNodes(uid=4.4,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:12:19 PM :   ...addNodes(uid=4.4,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:12:20 PM :   ...addNodes(uid=4.4,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:12:22 PM :   ...addNodes(uid=4.4,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:12:26 PM : Adding ISY node(s) for new Z-Wave device 4.5 type 4.3.1
Tue 12/10/2019 04:12:30 PM : Adding additional nodes for new Z-Wave device 4.5
Tue 12/10/2019 04:12:30 PM :   ...addNodes(uid=4.5,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:12:31 PM :   ...addNodes(uid=4.5,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:12:32 PM :   ...addNodes(uid=4.5,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:12:32 PM :   ...addNodes(uid=4.5,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:12:33 PM :   ...addNodes(uid=4.5,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:12:34 PM :   ...addNodes(uid=4.5,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:12:34 PM :   ...addNodes(uid=4.5,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:12:35 PM :   ...addNodes(uid=4.5,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:12:38 PM :   ...addNodes(uid=4.5,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:12:41 PM : Adding ISY node(s) for new Z-Wave device 4.6 type 4.3.1
Tue 12/10/2019 04:12:46 PM : Adding additional nodes for new Z-Wave device 4.6
Tue 12/10/2019 04:12:46 PM :   ...addNodes(uid=4.6,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:12:47 PM :   ...addNodes(uid=4.6,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:12:48 PM :   ...addNodes(uid=4.6,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:12:48 PM :   ...addNodes(uid=4.6,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:12:49 PM :   ...addNodes(uid=4.6,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:12:50 PM :   ...addNodes(uid=4.6,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:12:50 PM :   ...addNodes(uid=4.6,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:12:51 PM :   ...addNodes(uid=4.6,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:12:53 PM :   ...addNodes(uid=4.6,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:12:57 PM : Adding ISY node(s) for new Z-Wave device 4.7 type 4.3.1
Tue 12/10/2019 04:13:01 PM : Adding additional nodes for new Z-Wave device 4.7
Tue 12/10/2019 04:13:01 PM :   ...addNodes(uid=4.7,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:13:02 PM :   ...addNodes(uid=4.7,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:13:03 PM :   ...addNodes(uid=4.7,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:13:03 PM :   ...addNodes(uid=4.7,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:13:04 PM :   ...addNodes(uid=4.7,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:13:05 PM :   ...addNodes(uid=4.7,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:13:05 PM :   ...addNodes(uid=4.7,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:13:06 PM :   ...addNodes(uid=4.7,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:13:08 PM :   ...addNodes(uid=4.7,,cc=121,ver=0,sec=T)
Tue 12/10/2019 04:13:12 PM : Adding ISY node(s) for new Z-Wave device 4.8 type 4.3.1
Tue 12/10/2019 04:13:16 PM : Adding additional nodes for new Z-Wave device 4.8
Tue 12/10/2019 04:13:16 PM :   ...addNodes(uid=4.8,ZWAVEPLUS_INFO,cc=94,ver=0,sec=F)
Tue 12/10/2019 04:13:17 PM :   ...addNodes(uid=4.8,SECURITY,cc=152,ver=0,sec=F)
Tue 12/10/2019 04:13:17 PM :   ...addNodes(uid=4.8,SECURITY_2,cc=159,ver=0,sec=F)
Tue 12/10/2019 04:13:18 PM :   ...addNodes(uid=4.8,SUPERVISION,cc=108,ver=0,sec=F)
Tue 12/10/2019 04:13:19 PM :   ...addNodes(uid=4.8,ASSOCIATION,cc=133,ver=0,sec=T)
Tue 12/10/2019 04:13:19 PM :   ...addNodes(uid=4.8,ASSOCIATION_GROUP_INFO,cc=89,ver=0,sec=T)
Tue 12/10/2019 04:13:20 PM :   ...addNodes(uid=4.8,MULTI_CHANNEL_ASSOCIATION,cc=142,ver=0,sec=T)
Tue 12/10/2019 04:13:21 PM :   ...addNodes(uid=4.8,NOTIFICATION,cc=113,ver=0,sec=T)
Tue 12/10/2019 04:13:23 PM :   ...addNodes(uid=4.8,,cc=121,ver=0,sec=T)
Update:
Interestingly, having left it overnight, this morning all nine nodes now show as ON/OFF nodes (previously they showed current, voltage and power). I still can't control them, but now they have ON/OFF controls - I get "communication failed" messages if I try to turn them ON or OFF, but it looks more promising.
I'll fiddle with them some more, see what happens. Anyone know what they are supposed to look like?
Second Update, ran a "Synchronize" (not sure what that does), and it removed the controls, so now there is no ON/OFF controls, just 9 AV nodes that I can't do anything with.
I guess I'll just have to wait for 5.0.16B to be released and see if that solves the issue.
Edited by Niick_W
Updated observations.
  • 2 months later...
On 7/12/2019 at 12:12 PM, Michel Kohanim said:
@csteenwyk,
You need firmware 5.0.15A.
Was looking for a z-wave siren to add and was curious if the Siren 6 is functional with the latest ISY firmware yet.
