Module not responding to scene
I have a scene (Movie Done) in which one of the plug-in dimmers (Insteon) is not responding to the scene. Instead of ramping up to 98%, it changes to 6%. Most of the time I use voice commands to control the scene. The program log shows the lamp @ 98%, then immediately two commands (program?) & the light level changes to 6%. Don’t have any idea where the commands with a value? of 15 are coming from. Any ideas?
Movie Mini Remote - [ID 006B][Parent 0001]
        Control '.Fam Rm Rem - E (Movie Time)' is switched On
    And Control '.Fam Rm Rem - E (Movie Time)' is not switched Off
        Wait  4 seconds
        Set Scene 'Movie Time' On
        Wait  4 minutes
        Set 'ZW 003 TV back light' 46%
        Set 'ZW 005 Kitchen Cabinet Light' 30%
        Wait  3 seconds
        Set Scene 'Movie Done' On
        Wait  6 minutes
        Set 'ZW 003 TV back light' Off
        Set 'ZW 005 Kitchen Cabinet Light' 100%
        Set 'China Closet Lamp' Off
        Wait  1 hour 23 minutes and 36 seconds (Random)
        Set 'Corner Cabinet Lamp LampLinc' Off
        Set 'Kitchen Island ToggleLink Dim' Fade Down
Log File after running Movie Done scene.
Edited by edgar
Add info
Sometimes after a lot of time, or brownout/blackouts, Insteon modules lose their settings.
I suggest right-click on the device in the admin console and picking "Restore Device". If that doesn't do it, factory reset the device, then Restore Device
Paul
Paul
I tried your suggestion a couple of times with no luck. I believe the problem is related to the two "On" commands received after the module  reaches 98%, per the scene settings. Not sure where the On commands are coming from.
6 minutes ago, paulbates said:
Ok. If I'm reading the log right, the source for the ons is a program or programs.. log column second from the right.  Are there other programs associated with that lamp?
Paul
Yes, there other programs associated with that lamp, but none that should run every-time that when that scene is "called"; specially sending the 6% level command to that lamp. I will take a break then check the programs again to see if I'm missing something. Thanks for your input.
A suggestion is to disable those programs and see if the problem goes away. Its more than coincidental that its happening at exactly the same time
Paul
Edited by paulbates
FIY. Admin Console has a search and replace function to find device, variable etc. usage . Right click on any program and select it from the dropdown menu.
Paul
Thanks for the suggestion, I will give it a try.
Edgar
Thanks for the info, will be very helpful to find.
Thanks to Paul & larryllix for your input. The problem was the Great Rm.Table Lamp Dim program. I added the Else line last week (6%), believing that line would run only @ 10:31 PM and not anytime a Great Rm.Table Lamp On was issued.  Thanks again.
Edgar
Edgar
On that same pulldown menu there is also a 'copy to clipboard' for pasting programs here.
Careful with the dimmed values. They may not be exact at next program run
Sent using Tapatalk
Sent using Tapatalk
Thanks. I have to get more familiar with the pulldown menu. So far no problem with the dimmed values.
