Yale Z-Wave Connectivity Challenges
Hi ISY Friends,
I installed a Yale YRD256-ZW2 (Z-wave) deadbolt in August.  My ISY is in my basement and the range didn't work for this particular deadbolt.  I had to move the ISY right next to the deadbolt in order to get it added to the ISY.
I bought a couple of: Aeotec Range Extender 6's off of Amazon and added them to my home and the deadbolt worked great for about a month.  Now I seem to keep loosing connectivity.  I tried removing the lock from the ISY and adding it back in yesterday but it seems to be inconsistent even though I have one of these Z-wave repeaters right next to the lock.
I am still somewhat new to Z-Wave.  I have another Kiwikset Z-Wave Deadbolt and it has no issues at all.
Any ideas on what else I should do?
Running 5.0.15 A
Z-Wave 6.81.00
Edited by isyrocks!
May simply need a stronger mesh. Yale works great with the isy (I have a few).
Being rf only, different things can interfere with the zwave signal. I'd remove the lock, bring it closer to the isy, heal the network, and test for a few days to make sure the 2 can talk. If you have no issues, then you need more devices
  • 3 weeks later...
Thanks for the feedback.  I got it working again.  I factory reset the deadbolt, brought the ISY close to the deadbolt and re-added it just fine.  After that I ran a heal.  I then moved the ISY back to it's original spot and ran a heal again.  Now it's working.
