Recently lost the ability to expose Node-Server based nodes
gviliunas
I recently upgraded to ISY v5.0.16 and Polyglot 2.2.3
Previously, I had exposed several of my Lifx and Harmony node server nodes via the ISY portal so that I could control these via Alexa.
( e.g. "Alexa, turn on stereo")
Now, If I open the Amazon Echo device list in the portal, I can see my previously-configured nodes (See attached example of my page 11)
If I click to edit one of these nodes, the My Device field is blank and can't be edited.
If I try to add any Node Server-based devices, these are no longer shown in the list of available devices.
Devices configured prior to the upgrade can still be controlled by Alexa but new Node Server-based sub-nodes cannot be added.
I am not sure which upgrade caused the problem.
Edited by gviliunas
Thanks Benoit,
Here is the output that you requested. I think that you are onto something. The now non-working nodes all have a type = 0.0.0.0
Thanks for your help!
nodes.pdf
Hi Michel,
For me, the affected node servers are LiFX v2.1.16 and Harmony Hub v2.2.5
I am using Polyglot v2.2.3 and ISY v5.0.16
Any node with a nxxx_yyyyyyyy address except for the base controller nodes is now not shown in the My Device portal drop down selections.
eg. I do have a "LiFX controller (n005_controller)" node in the ISY Portal "My Device" drop down selection but none of the individual LiFX light nodes appear in this drop-down. Previously, these were there and I was able to expose individual LiFX lamps as devices.
Edited by gviliunas
I had a few minutes so tried restoring a good backup of ISY v. 5.0.15A to rule out either ISY or Polyglot as the cause for this.
Restoring the ISY backup did NOT solve the problem so I suspect that the cause for not able to expose the node-server based nodes has something to do with the Polyglot v. 2.2.3 upgrade.
Upgrading Polyglot to v. 2.2.4 did not resolve the issue either.
I made a change to ISY Portal. Nodes with a hint of 0.0.x.x should now appear as a dimmable light.
Can you please test it?
Benoit
  • Like 3
Thanks Benoit!!
Confirmed, yes, the node-server nodes are now present in the drop-down selection and populated once again in the existing portal-exposed nodes.
Thanks for your help with this!
Greg
  • Thanks 1
      377.1k
