2475DA1 + LED "Can" Lights?
Does the 2475DA1 (Insteon Remote Control In-Line Dimmer Switch) run LED Recessed lights like this -
https://www.lowes.com/pd/Juno-White-LED-Remodel-And-New-Construction-Recessed-Light-Kit-Fits-Opening-6-in/1000330977
Product Image 1
The description on the Insteon page says:   This dimmer controls incandescent bulbs. If you need to control a fluorescent light fixture or an appliance, try the In-LineLinc Relay
I've recently had several lights replaced with units like this (not sure the exact brand) and are working fine with the usual on/off and dimmer switches. But looking at putting in a few in the kitchen and wanted to control them independently (at times). and wanted to see if these in-line dimmers would work for LED "cans"/puck lights like this.
It calls for magnetic or electronic dimmers so the insteon dimmer wouldn't work for you since it uses a triac.
Bummer. Was going to snag these on sale. Guess I should find the lights first and get something that would work. We keep going back and forth over being able to operate individually or all or nothing.
Thanks for checking.
Sent from my Phone using Tapatalk
