Random on/off
I have 1 light in my backroom that randomly turns on everyday at 9pm. Have another light in my basement that randomly turns off at 9pm. Odd cause if i check that device to see when its scheduled to run next, no where does it say those times. Is there a way to see what is triggering these events?
Sent from my SM-G960U using Tapatalk
@diggler,
The first thing would be to unplug ISY and see whether or not the problems go away. Since this is happening on a regular basis, then you should immediately know whether or not the problem has gone away. If the problem goes away, then next thing would be to:
1. Right Mouse click on My Programs | Find & Replace
2. Look for that device + all scenes wherein that device is a member
3. Disable these programs and see whether or not the problem goes away
@diggler
I have had this before where it was a mysterious extra link on the device.  Try checking the links tables on the devices in question and compare against what ISY says the links should be.  If they are different, factory reset the device and restore it from ISY.
Michel's action will find if you accidentally have the device listed in a program or scene you didn't realize it was in, what I suggested will find if there are some stray links on the device.  If neither of these proves productive, then completely delete the device from ISY, factory reset it, and start over with that device.
I removed both devices from every scene. Problem solved. Thanks for the help.
