Policy has arrived however I cannot access by browser
I manually updated the firmware of my ISY to the required 5.0.16B firmware/ That process went fine. When I first connected Polisy it could not locate the ISY and kept beeping.
At this time the left light is on and Polisy shows connected to my router however with no TX or RX data showing. I cannot log into it wither by IP address or through https://polisy
I remain stuck at this point of being able to access anything.  Suggestions?   DHCP is enabled.
Edited by Tominnh
Same here so far.  My router shows it connected, but trying that address results in the same thing: nothing.  I will let you know if I find a solution.
I hope this is not one of those apple and safari things.
I use both Windows 10 and Mac computers, and I can access Polisy on either. However you may need to clear your browser's cache.
What is the full URL that you have been trying?
If you have the IP Address have you tried using that?
Have you tried with the longer named convention of "polisy.local"?
"Polisy.local" does not work (or I am missing something).  Neither does HTTPS://polisy.local.
I tried http://192.168.0.48.  This did not work.  I finally tried https://192.168.0.48.  This worked, but only on firefox.  Safari and chrome continue to resist my efforts.  Clearing the cache did not change this.
https://192.168.xx.yy assumes port 443 but my polyglot would never accept https://192.168.xx.yy:443 for some reason.
I have to ignore and bypass all the security warnings every time until I found how to use http only. I may have to undo that due to polyglot v2.2.6 confusing the ISY comms with the admin comm access now.
Hello, I have installed my Polisy today and am not able to gain access.  I can see it on my router and its IP address, but neither work.  I cleared cache on Edge and no change.  Any suggestions would be greatly appreciated.  I did put a ticket in with UD, but was hoping to look around on my day off.
Edited by AnthemAVM
  • Members
  • 2
  • 11 posts
I also had trouble connecting with any browser. If your unit has WIFI try the following:
Discovered open WIFI ports are not compatible with polisy.  Removed WIFI card from polisy  and all works well. Waiting for a fix! don't really need WIFI I have a wired connection.
Conclusion WIFI at this point is a problem!
50 minutes ago, 4481hoods said:
  • Members
  • 2
  • 11 posts
Thanks, I was able to get in via the direct IP address, but https://polisy doesn't work.
Edited by AnthemAVM
I opened A ticket and  Michel was quickly able to do a remote session and resolve the issue!
Hello all,
It seems that we can never run away from cache! It used to be Java cache and now it's browser cache especially if you had accessed Polyglot on your computer. It's best to clear your browser's cache.
You can quickly test for a cache issue by testing with an Incognito or in-private browser instance.... If it fails in a new private session it’s not a cache issue...
