Copy Alexa config to Google Home
I just went through and setup about 50 scenes in the Alexa/Echo config.  I also have Android phones, so I'd like to set them up for Google Home as well.  Is there a way to "copy" the spoken configuration from one to the other?  Or do I need to recreate them all manually?
Wayne
If you did your "spokens" in the isy, those will automatically transfer. I haven't seen a way to transfer Alexa settings to google
There was a copy over in the ISY portal originally. IIRC it did leave a few holes though. Possibly removed now.
Sent using Tapatalk
Thank you both.  I setup the spokens directly in the Portal, so they didn't come across automatically.  I was flying through the posts/wikis just trying to the Alexa set up, so I probably didn't take the time to consider benefits to doing some additional leg work on the isy before pulling them all together.
I just noticed that "room" is required for Google and I didn't populate it for Alexa, so even if the copy was there, I bet I would still have issues.  Guess it's time to be glad I have dual monitors so I can have Alexa up on one and edit Google on the other.  It's probably the fastest option at this point.
Thanks again.
