Adding August Smartlock Pro Z-Wave
@tmorse305
Yes, I installed the magnet and went through the calibration process in the August App.  I assumed that the "Locked" status shown in my screenshot was coming from that info.  When I manually turn the lock, the status in the Admin panel updates immediately.  Am I missing a node or is everything now combined?  My ISY firmware is v4.7.5.
Do you see the "Locked" status in your lock node and have another node that also shows locked?
That might be the difference. I’m running 5.x software. If you open the door and then lock it does it show as locked? The 4.x software might not support the contact. This last time I tried the 5.x software it showed the 2 nodes but the contact node did not work correctly.
So now I have a dumb firmware upgrade question and didn't wan't to start another thread.  When I download and unzip the firmware, what do I select?  During the manual firmware upgrade process, I tried selecting the zip, then I tried selecting the root folder, then I tried a few of the internal folders.  Sorry for the stupid question, but how do I update the firmware?
I read through the firmware instructions, they don't mention the zip or what folder or file to select.
I've upgraded firmware before and don't remember having any trouble.
You don't extract it. You just download it and the isy will take care of the rest
Ok, updated firmware to 5.0.16C.  Removed all Zwave devices and reset the zwave dongle on the ISY.  Added back the repeaters and the locks.  Locks only have 1 node(basically same as before firmware update) and now I have a repeater that thinks he is a lock (see screenshot).  I've tried removing everything and resetting the dongle multiple times.  I think I'm done for the night.
Did you clear java cache after you updated? Factory reset devices? Exclude devices from isy then include them?
I'm not running 5.0.16C yet but I would say the the problem has not been corrected yet.  If you're up for trying something else I would reset all and start over this time add the repeaters first, make sure they install correctly and appear correctly in the console.  Then add one lock. Once added, operate the lock a few times, open and close the door a few times before adding the second lock.  What I found was when the lock was initially installed only one node appeared in the console.  Then after I operated the lock the second node appeared.  That said even if the 2nd node appears it looks like there might still be an issue with the lock configuration in 5.0.16C.
Decided to start fresh today and everything looks good.  When I first added the lock, only 1 node showed up, after the status changed on the lock, the other node appeared in the admin application.  Based on the other forum thread above, it looks like that extra node is not really necessary but I labeled "sensor" anyway.
Thanks for all the help and suggestions.
Here's a screenshot of all devices added:
Edited by saphotoexpress
  • 8 months later...
On 3/29/2020 at 11:55 PM, simplextech said:
Z-Wave Heal process
Is this the same as repair links?
