ISY Portal maintenance - 04-12-2020
Hello everyone,
We will have a maintenance this Sunday 04-12-2020 at 5:00 AM PDT which will last for up to 1 hour. During this period, your ISY will disconnect for a few brief moments.
New feature:
  • Hint Editor: Under Connectivity there will be a new option which allows to manually edit the "Hint" of a Nodeserver node.
Maintenance:
  • Install OS patches
Benoit
@bmercier Has the maintenance completed?  It's noon central and the portal says my ISY is offline and I have rebooted it twice.  No joy.
Edited by btreinders
Just found this thread, as my ISY has gone offline a little while ago (green dot in ISY portal still there, but lost connection to Amazon, Google, etc.
@bmercier; I believe the thread title should say 04 (April), not 03 (March), correct?
I probably should have made the above post in this thread instead.
my theory is ISY's that have been restarted can't re-connect to the portal, but if the ISY was already connected before this morning it stayed connected.
So... It's now 1436 EST and I've also noticed that my ISY has dropped offline effectively breaking all of my smart home integrations like Alexa...  What's the status on bringing this back up?  Silence from the organization on something like this is completely unacceptable.  Additionally, simply notifying users via a form post and not an email is additionally unacceptable.
So is yours online with ISY portal and working with Alexa? And if so you believe this is because you didn't restart yours?
Mine was working before this morning. But I did restart it this morning.
For what it's worth, mine was working for a couple weeks without a restart.  It dropped off all by itself earlier this afternoon and still isn't back.  I've tried rebooting twice.
Correct.  my isy is connected to the portal and alexa is working as well.  my isy has not been restarted today.
What firmware are you on?
What firmware are you running?
I have been on v5.0.16C since 17-MAR.  I thought it was less than that, but apparently it was about a month ago that I upgraded.
1 minute ago, JSylvia007 said:
I have been on v5.0.16C  ...
Same here, ever since it was released.
(I am also offline as of an hour or so ago.)
I've been on v5.0.16C since 3days after it's release.  My ISY was last restarted a week ago exactly, I just looked it was literally this time of day last Sunday.
have you restarted or upgraded your ISY today?
I did restart today AFTER I had lost connection.
Hi.  I have the same problem.  On version 5.0.15A
I submitted a support ticket and they indicated that they are looking into the issue now.
Hello all,
Sincere apologies for the interruption in service. One of the proxy servers had to be migrated and thus the reason for this issue affecting only a certain number of folks (those that were connected to this proxy server). Things should go back to normal shortly on their own. If you have not done so, please reboot your ISY; this will cause ISY to connect to the working proxy.
I am on 5..0.16C.
Portal shows "ISY online since 12:30:19 PDT"
No reboots.
Polyclot cloud shows all kinds of errors.
2 minutes ago, Michel Kohanim said:
Hello all,
Michael, what about those of us who have been rebooting for the last hour? I just rebooted mine a few minutes ago and it still hasn't come back online. When can we expect this problem to "sort itself out"?
@JSylvia007,
I am so very sorry to hear. I think this is due to DNS propagation delays. Can you please reboot one more time and then send your error log to support@universal-devices.com?
7 minutes ago, Michel Kohanim said:
Hi @PurdueGuy,
What errors are you getting in PGC?
I emailed you the screenshots.  Requested ISY not online, etc.
I've rebooted twice, waiting for the 2nd reboot to come back.
Also, Alex says "The hub that devices connects to is not responding..."
Commands via Alexa (voice) worked about 20 minutes ago.
@PurdueGuy,
Thanks so very much! Got them all. I see the issue ... I think PGC is now bombarding ISY/ISY Portal. That's why Alexa worked for a few minutes. Looking into it as we speak.
