LIB_ERRORS-403
After upgrading to v5, when I open the Admin Console, I get two error windows.  First I get LIB_ERRORS-403, then I get Request Failed.
I am opening the Admin Console through the Launcher.  When setting up the Launcher, I added my ISY again using the Admin Console URL from the portal under ISY Information.  It does not matter if I use the ISY line item that the Launcher identifies or the one I added, they both point to the same ISY, I get LIB_ERRORS-403.  However, it's only when I use the line item that I added that I get the Request Failed.
Once in the Admin console, after clearing the errors, I went into Set Userid/Password, Admin User and created a user with the same admin credentials as is on my portal.  I've closed the Admin Portal and relaunched it via the Launcher using the credentials I just set and still get LIB_ERRORS-403.
When I log into the portal, I can see my ISY with a green connected light on the line.
I can't tell if these are extraneous errors, but something seems to be amiss.
I've rebooted my ISY.  Now in addition to the LIB_ERRORS-403, I'm getting Could not open file [/DEF/F1/I1/NLS/EN_US.TXT].  My error log since the reboot...
Wed 2020/09/09 10:52:20 AM    System    -5    Start
Wed 2020/09/09 10:52:21 AM    System    -110022    /CONF/INSTENG.OPT
Wed 2020/09/09 10:52:21 AM    System    -110012    /CONF/INSTENG.OPT
Wed 2020/09/09 10:52:22 AM    System    -110022    /DEF/F1/I1/NLS/EN_US.TXT
Wed 2020/09/09 10:52:24 AM    System    -170001    [Network] Established
Wed 2020/09/09 10:54:04 AM    System    -5011    uuid:0
Wed 2020/09/09 11:04:31 AM    System    -10011    n/a
Wed 2020/09/09 11:04:49 AM    System    -10011    n/a
Wed 2020/09/09 11:04:55 AM    System    -170001    [Auth:-10103] 192.168.171.20:55039->80, Num=3
Wed 2020/09/09 11:04:55 AM    System    -10011    n/a
Wed 2020/09/09 11:05:30 AM    System    -170001    [Auth:-10103] 192.168.171.20:55072->80, Num=4
Yes, I am using the launcher.
Yes, my UI & Firmware are the same:
Thanks Michal.  This has fixed the issue.
I'm not sure how I ended up with the SCE pilot version.  I originally updated my firmware from the portal by selecting Maintenance > Firmware Update.
I wasn't sure if I had a current version of the launcher, so I just searched for a launcher download and executed it.  Are there different versions of the launcher?  One that would have applied the SCE version?  If so, that's probably how I got it.  I didn't pay close enough attention to the launcher download.  If they are the same, then I don't know how I got it, because from there, I just opened my Admin console from that launcher and the upgrade kicked off automatically.
Bottom line, your advice had fixed my issue.  Thanks.
