I purchased Polisy during the pre-release and have never really figured out what to do with it.  I was able to log in and it has been sitting on my network with nothing running on it ever since; that is until today when the power went out in my house for 10 minutes.  When the power came back all three liLEDs flask and Polisy keeps beeping.  I unplugged it and powered it back up and get the same.
I hope it isn't broken.
Thanks.  So I followed the steps
Polisy Keeps Beeping
Networking Issue
  • Make sure you have connected the network cable to the right jack on the back of the unit (the right most when Polisy is facing you) - correct port used
  • Make sure the unit has Internet connectivity since, in some cases, it must download the latest packages upon first installation - connected to internet
  • Make sure your ISY is running firmware 5.0.16+ and is on the same network as Polisy -5.0.16c
Latest Packages Not Installed
If the above does not work, you will need an ssh utility (such as putty) to connect to Polisy over the network: 1. ssh admin@polisy (you can change polisy to the IP address of your unit) 2. Default password is admin. Once this process is done, please change it 3. Run the following commands:
Polyglot is opn 192.168.1.196
  • sudo service polyglot stop - executed
  • sudo service udx stop - executed and beeping stopped
  • sudo pkg update - Deemed to download something
  • sudo pkg upgrade - said repositories up to date
  • sudo service polyglot start - returned to beeping
  • sudo service udx start
login as: admin
Using keyboard-interactive authentication.
Password for admin@polisy:
Access denied
Last login: Sun Oct 11 07:10:46 2020 from desktop-78qab1r
FreeBSD 12.1-RELEASE-p1 r355229 POLISY
Welcome to Polisy!
[admin@polisy ~]$ sudo service polyglot stop
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
Password:
Stopping polyglot.
[admin@polisy ~]$ sudo service udx stop
Stopping udx.
Waiting for PIDS: 1025.
[admin@polisy ~]$ sudo pkg update
Updating FreeBSD-base repository catalogue...
Fetching meta.txz: 100%    240 B   0.2kB/s    00:01
Fetching packagesite.txz: 100%   19 KiB  19.8kB/s    00:01
Processing entries: 100%
FreeBSD-base repository update completed. 277 packages processed.
Updating udi repository catalogue...
Fetching meta.txz: 100%    796 B   0.8kB/s    00:01
Fetching packagesite.txz: 100%  103 KiB 105.4kB/s    00:01
udi repository update completed. 386 packages processed.
All repositories are up to date.
[admin@polisy ~]$ sudo service polyglot start
Starting polyglot.
[admin@polisy ~]$ sudo service udx start
Starting udx.
[admin@polisy ~]$ login as: admin
Password:
  • 3 weeks later...
I lost power last night and I am experiencing the same issue. All 3 lights blinking with beeping.
I have SSH the polisy and mongod status is running?
Please can you assist?
I have completed the following as well.
Edited by MBell
It doesn't appear that you're running the latest and greatest on your box.  You may need to have all your packages on the latest version.  I've upgraded and this is the version that's reported at the prompt:
FreeBSD 12.1-RELEASE-p10 r365882 POLISY
You might try running this:
sudo pkg update && sudo pkg upgrade
Reboot upon successful completion of the upgrade.
I am getting the same:
Michael a ticket was created at your request.
Thank you kindly for your support,
Update,
with nothing done on my part the Polisy started working as expected, no more blinking lights or beeping.
Edited by MBell
Update issue
6 hours ago, Michel Kohanim said:
@larryllix,
What does "same" refer to? Please submit a ticket.
Sorry. I didn't include the post I was responding to.
I was responding to Bumbleshoot, demonstrating that I have the same latest polisy O/S version, the same as he does.
No problem here with my equipment.
My login shows:
When I would check the web UI for updates it just disappeared after a while and didn't indicate if updates were available or not.
Ran 'sudo pkg update && sudo pkg upgrade' and it went through an installation process after which I rebooted Polisy.
Now the 'check for Polisy updates' returns no updates available (as I would expect).
Curious if the -p1 (which I still get) vs -p10 release information is an issue.  (no problems with Polisy that I am aware of)
Edited by gzahar
Just now, Michel Kohanim said:
@gzahar,
It's really not an issue since those are minor releases. Once we get to 13, then the system will allow you upgrade it.
Do you have any issues now?
MIchel
No.  Thanks.
It's been a while but I went back through the steps again and executed the additional items I found in this thread
login as: admin
Last login: Sun Oct 11 07:12:38 2020 from desktop-78qab1r
Welcome to Polisy!
Password:
Stopping polyglot.
Waiting for PIDS: 910.
Stopping udx.
Waiting for PIDS: 1057.
Fetching meta.txz: 100%    236 B   0.2kB/s    00:01
Processing entries:   0%
Newer FreeBSD version for package FreeBSD-zfs:
To ignore this error set IGNORE_OSVERSION=yes
- package: 1202000
- running kernel: 1201000
Ignore the mismatch and continue? [Y/n]: y
Fetching packagesite.txz: 100%   96 KiB  98.7kB/s    00:01
udi repository update completed. 353 packages processed.
Starting polyglot.
Starting udx.
[admin@polisy ~]$ sudo service mongod status
mongod is not running.
[admin@polisy ~]$ sudo pkg update && sudo pkg upgrade
FreeBSD-base repository is up to date.
udi repository is up to date.
New version of pkg detected; it needs to be installed first.
The following 1 package(s) will be affected (of 0 checked):
Installed packages to be UPGRADED:
        pkg: 1.12.0 -> 1.15.10 [udi]
Number of packages to be upgraded: 1
The process will require 3 MiB more space.
7 MiB to be downloaded.
Proceed with this action? [y/N]: y
[1/1] Fetching pkg-1.15.10.txz: 100%    7 MiB   1.9MB/s    00:04
Checking integrity... done (0 conflicting)
[1/1] Upgrading pkg from 1.12.0 to 1.15.10...
[1/1] Extracting pkg-1.15.10: 100%
pkg: Failed to execute lua script: [string "args = {}..."]:11: attempt to call a        nil value (field 'stat')
Checking for upgrades (68 candidates): 100%
Processing candidates (68 candidates): 100%
The following 108 package(s) will be affected (of 0 checked):
Installed packages to be REMOVED:
        python27: 2.7.17_1
New packages to be INSTALLED:
        apr: 1.7.0.1.6.1_1 [udi]
        bash-completion: 2.11,2 [udi]
        brotli: 1.0.9,1 [udi]
        db5: 5.3.28_7 [udi]
        gdbm: 1.18.1_1 [udi]
        gmp: 6.2.0 [udi]
        gnupg: 2.2.23 [udi]
        gnutls: 3.6.15 [udi]
        libassuan: 2.5.4 [udi]
        libedit: 3.1.20191231,1 [udi]
        libgcrypt: 1.8.7 [udi]
        libgpg-error: 1.39 [udi]
        libidn2: 2.3.0_1 [udi]
        libksba: 1.4.0 [udi]
        liblz4: 1.9.2_1,1 [udi]
        libtasn1: 4.16.0 [udi]
        libunistring: 0.9.10_1 [udi]
        nettle: 3.6 [udi]
        npth: 1.6 [udi]
        p11-kit: 0.23.21 [udi]
        p5-Clone: 0.45 [udi]
        p5-Encode-Locale: 1.05 [udi]
        p5-HTTP-Date: 6.05 [udi]
        p5-HTTP-Message: 6.26 [udi]
        p5-IO-HTML: 1.001_1 [udi]
        p5-LWP-MediaTypes: 6.04 [udi]
        p5-Term-ReadKey: 2.38_1 [udi]
        p5-TimeDate: 2.33,1 [udi]
        p5-URI: 1.76 [udi]
        p5-subversion: 1.14.0 [udi]
        pinentry: 1.1.0_6 [udi]
        pinentry-tty: 1.1.0 [udi]
        py37-mock: 3.0.5 [udi]
        serf: 1.3.9_5 [udi]
        sqlite3: 3.33.0_1,1 [udi]
        tpm-emulator: 0.7.4_2 [udi]
        trousers: 0.3.14_3 [udi]
        utf8proc: 2.5.0 [udi]
        bash: 5.0.11 -> 5.0.18_3 [udi]
        boost-libs: 1.72.0 -> 1.72.0_3 [udi]
        c-ares: 1.15.0_1 -> 1.16.1 [udi]
        ca_root_nss: 3.48 -> 3.58 [udi]
        curl: 7.67.0 -> 7.73.0 [udi]
        cyrus-sasl: 2.1.27 -> 2.1.27_1 [udi]
        dmidecode: 3.2 -> 3.3 [udi]
        e2fsprogs-libuuid: 1.45.3 -> 1.45.6 [udi]
        flashrom: 1.1 -> 1.2 [udi]
        gettext-runtime: 0.20.1 -> 0.21 [udi]
        git: 2.24.1 -> 2.29.2 [udi]
        gmake: 4.2.1_3 -> 4.3_2 [udi]
        icu: 65.1,1 -> 68.1,1 [udi]
        isc-dhcp44-client: 4.4.1_1 -> 4.4.2_1 [udi]
        libconfuse: 3.2.1_1 -> 3.3_2 [udi]
        libffi: 3.2.1_3 -> 3.3_1 [udi]
        libftdi1: 1.4_14 -> 1.5_1 [udi]
        libnghttp2: 1.40.0 -> 1.41.0 [udi]
        libpci: 3.6.2 -> 3.7.0_1 [udi]
        libuv: 1.34.0 -> 1.40.0 [udi]
        libwebsockets: 2.4.2 -> 4.0.21 [udi]
        mongodb36: 3.6.14_1 -> 3.6.20 [udi]
        node: 13.3.0 -> 15.2.0 [udi]
        npm: 6.12.1 -> 6.14.8 [udi]
        p5-CGI: 4.44 -> 4.51 [udi]
        p5-Error: 0.17028 -> 0.17029 [udi]
        p5-HTML-Parser: 3.72 -> 3.75 [udi]
        p5-IO-Socket-SSL: 2.066 -> 2.068 [udi]
        p5-Mozilla-CA: 20180117 -> 20200520 [udi]
        p5-Net-SSLeay: 1.85 -> 1.88 [udi]
        pciids: 20191211 -> 20200922 [udi]
        pcre: 8.43_2 -> 8.44 [udi]
        perl5: 5.30.1 -> 5.32.0 [udi]
        polyglot: 2.2.8 -> 2.2.9_7 [udi]
        powerdxx: 0.4.3 -> 0.4.4 [udi]
        py37-acme: 0.39.0,1 -> 1.9.0,1 [udi]
        py37-asn1crypto: 0.24.0 -> 1.3.0 [udi]
        py37-certbot: 0.39.0,1 -> 1.9.0,1 [udi]
        py37-certifi: 2019.9.11 -> 2020.6.20 [udi]
        py37-cffi: 1.13.2 -> 1.14.3 [udi]
        py37-configargparse: 0.15.2 -> 1.2.3 [udi]
        py37-dateutil: 2.8.0 -> 2.8.1 [udi]
        py37-distro: 1.4.0_1 -> 1.5.0 [udi]
        py37-holidays: 0.9.11_1 -> 0.9.12 [udi]
        py37-idna: 2.8 -> 2.10 [udi]
        py37-josepy: 1.2.0 -> 1.4.0 [udi]
        py37-parsedatetime: 2.5 -> 2.6 [udi]
        py37-pip: 19.1.1 -> 20.2.3 [udi]
        py37-pycparser: 2.19 -> 2.20 [udi]
        py37-pycryptodome: 3.9.0 -> 3.9.8 [udi]
        py37-pytz: 2019.3,1 -> 2020.1,1 [udi]
        py37-regex: 2018.02.21 -> 2020.7.14 [udi]
        py37-requests: 2.22.0 -> 2.22.0_2 [udi]
        py37-requests-toolbelt: 0.8.0_1 -> 0.9.1 [udi]
        py37-setuptools: 41.4.0_1 -> 44.0.0 [udi]
        py37-six: 1.12.0 -> 1.15.0 [udi]
        py37-urllib3: 1.25.6,1 -> 1.25.11,1 [udi]
        py37-yaml: 5.2 -> 5.3.1 [udi]
        python37: 3.7.5_1 -> 3.7.9_1 [udi]
        readline: 8.0.0 -> 8.0.4 [udi]
        snappy: 1.1.7 -> 1.1.8 [udi]
        sudo: 1.8.29 -> 1.9.3p1 [udi]
        udx: 1.0.26_4 -> 1.0.26_27 [udi]
Installed packages to be REINSTALLED:
        p5-Authen-SASL-2.16_1 [udi] (direct dependency changed: perl5)
        p5-Digest-HMAC-1.03_1 [udi] (direct dependency changed: perl5)
        p5-HTML-Tagset-3.20_1 [udi] (direct dependency changed: perl5)
        p5-IO-Socket-INET6-2.72_1 [udi] (direct dependency changed: perl5)
        p5-Socket6-0.29 [udi] (direct dependency changed: perl5)
Number of packages to be removed: 1
Number of packages to be installed: 39
Number of packages to be upgraded: 63
Number of packages to be reinstalled: 5
The process will require 33 MiB more space.
163 MiB to be downloaded.
[1/107] Fetching udx-1.0.26_27.txz: 100%  555 KiB 568.7kB/s    00:01
[2/107] Fetching sudo-1.9.3p1.txz: 100%  876 KiB 896.9kB/s    00:01
[3/107] Fetching snappy-1.1.8.txz: 100%   22 KiB  22.7kB/s    00:01
[4/107] Fetching readline-8.0.4.txz: 100%  332 KiB 339.6kB/s    00:01
[5/107] Fetching python37-3.7.9_1.txz: 100%   16 MiB   3.4MB/s    00:05
[6/107] Fetching py37-yaml-5.3.1.txz: 100%   75 KiB  76.7kB/s    00:01
[7/107] Fetching py37-urllib3-1.25.11,1.txz:  49%   80 KiB  81.9kB/s    00:01 ET        [7/107] Fetching py37-urllib3-1.25.11,1.txz: 100%  163 KiB 167.1kB/s    00:01
[8/107] Fetching py37-six-1.15.0.txz: 100%   19 KiB  19.6kB/s    00:01
[9/107] Fetching py37-setuptools-44.0.0.txz:  42%  216 KiB 221.2kB/s    00:01 ET        [9/107] Fetching py37-setuptools-44.0.0.txz: 100%  512 KiB 524.4kB/s    00:01
[10/107] Fetching py37-requests-toolbelt-0.9.1.txz: 100%   65 KiB  66.3kB/s    0        0:01
[11/107] Fetching py37-requests-2.22.0_2.txz:  48%   40 KiB  41.0kB/s    00:01 E        [11/107] Fetching py37-requests-2.22.0_2.txz: 100%   82 KiB  84.2kB/s    00:01
[12/107] Fetching py37-regex-2020.7.14.txz: 100%  291 KiB 298.1kB/s    00:01
[13/107] Fetching py37-pytz-2020.1,1.txz: 100%  157 KiB 160.9kB/s    00:01
[14/107] Fetching py37-pycryptodome-3.9.8.txz:   4%  496 KiB 507.9kB/s    00:19        [14/107] Fetching py37-pycryptodome-3.9.8.txz:  15%    1 MiB   1.1MB/s    00:10        [14/107] Fetching py37-pycryptodome-3.9.8.txz:  32%    3 MiB   1.8MB/s    00:04        [14/107] Fetching py37-pycryptodome-3.9.8.txz:  61%    6 MiB   2.9MB/s    00:02        [14/107] Fetching py37-pycryptodome-3.9.8.txz: 100%   10 MiB   2.6MB/s    00:04
[15/107] Fetching py37-pycparser-2.20.txz: 100%  164 KiB 168.4kB/s    00:01
[16/107] Fetching py37-pip-20.2.3.txz: 100%    2 MiB 894.2kB/s    00:02
[17/107] Fetching py37-parsedatetime-2.6.txz: 100%   57 KiB  58.3kB/s    00:01
[18/107] Fetching py37-josepy-1.4.0.txz: 100%   74 KiB  75.6kB/s    00:01
[19/107] Fetching py37-idna-2.10.txz: 100%   62 KiB  63.3kB/s    00:01
[20/107] Fetching py37-holidays-0.9.12.txz: 100%   74 KiB  76.2kB/s    00:01
[21/107] Fetching py37-distro-1.5.0.txz: 100%   23 KiB  23.3kB/s    00:01
[22/107] Fetching py37-dateutil-2.8.1.txz: 100%  255 KiB 261.1kB/s    00:01
[23/107] Fetching py37-configargparse-1.2.3.txz: 100%   26 KiB  26.9kB/s    00:0        1
[24/107] Fetching py37-cffi-1.14.3.txz: 100%  206 KiB 211.4kB/s    00:01
[25/107] Fetching py37-certifi-2020.6.20.txz: 100%  146 KiB 149.5kB/s    00:01
[26/107] Fetching py37-certbot-1.9.0,1.txz: 100%  293 KiB 299.6kB/s    00:01
[27/107] Fetching py37-asn1crypto-1.3.0.txz:  45%   72 KiB  73.7kB/s    00:01 ET        [27/107] Fetching py37-asn1crypto-1.3.0.txz: 100%  159 KiB 162.7kB/s    00:01
[28/107] Fetching py37-acme-1.9.0,1.txz: 100%   65 KiB  66.1kB/s    00:01
[29/107] Fetching powerdxx-0.4.4.txz: 100%  100 KiB 102.7kB/s    00:01
[30/107] Fetching polyglot-2.2.9_7.txz: 100%   17 MiB   3.6MB/s    00:05
[31/107] Fetching perl5-5.32.0.txz: 100%   14 MiB   3.0MB/s    00:05
[32/107] Fetching pcre-8.44.txz: 100%  910 KiB 466.1kB/s    00:02
[33/107] Fetching pciids-20200922.txz: 100%  213 KiB 218.3kB/s    00:01
[34/107] Fetching p5-Socket6-0.29.txz: 100%   16 KiB  16.7kB/s    00:01
[35/107] Fetching p5-Net-SSLeay-1.88.txz: 100%  258 KiB 263.8kB/s    00:01
[36/107] Fetching p5-Mozilla-CA-20200520.txz:  49%   64 KiB  65.5kB/s    00:01 E        [36/107] Fetching p5-Mozilla-CA-20200520.txz: 100%  128 KiB 131.1kB/s    00:01
[37/107] Fetching p5-IO-Socket-SSL-2.068.txz:  24%   40 KiB  41.0kB/s    00:03 E        [37/107] Fetching p5-IO-Socket-SSL-2.068.txz: 100%  164 KiB 168.2kB/s    00:01
[38/107] Fetching p5-IO-Socket-INET6-2.72_1.txz: 100%   13 KiB  13.1kB/s    00:0        1
[39/107] Fetching p5-HTML-Tagset-3.20_1.txz: 100%   12 KiB  12.0kB/s    00:01
[40/107] Fetching p5-HTML-Parser-3.75.txz: 100%   79 KiB  81.4kB/s    00:01
[41/107] Fetching p5-Error-0.17029.txz: 100%   27 KiB  27.3kB/s    00:01
[42/107] Fetching p5-Digest-HMAC-1.03_1.txz: 100%   10 KiB  10.2kB/s    00:01
[43/107] Fetching p5-CGI-4.51.txz: 100%  151 KiB 155.0kB/s    00:01
[44/107] Fetching p5-Authen-SASL-2.16_1.txz: 100%   40 KiB  41.5kB/s    00:01
[45/107] Fetching npm-6.14.8.txz: 100%    4 MiB 742.2kB/s    00:05
[46/107] Fetching node-15.2.0.txz: 100%    7 MiB 745.4kB/s    00:10
[47/107] Fetching mongodb36-3.6.20.txz: 100%   36 MiB 928.7kB/s    00:41
[48/107] Fetching libwebsockets-4.0.21.txz: 100%  366 KiB 375.3kB/s    00:01
[49/107] Fetching libuv-1.40.0.txz: 100%  118 KiB 121.1kB/s    00:01
[50/107] Fetching libpci-3.7.0_1.txz: 100%   53 KiB  54.3kB/s    00:01
[51/107] Fetching libnghttp2-1.41.0.txz: 100%  116 KiB 119.1kB/s    00:01
[52/107] Fetching libftdi1-1.5_1.txz: 100%  118 KiB 120.4kB/s    00:01
[53/107] Fetching libffi-3.3_1.txz: 100%   39 KiB  40.0kB/s    00:01
[54/107] Fetching libconfuse-3.3_2.txz: 100%   55 KiB  55.9kB/s    00:01
[55/107] Fetching isc-dhcp44-client-4.4.2_1.txz:   9%   96 KiB  98.3kB/s    00:0        [55/107] Fetching isc-dhcp44-client-4.4.2_1.txz:  66%  648 KiB 565.3kB/s    00:0        [55/107] Fetching isc-dhcp44-client-4.4.2_1.txz: 100%  978 KiB 501.0kB/s    00:0        2
[56/107] Fetching icu-68.1,1.txz: 100%   10 MiB 769.3kB/s    00:14
[57/107] Fetching gmake-4.3_2.txz: 100%  416 KiB 425.7kB/s    00:01
[58/107] Fetching git-2.29.2.txz: 100%    5 MiB 737.2kB/s    00:07
[59/107] Fetching gettext-runtime-0.21.txz: 100%  148 KiB 151.1kB/s    00:01
[60/107] Fetching flashrom-1.2.txz: 100%  183 KiB 187.1kB/s    00:01
[61/107] Fetching e2fsprogs-libuuid-1.45.6.txz: 100%   34 KiB  34.7kB/s    00:01
[62/107] Fetching dmidecode-3.3.txz: 100%   61 KiB  62.5kB/s    00:01
[63/107] Fetching cyrus-sasl-2.1.27_1.txz: 100%  230 KiB 235.4kB/s    00:01
[64/107] Fetching curl-7.73.0.txz: 100%    1 MiB 553.4kB/s    00:02
[65/107] Fetching ca_root_nss-3.58.txz: 100%  285 KiB 291.6kB/s    00:01
[66/107] Fetching c-ares-1.16.1.txz: 100%  137 KiB 140.0kB/s    00:01
[67/107] Fetching boost-libs-1.72.0_3.txz: 100%   12 MiB 727.7kB/s    00:18
[68/107] Fetching bash-5.0.18_3.txz: 100%    1 MiB 417.1kB/s    00:03
[69/107] Fetching py37-mock-3.0.5.txz: 100%   42 KiB  42.7kB/s    00:01
[70/107] Fetching p5-HTTP-Message-6.26.txz: 100%   78 KiB  80.0kB/s    00:01
[71/107] Fetching p5-LWP-MediaTypes-6.04.txz: 100%   20 KiB  20.1kB/s    00:01
[72/107] Fetching p5-HTTP-Date-6.05.txz: 100%   10 KiB  10.6kB/s    00:01
[73/107] Fetching p5-TimeDate-2.33,1.txz: 100%   33 KiB  33.5kB/s    00:01
[74/107] Fetching p5-URI-1.76.txz: 100%   76 KiB  78.3kB/s    00:01
[75/107] Fetching p5-IO-HTML-1.001_1.txz: 100%   14 KiB  14.5kB/s    00:01
[76/107] Fetching p5-Clone-0.45.txz: 100%   10 KiB  10.5kB/s    00:01
[77/107] Fetching p5-Encode-Locale-1.05.txz: 100%   12 KiB  11.9kB/s    00:01
[78/107] Fetching brotli-1.0.9,1.txz: 100%  356 KiB 364.5kB/s    00:01
[79/107] Fetching p5-subversion-1.14.0.txz: 100%    1 MiB 533.3kB/s    00:02
[80/107] Fetching utf8proc-2.5.0.txz: 100%   54 KiB  55.2kB/s    00:01
[81/107] Fetching subversion-1.14.0.txz: 100%    3 MiB 536.5kB/s    00:06
[82/107] Fetching serf-1.3.9_5.txz: 100%   83 KiB  84.8kB/s    00:01
[83/107] Fetching apr-1.7.0.1.6.1_1.txz: 100%  467 KiB 478.3kB/s    00:01
[84/107] Fetching gdbm-1.18.1_1.txz: 100%  162 KiB 165.9kB/s    00:01
[85/107] Fetching db5-5.3.28_7.txz: 100%    1 MiB 504.6kB/s    00:03
[86/107] Fetching gnupg-2.2.23.txz: 100%    2 MiB 522.8kB/s    00:04
[87/107] Fetching pinentry-1.1.0_6.txz: 100%   16 KiB  16.6kB/s    00:01
[88/107] Fetching pinentry-tty-1.1.0.txz: 100%   28 KiB  29.1kB/s    00:01
[89/107] Fetching libgpg-error-1.39.txz: 100%  232 KiB 237.2kB/s    00:01
[90/107] Fetching libassuan-2.5.4.txz: 100%   78 KiB  79.7kB/s    00:01
[91/107] Fetching libksba-1.4.0.txz: 100%  174 KiB 177.8kB/s    00:01
[92/107] Fetching libgcrypt-1.8.7.txz: 100%  616 KiB 630.3kB/s    00:01
[93/107] Fetching gnutls-3.6.15.txz: 100%    2 MiB 634.6kB/s    00:04
[94/107] Fetching trousers-0.3.14_3.txz: 100%  475 KiB 486.6kB/s    00:01
[95/107] Fetching tpm-emulator-0.7.4_2.txz: 100%  114 KiB 116.4kB/s    00:01
[96/107] Fetching gmp-6.2.0.txz: 100%  477 KiB 488.4kB/s    00:01
[97/107] Fetching p11-kit-0.23.21.txz: 100%  394 KiB 403.1kB/s    00:01
[98/107] Fetching bash-completion-2.11,2.txz: 100%  185 KiB 189.5kB/s    00:01
[99/107] Fetching libtasn1-4.16.0.txz: 100%  124 KiB 127.4kB/s    00:01
[100/107] Fetching nettle-3.6.txz: 100%  684 KiB 350.4kB/s    00:02
[101/107] Fetching libidn2-2.3.0_1.txz: 100%  111 KiB 113.3kB/s    00:01
[102/107] Fetching libunistring-0.9.10_1.txz: 100%  484 KiB 495.7kB/s    00:01
[103/107] Fetching npth-1.6.txz: 100%   21 KiB  21.0kB/s    00:01
[104/107] Fetching sqlite3-3.33.0_1,1.txz: 100%    1 MiB 483.3kB/s    00:03
[105/107] Fetching libedit-3.1.20191231,1.txz: 100%  134 KiB 137.3kB/s    00:01
[106/107] Fetching liblz4-1.9.2_1,1.txz: 100%  151 KiB 154.4kB/s    00:01
[107/107] Fetching p5-Term-ReadKey-2.38_1.txz: 100%   19 KiB  20.0kB/s    00:01
[1/108] Upgrading readline from 8.0.0 to 8.0.4...
[1/108] Extracting readline-8.0.4: 100%
[2/108] Upgrading libffi from 3.2.1_3 to 3.3_1...
[2/108] Extracting libffi-3.3_1: 100%
[3/108] Upgrading gettext-runtime from 0.20.1 to 0.21...
[3/108] Extracting gettext-runtime-0.21: 100%
[4/108] Upgrading python37 from 3.7.5_1 to 3.7.9_1...
[4/108] Extracting python37-3.7.9_1: 100%
[5/108] Upgrading py37-setuptools from 41.4.0_1 to 44.0.0...
[5/108] Extracting py37-setuptools-44.0.0: 100%
[6/108] Upgrading py37-pycparser from 2.19 to 2.20...
[6/108] Extracting py37-pycparser-2.20: 100%
[7/108] Upgrading py37-six from 1.12.0 to 1.15.0...
[7/108] Extracting py37-six-1.15.0: 100%
[8/108] Upgrading py37-cffi from 1.13.2 to 1.14.3...
[8/108] Extracting py37-cffi-1.14.3: 100%
[9/108] Upgrading py37-asn1crypto from 0.24.0 to 1.3.0...
[9/108] Extracting py37-asn1crypto-1.3.0: 100%
[10/108] Upgrading bash from 5.0.11 to 5.0.18_3...
[10/108] Extracting bash-5.0.18_3: 100%
[11/108] Installing libgpg-error-1.39...
[11/108] Extracting libgpg-error-1.39: 100%
[12/108] Installing gmp-6.2.0...
[12/108] Extracting gmp-6.2.0: 100%
[13/108] Upgrading perl5 from 5.30.1 to 5.32.0...
[13/108] Extracting perl5-5.32.0: 100%
[14/108] Upgrading ca_root_nss from 3.48 to 3.58...
[14/108] Extracting ca_root_nss-3.58: 100%
[15/108] Installing libassuan-2.5.4...
[15/108] Extracting libassuan-2.5.4: 100%
[16/108] Installing tpm-emulator-0.7.4_2...
===> Creating groups.
Creating group '_tss' with gid '601'.
===> Creating users
Creating user '_tss' with uid '601'.
[16/108] Extracting tpm-emulator-0.7.4_2: 100%
[17/108] Installing bash-completion-2.11,2...
[17/108] Extracting bash-completion-2.11,2: 100%
[18/108] Installing libtasn1-4.16.0...
[18/108] Extracting libtasn1-4.16.0: 100%
[19/108] Installing libunistring-0.9.10_1...
[19/108] Extracting libunistring-0.9.10_1: 100%
[20/108] Upgrading py37-idna from 2.8 to 2.10...
[20/108] Extracting py37-idna-2.10: 100%
[21/108] Upgrading py37-certifi from 2019.9.11 to 2020.6.20...
[21/108] Extracting py37-certifi-2020.6.20: 100%
[22/108] Installing p5-TimeDate-2.33,1...
[22/108] Extracting p5-TimeDate-2.33,1: 100%
[23/108] Installing gdbm-1.18.1_1...
[23/108] Extracting gdbm-1.18.1_1: 100%
[24/108] Installing db5-5.3.28_7...
[24/108] Extracting db5-5.3.28_7: 100%
[25/108] Installing pinentry-tty-1.1.0...
[25/108] Extracting pinentry-tty-1.1.0: 100%
[26/108] Installing trousers-0.3.14_3...
Using existing group '_tss'.
===> Creating users
Using existing user '_tss'.
[26/108] Extracting trousers-0.3.14_3: 100%
[27/108] Installing p11-kit-0.23.21...
[27/108] Extracting p11-kit-0.23.21: 100%
[28/108] Installing nettle-3.6...
[28/108] Extracting nettle-3.6: 100%
[29/108] Installing libidn2-2.3.0_1...
[29/108] Extracting libidn2-2.3.0_1: 100%
[30/108] Installing libedit-3.1.20191231,1...
[30/108] Extracting libedit-3.1.20191231,1: 100%
[31/108] Upgrading py37-urllib3 from 1.25.6,1 to 1.25.11,1...
[31/108] Extracting py37-urllib3-1.25.11,1: 100%
[32/108] Installing p5-LWP-MediaTypes-6.04...
[32/108] Extracting p5-LWP-MediaTypes-6.04: 100%
[33/108] Installing p5-HTTP-Date-6.05...
[33/108] Extracting p5-HTTP-Date-6.05: 100%
[34/108] Installing p5-URI-1.76...
[34/108] Extracting p5-URI-1.76: 100%
[35/108] Installing p5-IO-HTML-1.001_1...
[35/108] Extracting p5-IO-HTML-1.001_1: 100%
[36/108] Installing p5-Clone-0.45...
[36/108] Extracting p5-Clone-0.45: 100%
[37/108] Installing p5-Encode-Locale-1.05...
[37/108] Extracting p5-Encode-Locale-1.05: 100%
[38/108] Installing apr-1.7.0.1.6.1_1...
[38/108] Extracting apr-1.7.0.1.6.1_1: 100%
[39/108] Installing pinentry-1.1.0_6...
[39/108] Extracting pinentry-1.1.0_6: 100%
[40/108] Installing libksba-1.4.0...
[40/108] Extracting libksba-1.4.0: 100%
[41/108] Installing libgcrypt-1.8.7...
[41/108] Extracting libgcrypt-1.8.7: 100%
[42/108] Installing gnutls-3.6.15...
[42/108] Extracting gnutls-3.6.15: 100%
[43/108] Installing npth-1.6...
[43/108] Extracting npth-1.6: 100%
[44/108] Installing sqlite3-3.33.0_1,1...
[44/108] Extracting sqlite3-3.33.0_1,1: 100%
[45/108] Upgrading py37-requests from 2.22.0 to 2.22.0_2...
[45/108] Extracting py37-requests-2.22.0_2: 100%
[46/108] Upgrading py37-pytz from 2019.3,1 to 2020.1,1...
[46/108] Extracting py37-pytz-2020.1,1: 100%
[47/108] Reinstalling p5-Socket6-0.29...
[47/108] Extracting p5-Socket6-0.29: 100%
[48/108] Reinstalling p5-HTML-Tagset-3.20_1...
[48/108] Extracting p5-HTML-Tagset-3.20_1: 100%
[49/108] Upgrading icu from 65.1,1 to 68.1,1...
[49/108] Extracting icu-68.1,1: 100%
[50/108] Installing p5-HTTP-Message-6.26...
[50/108] Extracting p5-HTTP-Message-6.26: 100%
[51/108] Installing utf8proc-2.5.0...
[51/108] Extracting utf8proc-2.5.0: 100%
[52/108] Installing serf-1.3.9_5...
[52/108] Extracting serf-1.3.9_5: 100%
[53/108] Installing gnupg-2.2.23...
[53/108] Extracting gnupg-2.2.23: 100%
[54/108] Installing liblz4-1.9.2_1,1...
[54/108] Extracting liblz4-1.9.2_1,1: 100%
[55/108] Deinstalling python27-2.7.17_1...
[55/108] Deleting files for python27-2.7.17_1: 100%
[56/108] Upgrading snappy from 1.1.7 to 1.1.8...
[56/108] Extracting snappy-1.1.8: 100%
[57/108] Upgrading py37-requests-toolbelt from 0.8.0_1 to 0.9.1...
[57/108] Extracting py37-requests-toolbelt-0.9.1: 100%
[58/108] Upgrading py37-josepy from 1.2.0 to 1.4.0...
[58/108] Extracting py37-josepy-1.4.0: 100%
[59/108] Upgrading pcre from 8.43_2 to 8.44...
[59/108] Extracting pcre-8.44: 100%
[60/108] Upgrading pciids from 20191211 to 20200922...
[60/108] Extracting pciids-20200922: 100%
[61/108] Upgrading p5-Net-SSLeay from 1.85 to 1.88...
[61/108] Extracting p5-Net-SSLeay-1.88: 100%
[62/108] Upgrading p5-Mozilla-CA from 20180117 to 20200520...
[62/108] Extracting p5-Mozilla-CA-20200520: 100%
[63/108] Reinstalling p5-IO-Socket-INET6-2.72_1...
[63/108] Extracting p5-IO-Socket-INET6-2.72_1: 100%
[64/108] Upgrading p5-HTML-Parser from 3.72 to 3.75...
[64/108] Extracting p5-HTML-Parser-3.75: 100%
[65/108] Reinstalling p5-Digest-HMAC-1.03_1...
[65/108] Extracting p5-Digest-HMAC-1.03_1: 100%
[66/108] Upgrading libuv from 1.34.0 to 1.40.0...
[66/108] Extracting libuv-1.40.0: 100%
[67/108] Upgrading libnghttp2 from 1.40.0 to 1.41.0...
[67/108] Extracting libnghttp2-1.41.0: 100%
[68/108] Upgrading libconfuse from 3.2.1_1 to 3.3_2...
[68/108] Extracting libconfuse-3.3_2: 100%
[69/108] Upgrading e2fsprogs-libuuid from 1.45.3 to 1.45.6...
[69/108] Extracting e2fsprogs-libuuid-1.45.6: 100%
[70/108] Upgrading cyrus-sasl from 2.1.27 to 2.1.27_1...
*** Updated user `cyrus'.
[70/108] Extracting cyrus-sasl-2.1.27_1: 100%
[71/108] Upgrading c-ares from 1.15.0_1 to 1.16.1...
[71/108] Extracting c-ares-1.16.1: 100%
[72/108] Upgrading boost-libs from 1.72.0 to 1.72.0_3...
[72/108] Extracting boost-libs-1.72.0_3: 100%
[73/108] Installing py37-mock-3.0.5...
[73/108] Extracting py37-mock-3.0.5: 100%
[74/108] Installing brotli-1.0.9,1...
[74/108] Extracting brotli-1.0.9,1: 100%
[75/108] Installing subversion-1.14.0...
[75/108] Extracting subversion-1.14.0: 100%
[76/108] Upgrading py37-parsedatetime from 2.5 to 2.6...
[76/108] Extracting py37-parsedatetime-2.6: 100%
[77/108] Upgrading py37-distro from 1.4.0_1 to 1.5.0...
[77/108] Extracting py37-distro-1.5.0: 100%
[78/108] Upgrading py37-configargparse from 0.15.2 to 1.2.3...
[78/108] Extracting py37-configargparse-1.2.3: 100%
[79/108] Upgrading py37-acme from 0.39.0,1 to 1.9.0,1...
[79/108] Extracting py37-acme-1.9.0,1: 100%
[80/108] Upgrading p5-IO-Socket-SSL from 2.066 to 2.068...
[80/108] Extracting p5-IO-Socket-SSL-2.068: 100%
[81/108] Upgrading p5-Error from 0.17028 to 0.17029...
[81/108] Extracting p5-Error-0.17029: 100%
[82/108] Upgrading p5-CGI from 4.44 to 4.51...
[82/108] Extracting p5-CGI-4.51: 100%
[83/108] Reinstalling p5-Authen-SASL-2.16_1...
[83/108] Extracting p5-Authen-SASL-2.16_1: 100%
[84/108] Upgrading node from 13.3.0 to 15.2.0...
[84/108] Extracting node-15.2.0: 100%
[85/108] Upgrading mongodb36 from 3.6.14_1 to 3.6.20...
Using existing group 'mongodb'.
===> Creating users
Using existing user 'mongodb'.
===> Creating homedir(s)
[85/108] Extracting mongodb36-3.6.20: 100%
[86/108] Upgrading libpci from 3.6.2 to 3.7.0_1...
[86/108] Extracting libpci-3.7.0_1: 100%
[87/108] Upgrading libftdi1 from 1.4_14 to 1.5_1...
[87/108] Extracting libftdi1-1.5_1: 100%
[88/108] Upgrading gmake from 4.2.1_3 to 4.3_2...
[88/108] Extracting gmake-4.3_2: 100%
[89/108] Upgrading dmidecode from 3.2 to 3.3...
[89/108] Extracting dmidecode-3.3: 100%
[90/108] Upgrading curl from 7.67.0 to 7.73.0...
[90/108] Extracting curl-7.73.0: 100%
[91/108] Installing p5-subversion-1.14.0...
[91/108] Extracting p5-subversion-1.14.0: 100%
[92/108] Installing p5-Term-ReadKey-2.38_1...
[92/108] Extracting p5-Term-ReadKey-2.38_1: 100%
[93/108] Upgrading udx from 1.0.26_4 to 1.0.26_27...
[93/108] Extracting udx-1.0.26_27: 100%
[94/108] Upgrading sudo from 1.8.29 to 1.9.3p1...
[94/108] Extracting sudo-1.9.3p1: 100%
[95/108] Upgrading py37-yaml from 5.2 to 5.3.1...
[95/108] Extracting py37-yaml-5.3.1: 100%
[96/108] Upgrading py37-regex from 2018.02.21 to 2020.7.14...
[96/108] Extracting py37-regex-2020.7.14: 100%
[97/108] Upgrading py37-pycryptodome from 3.9.0 to 3.9.8...
[97/108] Extracting py37-pycryptodome-3.9.8: 100%
[98/108] Upgrading py37-pip from 19.1.1 to 20.2.3...
[98/108] Extracting py37-pip-20.2.3: 100%
[99/108] Upgrading py37-holidays from 0.9.11_1 to 0.9.12...
[99/108] Extracting py37-holidays-0.9.12: 100%
[100/108] Upgrading py37-dateutil from 2.8.0 to 2.8.1...
[100/108] Extracting py37-dateutil-2.8.1: 100%
[101/108] Upgrading py37-certbot from 0.39.0,1 to 1.9.0,1...
[101/108] Extracting py37-certbot-1.9.0,1: 100%
[102/108] Upgrading powerdxx from 0.4.3 to 0.4.4...
[102/108] Extracting powerdxx-0.4.4: 100%
[103/108] Upgrading polyglot from 2.2.8 to 2.2.9_7...
Using existing group 'polyglot'.
===> Creating users
Using existing user 'polyglot'.
[103/108] Extracting polyglot-2.2.9_7: 100%
[104/108] Upgrading npm from 6.12.1 to 6.14.8...
[104/108] Extracting npm-6.14.8: 100%
[105/108] Upgrading libwebsockets from 2.4.2 to 4.0.21...
[105/108] Extracting libwebsockets-4.0.21: 100%
[106/108] Upgrading isc-dhcp44-client from 4.4.1_1 to 4.4.2_1...
[106/108] Extracting isc-dhcp44-client-4.4.2_1: 100%
[107/108] Upgrading git from 2.24.1 to 2.29.2...
Using existing group 'git_daemon'.
===> Creating users
Using existing user 'git_daemon'.
[107/108] Extracting git-2.29.2: 100%
[108/108] Upgrading flashrom from 1.1 to 1.2...
[108/108] Extracting flashrom-1.2: 100%
Message from bash-completion-2.11,2:
To enable the bash completion library, add the following to
your .bashrc file:
[[ $PS1 && -f /usr/local/share/bash-completion/bash_completion.sh ]] && \
        source /usr/local/share/bash-completion/bash_completion.sh
See /usr/local/share/doc/bash-completion/README.md for more information.
Message from trousers-0.3.14_3:
To run tcsd automatically, add the following line to /etc/rc.conf:
tcsd_enable="YES"
You might want to edit /usr/local/etc/tcsd.conf to reflect your setup.
If you want to use tcsd with software TPM emulator, use the following
configuration in /etc/rc.conf:
tcsd_enable="YES"
tcsd_mode="emulator"
tpmd_enable="YES"
To use TPM, add your_account to '_tss' group like following:
# pw groupmod _tss -m your_account
Message from py37-urllib3-1.25.11,1:
Since version 1.25 HTTPS connections are now verified by default which is done
via "cert_reqs = 'CERT_REQUIRED'".  While certificate verification can be
disabled via "cert_reqs = 'CERT_NONE'", it's highly recommended to leave it on.
Various consumers of net/py-urllib3 already have implemented routines that
either explicitly enable or disable HTTPS certificate verification (e.g. via
configuration settings, CLI arguments, etc.).
Yet it may happen that there are still some consumers which don't explicitly
enable/disable certificate verification for HTTPS connections which could then
lead to errors (as is often the case with self-signed certificates).
In case of an error one should try first to temporarily disable certificate
verification of the problematic urllib3 consumer to see if that approach will
remedy the issue.
Message from apr-1.7.0.1.6.1_1:
The Apache Portable Runtime project removed support for FreeTDS with
version 1.6. Users requiring MS-SQL connectivity must migrate
configurations to use the added ODBC driver and FreeTDS' ODBC features.
Message from gnupg-2.2.23:
GnuPG, when run on hosts without IPv6 connectivity, may fail to connect to
dual-stack hkp servers [1].  As a workaround, add
disable-ipv6
to
/usr/local/etc/dirmngr.conf
[1] https://dev.gnupg.org/rGecfc4db3a2f8bc2652ba4ac4de5ca1cd13bfcbec
Message from py37-certbot-1.9.0,1:
The certbot periodic script has new config options:
 * weekly_certbot_pre_hook
 * weekly_certbot_post_hook
 * weekly_certbot_deploy_hook
 * weekly_certbot_custom_args
For config details, see the certbot periodic script:
    /usr/local/etc/periodic/weekly/500.certbot-3.7
[admin@polisy ~]$
After rebooting I now seen to get all 3 LEDs fast blinking.  then a beep  with one LED than back to the 3 LEDs Blinking.  Some sort of rolling reboot?
just playing around some more but don't really know what I am doing
login as: admin
Last login: Sun Nov 15 12:27:09 2020 from desktop-78qab1r
Welcome to Polisy!
Password:
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Your packages are up to date.
mongod is running as pid 23101.
[admin@polisy ~]$
what should I try as a next step?
ok, I will submit a ticket.  Not exactly the same constant beeping.  But after the SW update I have 3 LEDS Fast Blinking for 30 Seconds then goes down to two LEDs fast blinking then a beep with only one LED Blinking once followed by two beeps and back to all three LEDs blinking again (this sequence constantly repeats itself.)
Edited by epete
typo
greetings;
I also had Polisy beeping this morning, followed the instructions in the manual. the beeping stopped, but the whole system is behaving bizarrely, not connecting to ISY anymore, and Polisy Log (from local) is now back to admin/admin... followed the instructions with SSH, but of course they don't change the admin/admin default at all.
Corrupted Database
Default password is admin. Once this process is done, please change it   <----- HOW HOW HOW????
sudo service mongod status. If it's not running, then:
sudo rm -rf /var/db/mongodb
sudo reboot
Ran the sudo recommended above, here's the result. no change in behaviour. And yes, submitted a ticket...
Last login: Sat Nov 21 15:06:09 2020 from 192.168.10.190
Welcome to Polisy!
Password:
[admin@polisy ~]$
I'll echo multiple posts on the  topic of login/password: This feature belongs into settings, not SSH. Or AT LEAST give us clear instructions! Am I frustrated? YES!
Thanks guys.
23 hours ago, Michel Kohanim said:
@TriLife,
Is this for ticket 10649?
Hi @Michel Kohanim; not sure about the ticket number. I haven't received an acknowledgement to my mail to support (Polisy crashed and now unstable sent
Sat, 21 Nov, 14:57 (3 days ago)
We seem to be back to the same bug, that I don't get replies to my mails... I had brought that up some months ago (to Brad, I think, when I was first struggling with Polisy).
cheers;
13 minutes ago, Michel Kohanim said:
@TriLife, please send an email directly to support@universal-devices.com .
That's where it went the first time. Just re-sent it. Coming from jr@***.ws
And this time a got a ticket#10705...
