Polisy version mismatch message
yes and he said on the chat he has the same behavior as me
"Maybe I declared victory too early.... I am actually seeing the same behavior as @macjeff. After a Polyglot restart, you get the green "No updates available..."  bar  BUT, one day later, the bar no longer appears. Past history has been for updates to be released at least every week. I plan to wait a few weeks and see if any updates are received and successfully installed. "
and I have spoken to him just recently and it is still happening.
If you reboot everything is fine.  You say check for updates under the system menu.   and you get a response in a green box
Update Check complete. No updates available!"
or Update Polisy under the System Menu and you get a green box saying "Update success! Check polisy logs for details."
BUT if you wait a while.  Sometimes 12 hours but for sure the next day.   You check for updates or Update Polisy and you get no response.
Again I confirmed that @gviliunas still has the same issue.
jeff
yes but just did it again
[admin@polisy ~]$ curl -s https://pkg.isy.io/script/update121.sh | sudo bash
Password:
Installing FreeBSD-base updates
Updating FreeBSD-base repository catalogue...
FreeBSD-base repository is up to date.
Updating udi repository catalogue...
udi repository is up to date.
All repositories are up to date.
Checking for upgrades (0 candidates): 100%
Processing candidates (0 candidates): 100%
Checking integrity... done (0 conflicting)
Your packages are up to date.
pkg: No packages available to install matching 'FreeBSD-*' have been found in the repositories
lookig for .pkgnew files...
Preserving files that are unique to Polisy
lookig for any left over .pkgnew files...
Upgrade complete, please reboot using: sudo shutdown -r now
I discovered something new.  When the Check Updates and Install Updates wont give any feedback, it wont retrieve the configuration when asked under the settings menu.   It just stays on retrieving configuration (as mentioned by another user in this post).
The polisy reboot fixes this also but as with the check for updates I assume its a temporary fix,
