New to Z-Wave
sndflea
I've been running Insteon and X-10 for years but have no experience with Z-Wave.  I've added the dongle and the module.  Trying to add an Enbrighten Toggle Switch.  First thing I did was do a factory reset of the dongle.  Next clicked Add Z-Wave Device.  Window pops up searching for device.  Directions for Enbrighten say to press up and release the toggle to add it to the network.  ISY never sees the switch.  I did a bench test and put the switch right next to the ISY and it still doesn't see it.   I have read the documentation  for ISY / Z-Wave and thing I have done everything that I should have to get it set up.  What am I missing?
When adding zwave devices, the first thing you should do is exclude the device and then include the device. Be sure to move the device within 3 feet of the ISY while doing this.
2 minutes ago, sndflea said:
In the Admin Console I can see the option to add a device and to remove a device that has been added.  How do I exclude it?
Here are the instructions from the Wiki.
Remove Devices
  • Select Remove/Exclude a Z-Wave Device from the menu and wait for a popup window to appear.
    • If the popup window does not appear, Select Stop Adding or Removing a Z-Wave Device from the advanced menu then try again.
  • Put the Z-Wave device in link mode. Refer to the user guide for your product on how to do this. In many cases, this just requires you to press a button on the device.
  • The ISY will remove the device (this may occur a few seconds after you put the device in link mode)
    • The popup window will go away, but you will NOT see your device removed from the tree.
Notes
  • Deleting a node from the ISY does not delete it from the Z-Wave dongle.
  • When nodes are removed with a different controller, the ISY nodes are disabled instead of deleted. This is done in case the user accidentally removes ISY from the Z-Wave network, which essentially tells ISY that all nodes are deleted. We may change this behaviour based on Alpha feedback.
Adding Devices directly from ISY
  • Make sure the ISY is the Primary Controller
  • Select Add a Z-Wave Device from the menu and wait for a popup window to appear.
    • If the popup window does not appear, Select 'Stop Adding or Removing a Z-Wave Device' from the advanced menu then try again.
  • The ISY will begin adding the device (this may occur a few seconds after you put the device in link mode)
    • The popup window will go away, and you will see your device added to the tree.
Note
  • All Secure devices such as door locks must be added to the ISY directly
      38.1k
      379.6k
