Portal maintenance - October 2 - 4am-5am Pacific ×
ELK connection problems
drich
I have an Elk M1 Gold that has been working great with my ISY994i for years. Recently however I have noticed that the response to requests for the Elk has been slow and after my ISY is up and running for a few days it seems to lose the connection to it entirely. The only thing I see in the event logs are messages like the following . I don't know if the socket errors are related, but they seem to start showing up in the logs around the time that the connections start failing.
I don't think it's a problem with the Elk network interface, as that seems to work fine with Home Assistant and with anything else that queries it directly.
Any ideas? I'm currently running 5.3.0, I'm not sure if this started occurring with the 5.3 upgrade or it was happening before and I just didn't notice it.
Sun 12/27/2020 20:28:47 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:28:47 : Elk Query All Failed, requesting retry
Sun 12/27/2020 20:28:48 : [ELK-TX      ] Get Topology
Sun 12/27/2020 20:28:59 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:02 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:02 : [ELK         ] Disconnect
Sun 12/27/2020 20:29:02 : [ELK         ] Connect
Sun 12/27/2020 20:29:02 : [ELK         ] Connect Successful
Sun 12/27/2020 20:29:13 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:15 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:16 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:20 : Elk Query All
Sun 12/27/2020 20:29:20 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:24 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:28 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:29 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:31 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:37 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:40 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:29:43 : SOCK-READ-16 - Buffer Overflow
Sun 12/27/2020 20:30:10 : Elk Query All Failed, requesting retry
32 minutes ago, Michel Kohanim said:
@drich,
Can you please make sure ELK RP is not turned on. Also, could it be using a different port now?
The thing is, it works fine after a reboot. Then within a couple of days it'll start throwing that SOCK-READ-16 error and fail. I have been having problems with my polyglot server, is it possible there is a resource leak somewhere and that is causing the ISY to run out of socket connections? I fixed the polyglot issue last night, so if that is the case this should stop happening.
8 hours ago, Michel Kohanim said:
@drich,
Please send your full error log to support@universal-devices.com.
I will send in a set of logs the next time this happens.
On 12/30/2020 at 7:37 AM, Michel Kohanim said:
@drich,
@Michel KohanimI sent in the logs last week (I realize it was a holiday weekend and likely no one has even looked at them yet).
FWIW, the problem seems to be getting worse. I rebooted yesterday evening as the ISY couldn't connect to the ELK again, and the problem has already reoccured this morning. I am not seeing anything obvious in the error or event logs that could be triggering this, and I have disabled most of the programs calling network resources at this point.
I also just noticed that several of my Z-Wave devices are sitting with the "writing changes" icon showing in the UI. I wonder if that could be related?
Edited by drich
3 hours ago, Michel Kohanim said:
@drich,
Do you have a ticket#? I cannot find it.
I got a ticket on resending the e-mail: #11411
